[mapserver-commits] r10811 - in trunk/msautotest: pymod wxs
Wed Dec 22 00:00:45 EST 2010
Author: sdlime
Date: 2010-12-21 21:00:45 -0800 (Tue, 21 Dec 2010)
New Revision: 10811
Added:
   trunk/msautotest/wxs/wcs_post.map
   trunk/msautotest/pymod/mstestlib.py
   trunk/msautotest/wxs/wcs_simple.map
New/updated set of tests for WCS 2.0 support (#3595).
Modified: trunk/msautotest/pymod/mstestlib.py
--- trunk/msautotest/pymod/mstestlib.py	2010-12-22 04:43:56 UTC (rev 10810)
+++ trunk/msautotest/pymod/mstestlib.py	2010-12-22 05:00:45 UTC (rev 10811)
@@ -319,6 +319,18 @@
                 command = string.replace( command, '[RENDERER]', '-i '+renderer )
             else:
                 command = string.replace( command, '[RENDERER]', '' )
+            # support for POST request method
+            begin = command.find('[POST]')
+            end = command.find('[/POST]')
+            if begin != -1 and end != -1 and begin < end:
+                post = command[begin+len('[POST]'):end]
+                tmp = command
+                post = string.replace(post, '"', '\'')
+                command = 'echo "' + post + '" | ' + tmp[:begin] + tmp[end+len('[/POST]'):]
+                os.environ['CONTENT_LENGTH'] = str(len(post))
+                os.environ['REQUEST_METHOD'] = "POST"
+                os.environ['MS_MAPFILE'] = map
             command = string.replace( command, '[MAPSERV]', 'mapserv' )
             command = string.replace( command, '[LEGEND]', 'legend' )
Added: trunk/msautotest/wxs/wcs_post.map
--- trunk/msautotest/wxs/wcs_post.map	                        (rev 0)
+++ trunk/msautotest/wxs/wcs_post.map	2010-12-22 05:00:45 UTC (rev 10811)
@@ -0,0 +1,183 @@
+# Test WCS.
+# REQUIRES: INPUT=GDAL OUTPUT=PNG SUPPORTS=WCS
+# Some post tests
+# RUN_PARMS: wcs_20_post_cap.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCapabilities xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"/>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_desc.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:DescribeCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" version="2.0.0" service="WCS"><wcs:coverageid>grey</wcs:coverageid></wcs:DescribeCoverage>[/POST] > [RESULT_DEMIME]
+# Subsetting
+# RUN_PARMS: wcs_20_post_getcov_trim_x_min.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>20</wcs:TrimLow></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_x_max.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_x_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_y_max.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>20</wcs:TrimLow></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_y_min.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_y_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_trim_x_y_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_full_multipart.dat [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Mediatype>multipart/mixed</wcs:Mediatype></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Subsetting in diverse CRS
+# RUN_PARMS: wcs_20_post_getcov_imageCRS.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">x</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>10</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">y</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>10</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_origCRS.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">x</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">y</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_reproj.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lon</wcs:Dimension><wcs:TrimLow>-121.488</wcs:TrimLow><wcs:TrimHigh>-121.487</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lat</wcs:Dimension><wcs:TrimLow>0.000</wcs:TrimLow><wcs:TrimHigh>0.001</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Scaling
+# RUN_PARMS: wcs_20_post_getcov_scaling_size_full.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">10</wcs:Size><wcs:Size dimension="y">20</wcs:Size></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_scaling_resolution_full.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="x">20</wcs:Resolution><wcs:Resolution dimension="y">20</wcs:Resolution></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_scaling_size_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">40</wcs:Size><wcs:Size dimension="y">40</wcs:Size><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>30</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>30</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_scaling_resolution_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="x">5</wcs:Resolution><wcs:Resolution dimension="y">5</wcs:Resolution><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>30</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>30</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Scaling in imageCRS
