[mapserver-commits] r9820 - branches/branch-5-6/docs/en/mapfile
Sat Feb 20 15:19:38 EST 2010
Author: sdlime
Date: 2010-02-20 15:19:38 -0500 (Sat, 20 Feb 2010)
New Revision: 9820
   branches/branch-5-6/docs/en/mapfile/template.txt
Minor edits...
Modified: branches/branch-5-6/docs/en/mapfile/template.txt
--- branches/branch-5-6/docs/en/mapfile/template.txt	2010-02-20 20:18:22 UTC (rev 9819)
+++ branches/branch-5-6/docs/en/mapfile/template.txt	2010-02-20 20:19:38 UTC (rev 9820)
@@ -632,7 +632,7 @@
      In addition the escaped version (for use in URLs) as well as the raw data is
      available.
-[Join name_DBASE item name],[Join name_DBASE item name_esc], [Join name_DBASE item name_raw]
+[Join name_attribute name],[Join name_attribute name_esc], [Join name_attribute name_raw]
      One-to-one joins: First the join name (as specified in the :ref:`mapfile` has to
      be given, second the tables fields can be accessed similar to the layers
      attribute data. Available only when processing query results.
