[mapserver-commits] r9826 - trunk/mapserver
Sat Feb 20 17:32:34 EST 2010
Author: sdlime
Date: 2010-02-20 17:32:33 -0500 (Sat, 20 Feb 2010)
New Revision: 9826
   trunk/mapserver/mapfile.c
   trunk/mapserver/maplegend.c
   trunk/mapserver/mapogcsld.c
   trunk/mapserver/mapscale.c
   trunk/mapserver/mapserver.h
Added basic structure changes and initialization/free code to support styles in labelObj.
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2010-02-20 21:17:21 UTC (rev 9825)
+++ trunk/mapserver/mapfile.c	2010-02-20 22:32:33 UTC (rev 9826)
@@ -1343,6 +1343,12 @@
   label->force = MS_FALSE;
   label->priority = MS_DEFAULT_LABEL_PRIORITY;
+  /* Set maxstyles = 0, styles[] will be allocated as needed on first call
+   * to msGrowLabelStyles()
+  label->numstyles = label->maxstyles = 0;
+  label->styles = NULL;
   label->numbindings = 0;
   for(i=0; i<MS_LABEL_BINDING_LENGTH; i++) {
     label->bindings[i].item = NULL;
@@ -1359,6 +1365,15 @@
   msFree(label->font);
   msFree(label->encoding);
+  for(i=0;i<label->numstyles;i++) { /* each style */
+    if(label->styles[i]!=NULL) {
+      if(freeStyle(label->styles[i]) == MS_SUCCESS) {
+        msFree(label->styles[i]);
+  msFree(label->styles);
     msFree(label->bindings[i].item);
@@ -2312,9 +2327,7 @@
    * to msGrowClassStyles()
-  class->numstyles = 0;
-  class->maxstyles = 0;
+  class->numstyles = class->maxstyles = 0;
   class->styles = NULL;
   class->keyimage = NULL;
@@ -2403,18 +2416,54 @@
     return class->styles[class->numstyles];
+/* exactly the same as for a classObj */
+styleObj *msGrowLabelStyles( labelObj *label )
+    /* Do we need to increase the size of styles[] by  MS_STYLE_ALLOCSIZE?
+    if (label->numstyles == label->maxstyles) {
+        styleObj **newStylePtr;
+        int i, newsize;
-/* msMaybeAllocateStyle()
+        newsize = label->maxstyles + MS_STYLE_ALLOCSIZE;
+        /* Alloc/realloc styles */
+        newStylePtr = (styleObj**)realloc(label->styles,
+                                          newsize*sizeof(styleObj*));
+        if (newStylePtr == NULL) {
+            msSetError(MS_MEMERR, "Failed to allocate memory for styles array.", "msGrowLabelStyles()");
+            return NULL;
+        label->styles = newStylePtr;
+        label->maxstyles = newsize;
+        for(i=label->numstyles; i<label->maxstyles; i++) {
+            label->styles[i] = NULL;
+    if (label->styles[label->numstyles]==NULL) {
+        label->styles[label->numstyles]=(styleObj*)calloc(1,sizeof(styleObj));
+          msSetError(MS_MEMERR, "Failed to allocate memory for a styleObj", "msGrowLabelStyles()");
+          return NULL;
+    return label->styles[label->numstyles];
+/* msMaybeAllocateClassStyle()
