[mapserver-commits] r9768 - trunk/mapserver
Mon Feb 1 17:04:24 EST 2010
Author: pramsey
Date: 2010-02-01 17:04:23 -0500 (Mon, 01 Feb 2010)
New Revision: 9768
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapwms.c
Add support for the WMS capabilities items AuthorityURL, Identifier (#3251)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-29 18:50:11 UTC (rev 9767)
+++ trunk/mapserver/HISTORY.TXT	2010-02-01 22:04:23 UTC (rev 9768)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Add support for the WMS capabilities items AuthorityURL, Identifier (#3251)
 - Added support to write a null shape in a shape file. (#3277)
 - Apply ON_MISSING_DATA to zero-length WMS client calls (#2785, #3243)
Modified: trunk/mapserver/mapwms.c
--- trunk/mapserver/mapwms.c	2010-01-29 18:50:11 UTC (rev 9767)
+++ trunk/mapserver/mapwms.c	2010-02-01 22:04:23 UTC (rev 9768)
@@ -1584,6 +1584,47 @@
                          MS_FALSE, MS_FALSE, MS_FALSE, MS_TRUE, MS_TRUE,
                          NULL, NULL, NULL, NULL, NULL, "        ");
+  /* AuthorityURL support and Identifier support, only available > WMS 1.1.0 */
+  if(nVersion >= OWS_1_1_0)
+    const char *pszWmsAuthorityName = msOWSLookupMetadata(&(lp->metadata), "MO", "authorityurl_name");
+    const char *pszWMSAuthorityHref = msOWSLookupMetadata(&(lp->metadata), "MO", "authorityurl_href");
+    const char *pszWMSIdentifierAuthority = msOWSLookupMetadata(&(lp->metadata), "MO", "identifier_authority");
+    const char *pszWMSIdentifierValue = msOWSLookupMetadata(&(lp->metadata), "MO", "identifier_value");
+    /* AuthorityURL only makes sense if you have *both* the name and url */
+    if( pszWmsAuthorityName && pszWMSAuthorityHref )
+       msOWSPrintEncodeMetadata(stdout, &(lp->metadata), "MO", "authorityurl_name",
+                                OWS_NOERR, "        <AuthorityURL name=\"%s\">\n",
+                                NULL);
+       msOWSPrintEncodeMetadata(stdout, &(lp->metadata), "MO", "authorityurl_href",
+                                OWS_NOERR, "          <OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:href=\"%s\"/>\n",
+                                NULL);
+       msIO_printf("        </AuthorityURL>\n");
+    else if ( pszWmsAuthorityName || pszWMSAuthorityHref )
+       msIO_printf("        <!-- WARNING: Both wms_authorityurl_name and wms_authorityurl_href must be set to output an AuthorityURL -->\n");
+    /* Identifier only makes sense if you have *both* the authority and value */
+    if( pszWMSIdentifierAuthority && pszWMSIdentifierValue )
+      msOWSPrintEncodeMetadata(stdout, &(lp->metadata), "MO", "identifier_authority",
+                               OWS_NOERR, "        <Identifier authority=\"%s\">",
+                               NULL);
+      msOWSPrintEncodeMetadata(stdout, &(lp->metadata), "MO", "identifier_value",
+                               OWS_NOERR, "%s</Identifier>\n>",
+                               NULL);
+    else if ( pszWMSIdentifierAuthority || pszWMSIdentifierValue )
+       msIO_printf("        <!-- WARNING: Both wms_identifier_authority and wms_identifier_value must be set to output an Identifier -->\n");
    /* The LegendURL reside in a style. The Web Map Context spec already  */
    /* included the support on this in mapserver. However, it is not in the  */
    /* wms_legendurl_... metadatas it's in the styles metadata, */
