[mapserver-commits] r9792 - trunk/mapserver
Fri Feb 12 16:47:09 EST 2010
Author: assefa
Date: 2010-02-12 16:47:09 -0500 (Fri, 12 Feb 2010)
New Revision: 9792
   trunk/mapserver/mapogcfilter.c
   trunk/mapserver/mapwfs.c
Strip name spaces used in property names #3308
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2010-02-12 15:49:26 UTC (rev 9791)
+++ trunk/mapserver/mapogcfilter.c	2010-02-12 21:47:09 UTC (rev 9792)
@@ -3991,6 +3991,36 @@
+static void FLTStripNameSpacesFromPropertyName(FilterEncodingNode *psFilterNode)
+    char **tokens=NULL;
+    int n=0;
+    if (psFilterNode)
+         if (psFilterNode->eType == FILTER_NODE_TYPE_PROPERTYNAME)
+             if (psFilterNode->pszValue &&
+                 strstr(psFilterNode->pszValue, ":"))
+                 tokens = msStringSplit(psFilterNode->pszValue, ':', &n);
+                 if (tokens && n==2)
+                     msFree(psFilterNode->pszValue);
+                     psFilterNode->pszValue = strdup(tokens[1]);
+                 if (tokens && n>0)
+                   msFreeCharArray(tokens, n);
+         if (psFilterNode->psLeftNode)
+           FLTStripNameSpacesFromPropertyName(psFilterNode->psLeftNode);
+         if (psFilterNode->psRightNode)
+           FLTStripNameSpacesFromPropertyName(psFilterNode->psRightNode);
 /*                        FLTPreParseFilterForAlias                     */
@@ -4008,6 +4038,9 @@
     if (psFilterNode && map && i>=0 && i<map->numlayers)
+        /*strip name speces befor hand*/
+        FLTStripNameSpacesFromPropertyName(psFilterNode);
         lp = GET_LAYER(map, i);
         if (msLayerOpen(lp) == MS_SUCCESS && msLayerGetItems(lp) == MS_SUCCESS)
Modified: trunk/mapserver/mapwfs.c
--- trunk/mapserver/mapwfs.c	2010-02-12 15:49:26 UTC (rev 9791)
+++ trunk/mapserver/mapwfs.c	2010-02-12 21:47:09 UTC (rev 9792)
@@ -1171,7 +1171,39 @@
                           if (strlen(tokens[i]) > 0)
-                              papszPropertyName[i] = strdup(tokens[i]);
+                              /*trim namespaces. PROPERTYNAME=(ns:prop1,ns:prop2)(prop1)*/
+                              if (strstr(tokens[i], ":"))
+                                  char **tokens1, **tokens2;
+                                  int n1=0,n2=0,l=0;
+                                  char *pszTmp = NULL;
+                                  tokens1 = msStringSplit(tokens[i], ',', &n1);
+                                  for (l=0;l<n1;l++)
+                                      if (pszTmp!=NULL)
+                                        pszTmp = msStringConcatenate(pszTmp,",");
+                                      if (strstr(tokens1[l],":"))
+                                          tokens2 = msStringSplit(tokens1[l], ':', &n2);
+                                          if (tokens2 && n2==2)
+                                            pszTmp = msStringConcatenate(pszTmp, tokens2[1]);
+                                          else
+                                            pszTmp = msStringConcatenate(pszTmp,tokens1[l]);
+                                          if (tokens2 && n2>0)
+                                            msFreeCharArray(tokens2, n2);
+                                      else
+                                  papszPropertyName[i] = strdup(pszTmp);
+                                  msFree(pszTmp);
+                                  if (tokens1 && n1>0)
+                                    msFreeCharArray(tokens1, n1);
+                              else
+                                papszPropertyName[i] = strdup(tokens[i]);
                               /* remove trailing ) */
                               papszPropertyName[i][strlen(papszPropertyName[i])-1] = '\0';