 ** Ensure that requested style index exists and has been initialized.
 ** Returns MS_SUCCESS/MS_FAILURE.
-int msMaybeAllocateStyle(classObj* c, int idx) {
+int msMaybeAllocateClassStyle(classObj* c, int idx) {
     if (c==NULL) return MS_FAILURE;
     if ( idx < 0 ) {
-        msSetError(MS_MISCERR, "Invalid style index: %d", "msMaybeAllocateStyle()", idx);
+        msSetError(MS_MISCERR, "Invalid style index: %d", "msMaybeAllocateClassStyle()", idx);
         return MS_FAILURE;
@@ -2427,7 +2476,7 @@
         if ( initStyle(c->styles[c->numstyles]) == MS_FAILURE ) {
             msSetError(MS_MISCERR, "Failed to init new styleObj",
-                       "msMaybeAllocateStyle()");
+                       "msMaybeAllocateClassStyle()");
             return(MS_FAILURE);
         c->numstyles++;
@@ -2591,40 +2640,40 @@
     ** for backwards compatability, these are shortcuts for style 0
     case(BACKGROUNDCOLOR):
-      if (msMaybeAllocateStyle(class, 0)) return MS_FAILURE;
+      if (msMaybeAllocateClassStyle(class, 0)) return MS_FAILURE;
       if(loadColor(&(class->styles[0]->backgroundcolor), NULL) != MS_SUCCESS) return(-1);
       break;
     case(COLOR):
       if(loadColor(&(class->styles[0]->color), NULL) != MS_SUCCESS) return(-1);
       class->numstyles = 1; /* must *always* set a color or outlinecolor */
       break;
 #if ALPHACOLOR_ENABLED
     case(ALPHACOLOR):
       if(loadColorWithAlpha(&(class->styles[0]->color)) != MS_SUCCESS) return(-1);
       class->numstyles = 1; /* must *always* set a color, symbol or outlinecolor */
       break;
 #endif
     case(MAXSIZE):
       if(getDouble(&(class->styles[0]->maxsize)) == -1) return(-1);
       break;
     case(MINSIZE):
       if(getDouble(&(class->styles[0]->minsize)) == -1) return(-1);
       break;
     case(OUTLINECOLOR):
       if(loadColor(&(class->styles[0]->outlinecolor), NULL) != MS_SUCCESS) return(-1);
       break;
     case(SIZE):
       if(getDouble(&(class->styles[0]->size)) == -1) return(-1);
       break;
     case(SYMBOL):
       if((state = getSymbol(2, MS_NUMBER,MS_STRING)) == -1) return(-1);
       if(state == MS_NUMBER)
 	class->styles[0]->symbol = (int) msyynumber;
@@ -2641,33 +2690,33 @@
     ** for backwards compatability, these are shortcuts for style 1
     case(OVERLAYBACKGROUNDCOLOR):
-      if (msMaybeAllocateStyle(class, 1)) return MS_FAILURE;
+      if (msMaybeAllocateClassStyle(class, 1)) return MS_FAILURE;
       if(loadColor(&(class->styles[1]->backgroundcolor), NULL) != MS_SUCCESS) return(-1);
       break;
     case(OVERLAYCOLOR):
       if(loadColor(&(class->styles[1]->color), NULL) != MS_SUCCESS) return(-1);
       class->numstyles = 2; /* must *always* set a color, symbol or outlinecolor */
       break;
     case(OVERLAYMAXSIZE):
       if(getDouble(&(class->styles[1]->maxsize)) == -1) return(-1);
       break;
     case(OVERLAYMINSIZE):
       if(getDouble(&(class->styles[1]->minsize)) == -1) return(-1);
       break;
     case(OVERLAYOUTLINECOLOR):
       if(loadColor(&(class->styles[1]->outlinecolor), NULL) != MS_SUCCESS) return(-1);
       break;
     case(OVERLAYSIZE):
       if(getDouble(&(class->styles[1]->size)) == -1) return(-1);
       break;
     case(OVERLAYSYMBOL):
 	class->styles[1]->symbol = (int) msyynumber;
Modified: trunk/mapserver/maplegend.c
--- trunk/mapserver/maplegend.c	2010-02-20 21:17:21 UTC (rev 9825)
+++ trunk/mapserver/maplegend.c	2010-02-20 22:32:33 UTC (rev 9826)
@@ -635,7 +635,7 @@
   GET_LAYER(map, l)->status = MS_ON;
-  if(msMaybeAllocateStyle(GET_LAYER(map, l)->class[0], 0)==MS_FAILURE) return MS_FAILURE;
+  if(msMaybeAllocateClassStyle(GET_LAYER(map, l)->class[0], 0)==MS_FAILURE) return MS_FAILURE;
   GET_LAYER(map, l)->class[0]->styles[0]->symbol = s;
   GET_LAYER(map, l)->class[0]->styles[0]->color.pen = -1;
   GET_LAYER(map, l)->class[0]->label.force = MS_TRUE;
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2010-02-20 21:17:21 UTC (rev 9825)
+++ trunk/mapserver/mapogcsld.c	2010-02-20 22:32:33 UTC (rev 9826)