+# RUN_PARMS: wcs_20_post_getcov_imageCRS_scaling_size_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">20</wcs:Size><wcs:Size dimension="y">30</wcs:Size><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">x</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>20</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">y</wcs:Dimension><wcs:TrimLow>10</wcs:TrimLow><wcs:TrimHigh>30</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_imageCRS_scaling_resolution_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="x">20</wcs:Resolution><wcs:Resolution dimension="y">5</wcs:Resolution><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">x</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>10</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="imageCRS">y</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>10</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Scaling in Original CRS
+# RUN_PARMS: wcs_20_post_getcov_origCRS_scaling_size_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">30</wcs:Size><wcs:Size dimension="y">35</wcs:Size><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">x</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">y</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_origCRS_scaling_resolution_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="x">5</wcs:Resolution><wcs:Resolution dimension="y">2</wcs:Resolution><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">x</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/32611">y</wcs:Dimension><wcs:TrimLow>0</wcs:TrimLow><wcs:TrimHigh>50</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Reprojected Scaling
+# RUN_PARMS: wcs_20_post_getcov_reproj_scaling_size_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="lat">30</wcs:Size><wcs:Size dimension="lon">40</wcs:Size><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lon</wcs:Dimension><wcs:TrimLow>-121.488</wcs:TrimLow><wcs:TrimHigh>-121.487</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lat</wcs:Dimension><wcs:TrimLow>0.000</wcs:TrimLow><wcs:TrimHigh>0.001</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_reproj_scaling_resolution_trim_both.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="lat">0.00002</wcs:Resolution><wcs:Resolution dimension="lon">0.00005</wcs:Resolution><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lon</wcs:Dimension><wcs:TrimLow>-121.488</wcs:TrimLow><wcs:TrimHigh>-121.487</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension crs="http://www.opengis.net/def/crs/EPSG/0/4326">lat</wcs:Dimension><wcs:TrimLow>0.000</wcs:TrimLow><wcs:TrimHigh>0.001</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Size and Resolution
+# RUN_PARMS: wcs_20_post_getcov_scaling_size_resolution.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">10</wcs:Size><wcs:Resolution dimension="y">5</wcs:Resolution></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_scaling_resolution_size.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Resolution dimension="x">5</wcs:Resolution><wcs:Size dimension="y">10</wcs:Size></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# Interpolation
+# RUN_PARMS: wcs_20_post_getcov_interpolation_nearest.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">20</wcs:Size><wcs:Size dimension="y">20</wcs:Size><wcs:Interpolation>NEAREST</wcs:Interpolation></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_interpolation_average.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">20</wcs:Size><wcs:Size dimension="y">20</wcs:Size><wcs:Interpolation>AVERAGE</wcs:Interpolation></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_getcov_interpolation_bilinear.tif [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">20</wcs:Size><wcs:Size dimension="y">20</wcs:Size><wcs:Interpolation>BILINEAR</wcs:Interpolation></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# InvalidParameterValue
