[mapserver-commits] r10817 - trunk/mapserver
Thu Dec 23 14:11:07 EST 2010
Author: sdlime
Date: 2010-12-23 11:11:07 -0800 (Thu, 23 Dec 2010)
New Revision: 10817
   trunk/mapserver/maptemplate.c
First crack at supporting inner and outer ring formatting in shpxy tag. (#3606)
Modified: trunk/mapserver/maptemplate.c
--- trunk/mapserver/maptemplate.c	2010-12-23 17:42:41 UTC (rev 10816)
+++ trunk/mapserver/maptemplate.c	2010-12-23 19:11:07 UTC (rev 10817)
@@ -1865,6 +1865,9 @@
   char *irh, *irf; /* inner ring: necessary for complex polygons */
   char *orh, *orf; /* outer ring */
+  int useRingFormatting = MS_FALSE; /* do we need to consider inner and outer rings in formatting */
+  int isOuterRing;
   int centroid;
   int precision;
@@ -1913,7 +1916,7 @@
     projectionString = NULL;
     tagOffset = tagStart - *line;
     /* check for any tag arguments */
     if(getTagArgs("shpxy", tagStart, &tagArgs) != MS_SUCCESS) return(MS_FAILURE);
     if(tagArgs) {
@@ -2077,7 +2080,14 @@
     /* TODO: add thinning support here */
-    /* build the coordinate string */
+    ** build the coordinate string
+    /* do we need to handle inner/outer rings */
+    if(tShape.type == MS_SHAPE_POLYGON && strlen(orh) > 0 && strlen(irh) > 0)
+      useRingFormatting = MS_TRUE;
     if(strlen(sh) > 0) coords = msStringConcatenate(coords, sh);
     for(i=0; i<tShape.numlines; i++) { /* e.g. part */
@@ -2086,14 +2096,32 @@
         (tShape.type == MS_SHAPE_POLYGON && tShape.line[i].numpoints < 3))
         continue;
-      if(strlen(ph) > 0) coords = msStringConcatenate(coords, ph);
+      if(useRingFormatting) {
+        isOuterRing = msIsOuterRing(&tShape, i); /* compute once */
+        if(isOuterRing == MS_TRUE)
+          coords = msStringConcatenate(coords, orh);
+        else
+          coords = msStringConcatenate(coords, irh);
+      } else if(strlen(ph) > 0) {
+        coords = msStringConcatenate(coords, ph);
       for(j=0; j<tShape.line[i].numpoints-1; j++) {
         snprintf(point, sizeof(point), pointFormat1, scale_x*tShape.line[i].point[j].x, scale_y*tShape.line[i].point[j].y);
         coords = msStringConcatenate(coords, point);
       snprintf(point, sizeof(point), pointFormat2, scale_x*tShape.line[i].point[j].x, scale_y*tShape.line[i].point[j].y);
-      if(strlen(pf) > 0) coords = msStringConcatenate(coords, pf);
+          coords = msStringConcatenate(coords, orf);
+        else
+          coords = msStringConcatenate(coords, irf);
+      } else if(strlen(pf) > 0) {
+        coords = msStringConcatenate(coords, pf);
       if((i < tShape.numlines-1) && (strlen(ps) > 0)) coords = msStringConcatenate(coords, ps);
     if(strlen(sf) > 0) coords = msStringConcatenate(coords, sf);
