[mapserver-commits] r10806 - trunk/mapserver
Fri Dec 17 15:59:08 EST 2010
Author: assefa
Date: 2010-12-17 12:59:07 -0800 (Fri, 17 Dec 2010)
New Revision: 10806
   trunk/mapserver/mapkmlrenderer.cpp
set kml_outputasraster at map level #3501
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp	2010-12-17 20:57:50 UTC (rev 10805)
+++ trunk/mapserver/mapkmlrenderer.cpp	2010-12-17 20:59:07 UTC (rev 10806)
@@ -239,6 +239,8 @@
     /*if layer has a metadata KML_OUTPUTASRASTER set to true, add a processing directive
       to use an agg driver*/
     asRaster = msLookupHashTable(&layer->metadata, "kml_outputasraster");
+    if (!asRaster)
+       asRaster = msLookupHashTable(&(layer->map->web.metadata), "kml_outputasraster");
     if (asRaster && (strcasecmp(asRaster, "true") == 0 ||
                      strcasecmp(asRaster, "yes") == 0))
       msLayerAddProcessing(layer, "RENDERER=png24");