+# RUN_PARMS: wcs_20_post_exception_invalidparam_request.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:InvalidRequest xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"/>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_exception_invalidparam_coverage.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>invalid</wcs:CoverageID></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_exception_invalidparam_format.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/invalid</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_exception_invalidparam_interpolation.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:Interpolation>INVALIDINTERPOLATION</wcs:Interpolation><wcs:CoverageID>grey</wcs:CoverageID></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# MissingParameterValue
+# RUN_PARMS: wcs_20_post_exception_missingparam_coverage.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_post_exception_missingparam_format.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:CoverageID>grey</wcs:CoverageID></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# TooManyParameterValues
+# RUN_PARMS: wcs_20_post_exception_toomanyparams_coverage.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:CoverageID>grey2</wcs:CoverageID></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# ExtentError
+# RUN_PARMS: wcs_20_post_exception_extent_nooverlap.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:DimensionTrim><wcs:Dimension>x</wcs:Dimension><wcs:TrimLow>1000</wcs:TrimLow><wcs:TrimHigh>2000</wcs:TrimHigh></wcs:DimensionTrim><wcs:DimensionTrim><wcs:Dimension>y</wcs:Dimension><wcs:TrimLow>1000</wcs:TrimLow><wcs:TrimHigh>2000</wcs:TrimHigh></wcs:DimensionTrim></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+# ScalingError
+# RUN_PARMS: wcs_20_post_exception_scaling.xml [MAPSERV] -nh [POST]<?xml version="1.0" encoding="UTF-8"?><wcs:GetCoverage xmlns:wcs="http://www.opengis.net/wcs/2.0" service="WCS" version="2.0.0"><wcs:Format>image/tiff</wcs:Format><wcs:CoverageID>grey</wcs:CoverageID><wcs:Size dimension="x">20</wcs:Size><wcs:Resolution dimension="x">20</wcs:Resolution></wcs:GetCoverage>[/POST] > [RESULT_DEMIME]
+MAP
+NAME TEST
+SIZE 400 300
+EXTENT 0 0 400 300
+IMAGETYPE PNG
+TRANSPARENT OFF
+SHAPEPATH "data"
+OUTPUTFORMAT
+  NAME GEOTIFF_16
+  DRIVER "GDAL/GTiff"
+  MIMETYPE "image/tiff"
+  IMAGEMODE INT16
+  EXTENSION "tif"
+END
+OUTPUTFORMAT
+  NAME GDPNG
+  DRIVER "AGG/PNG"
+  MIMETYPE "image/png"
+  IMAGEMODE RGB
+  EXTENSION "png"
+END
+OUTPUTFORMAT
+  NAME GDPNGGREY
+  DRIVER "GD/PNG"
+  MIMETYPE "image/png; mode=8bit"
+  IMAGEMODE PC256
+  EXTENSION "png"
+END
+OUTPUTFORMAT
+  NAME AAIGRID
+  DRIVER "GDAL/AAIGRID"
+  MIMETYPE "image/x-aaigrid"
+  IMAGEMODE INT16
+  EXTENSION "grd"
+END
+PROJECTION
+  "init=epsg:32611"
+END
+WEB
+  METADATA
+   # OWS stuff for server
+   "ows_updatesequence"   "2007-10-30T14:23:38Z"
+   "ows_title"            "First Test Service"
+   "ows_fees"             "NONE"
+   "ows_accessconstraints" "NONE"
+   "ows_abstract"         "Test Abstract"
+   "ows_keywordlist"      "keyword,list"
+   "ows_service_onlineresource" "http://198.202.74.215/cgi-bin/wcs_demo"
+   "ows_contactorganization" "OSGeo"
+   "ows_contactperson"    "Frank Warmerdam"
+   "ows_contactposition"  "Software Developer"
+   "ows_contactvoicetelephone" "(613) 754-2041"
+   "ows_contactfacsimiletelephone" "(613) 754-2041x343"
+   "ows_address" "3594 Foymount Rd"
+   "ows_city" "Eganville"
+   "ows_stateorprovince" "Ontario"
+   "ows_postcode" "K0J 1T0"
+   "ows_country" "Canada"
+   "ows_contactelectronicmailaddress" "warmerdam at pobox.com"
+   "ows_hoursofservice" "0800h - 1600h EST"
+   "ows_contactinstructions" "during hours of service"
+   "ows_role" "staff"
+   # OGC:WCS
+   "wcs_label"    "Test Label"
+   "wcs_description" "Test description"
+   "wcs_onlineresource"    "http://devgeo.cciw.ca/cgi-bin/mapserv/ecows"
+   "wcs_metadatalink_href" "http://devgeo.cciw.ca/index.html"
+  END
+END
+LAYER
+  NAME grey
+  TYPE raster
+  STATUS ON
+  DUMP TRUE
+  TILEINDEX "wcs_index.shp"
+  TILEITEM "location"
+  PROJECTION
+    "init=epsg:32611"
+  END
+  METADATA
+   "ows_extent" "0 0 400 300"
+   "wcs_label" "Test label"
+   "ows_srs"	"EPSG:32611 EPSG:4326"
+   "wcs_resolution" "10 10"
+   "wcs_bandcount" "1"
+   "wcs_formats" "GEOTIFF_16 GDPNG AAIGRID"
