[mapserver-commits] r9807 - branches/branch-5-6/docs/en/development/rfc
Sat Feb 20 12:11:47 EST 2010
Author: assefa
Date: 2010-02-20 12:11:46 -0500 (Sat, 20 Feb 2010)
New Revision: 9807
Added:
   branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt
KML output
Added: branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt
--- branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt	                        (rev 0)
+++ branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt	2010-02-20 17:11:46 UTC (rev 9807)
@@ -0,0 +1,208 @@
+.. _rfc58:
+MS RFC 58: Kml Output
+:Date: 2009/03/01
+:Authors: Dvaid Kana (david.kana at gmail.com)
+:Authors: Thomas.Bonfort (thomas.bonfort at gmail.com)
+:Authors: Yewondwossen Assefa (yassefa at dmsolutions.ca)
+:Authors: Michael Smith (michael.smith at usace.army.mil)
+:Status: Planning
+:Version: MapServer 6.0
+:Id: $
+Purpose
+This purpose of this RFC is to provide a KML output for MapServer 6.0.
+The initial work was done by David Kana during the 2009 Google Summer of Code.
+The main task of the project is the implementation of the KML driver for generating
+KML output used mainly by Google Earth application. Code for KML rendering is based
+on new renderer API described in MS RFC 54
+First intention was to use original KML library libkml provided by Google but due
+to its complexity libxml2 already included in MapServer was selected for xml generating.
+Functionnalities
+KML driver can work in two modes: vector mode generates standard KML output where
+MapServer shapes are transformed into KML elements called placemarks.
+On the other side, raster mode generates standard MapServer raster image output
+transformed into KML element ground overlay. Switching between vector and raster
+depends on feature count and user can change default value on global level using
+FORMATOPTION or using layer METADATA.
+Format options
+KML_RASTEROUTPUTFOMAT specifies name of the raster driver, default value is cairopng.
+OUTPUTFORMAT
+    NAME "cairo/kml"
+    DRIVER "cairo/png"
+    IMAGEMODE RGBA
+END
+OUTPUTFORMAT
+    NAME "kml"
+    DRIVER "KML"
+    IMAGEMODE RGB
+    FORMATOPTION "kml_rasteroutputformat=cairo/kml"
+    FORMATOPTION "kml_maxfeaturecount=30"
+END
+IMAGETYPE 'KML'
+Driver configuration options
+KML_MAXFEATURECOUNT
+Maximum number of features rendered as KML vector, if number of features rendered
+in one layer is greater than maximum feature count, layer is rasterized and renderer
+generates ground overlay KML element.
+KML_DUMPATTRIBUTES
+Option whether or not to create KML description element "baloon" containing shape
+attributes. Default is yes, possible values 0, no, or list of attributes separated
+by comma.
+Example: KML_DUMPATTRIBUTES "NAME,SIZE"
+KML_ALTITUDEMODE
+Specifies how altitude components in the <coordinates> element are interpreted.
+Possible values are: absolute, relativeToGround, clampToGround.
+http://code.google.com/apis/kml/documentation/kmlreference.html#altitudemode
+KML_EXTRUDE
+Specifies whether to connect the LinearRing to the ground.
+http://code.google.com/apis/kml/documentation/kmlreference.html#tessellate
+KML_TESSELLATE
+Specifies whether to allow the LinearRing to follow the terrain.
+http://code.google.com/apis/kml/documentation/kmlreference.html#extrude
+Options are specified in layer metadata.
+LAYER
+METADATA
+	kml_maxfeaturecount	"512"
+END
+END
+Projection
+Google  Earth accepts only WGS84 Lat Lon coordinates, using mapfile projection
+epsg:4326 is the only alternative. Driver tests mapfile projection and generates
+error when projection doesn't match.
+Shape  types
+MapServer layer is transformed into KML element Folder
+For every shape KML driver creates KML element Placemark.
+Point shapes
+- is transformed into Placemark including symbol.
+Line shape
+- is transformed into kml element LineString, supported attributes:
+color, width.
+Polygon shape
+- is transformed into KML element Polygon, supported attributes:
+outline color, color, width.
+Symbol
+- is rendered and stored in separate file and transformed into KML element
+Icon.
+Label
+- is transformed into placemark name. To ensure binding shape and label,
+labelcache should be switched off.  Label position LL is also recommended.
+LAYER
+LABELCACHE OFF
+END
+Raster layers are not supported yet
+WMS Client layers are not yet supported
+Compressed KMZ output
+Minizip library was tested as possibility for generating compressed KML output,
+additional efforts needed to determine how to integrate effectively minizip library
+into MapServer.
+KML NetworkLink
+MapServer KML output can be displayed in Google Earth using KML NetworkLink element.
+<?xml version="1.0" encoding="UTF-8"?>
+<kml xmlns="http://www.opengis.net/kml/2.2">
+<Folder>
+<name>MapServer KML Reflector</name>
+<NetworkLink>
+  <name>Network Link</name>
+  <visibility>1</visibility>
+  <flyToView>0</flyToView>
+  <Link>
+    <href>http://localhost/Mapserver/Mapserv.cgi?map=test_kml.map&amp;MODE=map</href>
+    <viewRefreshMode>onStop</viewRefreshMode>
+    <viewRefreshTime>1</viewRefreshTime>
+    <viewFormat>MAPEXT=[bboxWest] [bboxSouth] [bboxEast] [bboxNorth]</viewFormat>
+  </Link>
+</NetworkLink>
+</Folder>
+</kml>
+Testing
+Development is done for now inside http://svn.osgeo.org/mapserver/sandbox/davidK/
+sandbox
+Documentation
+Comments from Review period
+Voting History
Property changes on: branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt
___________________________________________________________________
Added: svn:executable
