[mapserver-commits] r10776 - trunk/mapserver
Thu Dec 2 08:54:37 EST 2010
Author: tamas
Date: 2010-12-02 05:54:37 -0800 (Thu, 02 Dec 2010)
New Revision: 10776
   trunk/mapserver/mapmssql2008.c
Replace _msStrdup with msStrdup to prevent from the linker error.
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c	2010-12-02 04:57:11 UTC (rev 10775)
+++ trunk/mapserver/mapmssql2008.c	2010-12-02 13:54:37 UTC (rev 10776)
@@ -531,7 +531,7 @@
-	geom_table = _msStrdup(layerinfo->geom_table);
+	geom_table = msStrdup(layerinfo->geom_table);
     pos_from = strstrIgnoreCase(geom_table, " from ");
     if(!pos_from) {
@@ -569,7 +569,7 @@
         snprintf(buffer, sizeof(buffer), "%s.STAsBinary(),convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
-        columns_wanted = _msStrdup(buffer);
+        columns_wanted = msStrdup(buffer);
     else
@@ -581,7 +581,7 @@
         snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(),convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
 	if (rect.minx == rect.maxx || rect.miny == rect.maxy)
@@ -671,7 +671,7 @@
     if (executeSQL(layerinfo->conn, query_string_temp))
-        *query_string = _msStrdup(query_string_temp);
+        *query_string = msStrdup(query_string_temp);
         return MS_SUCCESS;
@@ -1496,7 +1496,7 @@
     if(layer->numitems == 0)
         snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
     else
@@ -1506,13 +1506,13 @@
         snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
 	/* index_name is ignored here since the hint should be for the spatial index, not the PK index */
     snprintf(buffer, sizeof(buffer), "select %s from %s where %s = %d", columns_wanted, layerinfo->geom_table, layerinfo->urid_name, record);
-    query_str = _msStrdup(buffer);
+    query_str = msStrdup(buffer);
     if(layer->debug) {
         msDebug("msMSSQL2008LayerGetShape: %s \n", query_str);
@@ -1723,7 +1723,7 @@
         buff[retLen] = 0;
-        *urid_name = _msStrdup(buff);
+        *urid_name = msStrdup(buff);
     return MS_SUCCESS;