+   "wcs_nativeformat" "GeoTIFF"
+   "wcs_metadatalink_href" "http://www.gdal.org/metadata_test_link.html"
+   "wcs_keywordlist" "test,mapserver"
+   "wcs_abstract" "Category: Image
+Product: IKONOS-2 PAN/MSI
+Acquisition: 1999-10-11 18:47"
+   "wcs_rangeset_axes" "bands"
+   "wcs_rangeset_name" "Landsat 5 TM Bands"
+   "wcs_rangeset_label" "Bands"
+   "wcs_rangeset_description" "Bands for Landsat 5 TM"
+   "wcs_rangeset_nullvalue" "-99"
+  END
+END
+END
Modified: trunk/msautotest/wxs/wcs_simple.map
--- trunk/msautotest/wxs/wcs_simple.map	2010-12-22 04:43:56 UTC (rev 10810)
+++ trunk/msautotest/wxs/wcs_simple.map	2010-12-22 05:00:45 UTC (rev 10811)
@@ -6,6 +6,8 @@
 # Exception
 # RUN_PARMS: wcs_exception.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage" > [RESULT]
+# RUN_PARMS: wcs_exception-2.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=a" > [RESULT]
+# RUN_PARMS: wcs_exception-3.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=3.0.0&REQUEST=GetCoverage" > [RESULT]
 # Capabilities
 # RUN_PARMS: wcs_cap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities" > [RESULT_DEVERSION]
@@ -86,6 +88,92 @@
 # GetCoverage to GDPNG 1.1 (Test non-GDAL output)
 # RUN_PARMS: wcs_getcov_gdpng8_11.dat [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=1.1.0&REQUEST=GetCoverage&FORMAT=image/png;%20mode=8bit&BOUNDINGBOX=0,-121.48874388968,0.0027058261133485,-121.48516027717,urn:ogc:def:crs:EPSG::4326&IDENTIFIER=grey&GridCS=urn:ogc:def:crs:OGC::imageCRS&GridType=urn:ogc:def:method:WCS:1.1:2dGridIn2dCrs&GridOrigin=0.0027058261133485,-121.48874388968&GridOffsets=-0.0003,0.0003" > [RESULT]
+# WCS 2.0.0
+# GetCapabilities 2.0
+# RUN_PARMS: wcs_20_cap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCapabilities" > [RESULT_DEMIME]
+# DescribeCoverage 2.0
+# RUN_PARMS: wcs_20_desc.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=DescribeCoverage&COVERAGEID=grey" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff full
+# RUN_PARMS: wcs_20_getcov_full.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim x min
+# RUN_PARMS: wcs_20_getcov_trim_x_min.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(20,*)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim x max
+# RUN_PARMS: wcs_20_getcov_trim_x_max.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(*,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim x both
+# RUN_PARMS: wcs_20_getcov_trim_x_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim y min
+# RUN_PARMS: wcs_20_getcov_trim_y_min.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=y(20,*)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim y max
+# RUN_PARMS: wcs_20_getcov_trim_y_max.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=y(*,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim y both
+# RUN_PARMS: wcs_20_getcov_trim_y_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=y(10,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 image/tiff trim x y both
+# RUN_PARMS: wcs_20_getcov_trim_x_y_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,20)&SUBSET=y(10,20)" > [RESULT_DEMIME]
+# GetCoverage 2.0 gml+image/tiff full
+# RUN_PARMS: wcs_20_getcov_full.dat [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&MEDIATYPE=multipart/mixed" > [RESULT_DEMIME]
+# GetCoverage 2.0 imageCRS
+# RUN_PARMS: wcs_20_getcov_imageCRS.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,imageCRS(0,10)&SUBSET=y,imageCRS(0,10)" > [RESULT_DEMIME]
+# GetCoverage 2.0 EPSG 32611
+# RUN_PARMS: wcs_20_getcov_origCRS.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)&SUBSET=y,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)" > [RESULT_DEMIME]
+# GetCoverage 2.0 reproject to EPSG 4326
+# RUN_PARMS: wcs_20_getcov_reproj.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=long,http://www.opengis.net/def/crs/EPSG/0/4326(-121.488,-121.487)&SUBSET=lat,http://www.opengis.net/def/crs/EPSG/0/4326(0,0.001)" > [RESULT_DEMIME]
+# GetCoverage 2.0 scaling
