[mapserver-commits] r9810 -
branches/branch-5-6/docs/en/mapscript/php
svn at osgeo.org
svn at osgeo.org
Sat Feb 20 13:11:52 EST 2010
Author: jmckenna
Date: 2010-02-20 13:11:51 -0500 (Sat, 20 Feb 2010)
New Revision: 9810
branches/branch-5-6/docs/en/mapscript/php/index.txt
document resultsGetShape() - ticket 3140
Modified: branches/branch-5-6/docs/en/mapscript/php/index.txt
--- branches/branch-5-6/docs/en/mapscript/php/index.txt 2010-02-20 17:24:08 UTC (rev 9809)
+++ branches/branch-5-6/docs/en/mapscript/php/index.txt 2010-02-20 18:11:51 UTC (rev 9810)
@@ -982,14 +982,22 @@
Returns MS_TRUE/MS_FALSE depending on whether the layer is
currently visible in the map (i.e. turned on, in scale, etc.).
-int setConenctionType(int connectiontype [,string plugin_library])
+int setConnectionType(int connectiontype [,string plugin_library])
Changes the connectiontype of the layer and recreates the vtable
according to the new connection type. This method should be used
instead of setting the connectiontype parameter directly.
- In case when the layer.connectiontype = MS_PLUGIN the plugin_library
+ In the case when the layer.connectiontype = MS_PLUGIN the plugin_library
parameter should also be specified so as to select the library to
- load by mapserver. For the other connection types this parameter
+ load by MapServer. For the other connection types this parameter
is not used.
+shapeObj resultsGetShape(int shapeindex [, int tileindex = -1])
+ Retrieve shapeObj from a layer's resultset by index.
+ Tileindex is optional and is used only for tiled shapefiles
+ (you get it from the resultCacheMemberObj returned by getResult()
+ for instance).
+ Simply omit or pass tileindex = -1 for other data sources.
+ Added in MapServer 5.6.0 due to the one-pass query implementation.
ClassObj Class
More information about the mapserver-commits
