[mapserver-commits] r9817 - trunk/docs/en/output
Sat Feb 20 14:35:54 EST 2010
Author: pramsey
Date: 2010-02-20 14:35:53 -0500 (Sat, 20 Feb 2010)
New Revision: 9817
   trunk/docs/en/output/tile_mode.txt
Documentation for metatile/buffer in mode=tile (#3323)
Modified: trunk/docs/en/output/tile_mode.txt
--- trunk/docs/en/output/tile_mode.txt	2010-02-20 18:38:16 UTC (rev 9816)
+++ trunk/docs/en/output/tile_mode.txt	2010-02-20 19:35:53 UTC (rev 9817)
@@ -59,7 +59,13 @@
  * MapServer compiled with PROJ support
  * Map file with a :ref:`PROJECTION` defined for every :ref:`LAYER`
+As of MapServer 6.0, there are two extra parameters available for configuring tile mode.
+ * *tile_map_edge_buffer* renders the tile into a buffered rendering frame, then clips out the final tile. This will reduce edge effects when large symbols or wide lines are drawn. Recommended value: the size of the largest symbol or line width in your map file.
+ * *tile_metatile_level* renders the into into a fixed metatile, then clips out the final tile. This will reduce label repetition, at the expense of much higher rendering cost.  Recommended value: 1 if you are doing labelling of large features in your layer. 0 otherwise.
+If you use both *tile_map_edge_buffer* and *tile_metatile_level* at the same time, the buffer will be applied at the meta-tile level.
 Utilization