+# RUN_PARMS: wcs_20_getcov_scaling_size_full.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SIZE=x(10)&SIZE=y(20)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_scaling_resolution_full.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&RESOLUTION=x(20)&RESOLUTION=y(20)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_scaling_size_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,30)&SUBSET=y(10,30)&SIZE=x(40)&SIZE=y(40)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_scaling_resolution_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x(10,30)&SUBSET=y(10,30)&RESOLUTION=x(5)&RESOLUTION=y(5)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_imageCRS_scaling_size_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,imageCRS(10, 20)&SUBSET=y,imageCRS(10, 20)&SIZE=x(20)&SIZE=y(30)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_imageCRS_scaling_resolution_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,imageCRS(0,10)&SUBSET=y,imageCRS(0,10)&RESOLUTION=x(20)&RESOLUTION=y(5)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_origCRS_scaling_size_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)&SUBSET=y,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)&SIZE=x(30)&SIZE=y(35)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_origCRS_scaling_resolution_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=x,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)&SUBSET=y,http://www.opengis.net/def/crs/EPSG/0/32611(0,50)&RESOLUTION=x(5)&RESOLUTION=y(2)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_reproj_scaling_size_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=long,http://www.opengis.net/def/crs/EPSG/0/4326(-121.488,-121.487)&SUBSET=lat,http://www.opengis.net/def/crs/EPSG/0/4326(0,0.001)&SIZE=long(30)&SIZE=lat(40)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_reproj_scaling_resolution_trim_both.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SUBSET=long,http://www.opengis.net/def/crs/EPSG/0/4326(-121.488,-121.487)&SUBSET=lat,http://www.opengis.net/def/crs/EPSG/0/4326(0,0.001)&RESOLUTION=long(0.00002)&RESOLUTION=lat(0.00005)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_scaling_size_resolution.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SIZE=x(10)&RESOLUTION=y(5)" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_scaling_resolution_size.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&RESOLUTION=x(5)&SIZE=y(10)" > [RESULT_DEMIME]
+# GetCoverage 2.0 Interpolation
+# RUN_PARMS: wcs_20_getcov_interpolation_nearest.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SIZE=x(20)&SIZE=y(20)&INTERPOLATION=NEAREST" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_interpolation_average.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SIZE=x(20)&SIZE=y(20)&INTERPOLATION=AVERAGE" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_getcov_interpolation_bilinear.tif [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&SIZE=x(20)&SIZE=y(20)&INTERPOLATION=BILINEAR" > [RESULT_DEMIME]
+# WCS 2.0 Exceptions
+# RUN_PARMS: wcs_20_exception_invalidparam_request.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=InvalidRequest" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_invalidparam_coverage.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&FORMAT=image/png&COVERAGEID=invalid" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_invalidparam_format.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&FORMAT=image/invalid&COVERAGEID=grey" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_invalidparam_interpolation.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/png&INTERPOLATION=NOVALIDINTERPOLATION" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_missingparam_request.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_missingparam_coverage.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&FORMAT=image/png" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_missingparam_format.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey" > [RESULT_DEMIME]
+# RUN_PARMS: wcs_20_exception_toomanyparams_coverage.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&FORMAT=image/png&COVERAGEID=a,b,c" > [RESULT_DEMIME]
+# ExtentError
+# RUN_PARMS: wcs_20_exception_extent_nooverlap.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&FORMAT=image/png&COVERAGEID=grey&SUBSET=x(1000,2000)&SUBSET=y(1000,2000)" > [RESULT_DEMIME]
+# ScalingError
+# RUN_PARMS: wcs_20_exception_scaling.xml [MAPSERV] QUERY_STRING="map=[MAPFILE]&SERVICE=WCS&VERSION=2.0.0&REQUEST=GetCoverage&COVERAGEID=grey&FORMAT=image/tiff&RESOLUTION=x(5)&SIZE=x(10)" > [RESULT_DEMIME]
 MAP
 NAME TEST
@@ -105,7 +193,7 @@
 END
 OUTPUTFORMAT
   NAME GDPNG
-  DRIVER "GD/PNG"
+  DRIVER "AGG/PNG"
   IMAGEMODE RGB
   EXTENSION "png"