@@ -1127,7 +1127,7 @@
               nClassId = psLayer->numclasses-1;
             iStyle = psLayer->class[nClassId]->numstyles;
-	    msMaybeAllocateStyle(psLayer->class[nClassId], iStyle);
+	    msMaybeAllocateClassStyle(psLayer->class[nClassId], iStyle);
             msSLDParseStroke(psStroke, psLayer->class[nClassId]->styles[iStyle],
                              psLayer->map, 0);
@@ -1407,7 +1407,7 @@
             msSLDParsePolygonFill(psFill, psLayer->class[nClassId]->styles[iStyle],
                                   psLayer->map);
@@ -1431,7 +1431,7 @@
                 nClassId =psLayer->numclasses-1;
             else
@@ -1447,7 +1447,7 @@
@@ -2268,7 +2268,7 @@
         msSLDParseGraphicFillOrStroke(psRoot, NULL,
@@ -2495,7 +2495,7 @@
             initClass(psLayer->class[psLayer->numclasses]);
             nClassId = psLayer->numclasses;
             psLayer->numclasses++;
-	    msMaybeAllocateStyle(psLayer->class[nClassId], 0);
+	    msMaybeAllocateClassStyle(psLayer->class[nClassId], 0);
             nStyleId = 0;
         else
@@ -2718,7 +2718,7 @@
                                 else
                                   psLayer->class[nClassId]->name = strdup(pszPreviousQuality);
                                 psLayer->class[nClassId]->styles[0]->color.red =
                                   sColor.red;
@@ -2779,7 +2779,7 @@
                         if (pszLabel)
                           psLayer->class[nClassId]->name = strdup(pszLabel);
                         else
@@ -2890,7 +2890,7 @@
                             psLayer->class[nClassId]->numstyles = 1;
                               sColor.red;
Modified: trunk/mapserver/mapscale.c
--- trunk/mapserver/mapscale.c	2010-02-20 21:17:21 UTC (rev 9825)
+++ trunk/mapserver/mapscale.c	2010-02-20 22:32:33 UTC (rev 9826)
@@ -472,7 +472,7 @@
   /* TODO: Change this when we get rid of MS_MAXSTYLES */
-  if (msMaybeAllocateStyle(GET_LAYER(map, l)->class[0], 0)==MS_FAILURE) return MS_FAILURE;
+  if (msMaybeAllocateClassStyle(GET_LAYER(map, l)->class[0], 0)==MS_FAILURE) return MS_FAILURE;
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-02-20 21:17:21 UTC (rev 9825)
+++ trunk/mapserver/mapserver.h	2010-02-20 22:32:33 UTC (rev 9826)
@@ -651,72 +651,7 @@
 } attributeBindingObj;
 #endif
-/*                               labelObj                               */
-/*      parameters needed to annotate a layer, legend or scalebar       */
-typedef struct {
-  char *font;
-  enum MS_FONT_TYPE type;
-  colorObj color;
-  colorObj outlinecolor;
-  int outlinewidth;
-  colorObj shadowcolor;
-  int shadowsizex, shadowsizey;
-  colorObj backgroundcolor;
-  colorObj backgroundshadowcolor;
-  int backgroundshadowsizex, backgroundshadowsizey;
-  double size;
-  double minsize, maxsize;
-  int position;
-  int offsetx, offsety;
-  double angle;
-  int autoangle; /* true or false */
-  int autofollow;  /* true or false, bug #1620 implementation */
-  int buffer; /* space to reserve around a label */
-  int antialias;
-  int align;
-  char wrap;
-  int maxlength;
-  int minlength;
-  double space_size_10; /*cached size of a single space character -
-                       used for label text alignment of rfc40 */
-  int minfeaturesize; /* minimum feature size (in pixels) to label */
-  int autominfeaturesize; /* true or false */
-  double minscaledenom,maxscaledenom;
-  int mindistance;
-  int repeatdistance;
-  int partials; /* can labels run of an image */
-  int force; /* labels *must* be drawn */
-  char *encoding;
-  int priority;  /* Priority level 1 to MS_MAX_LABEL_PRIORITY, default=1 */
-#ifndef SWIG
-  attributeBindingObj bindings[MS_LABEL_BINDING_LENGTH];
-  int numbindings;
-#endif
-} labelObj;
 /*                                webObj                                */
 /*      holds parameters for a mapserver/mapscript interface            */
@@ -834,6 +769,76 @@
 } styleObj;
+/*                               labelObj                               */
+/*      parameters needed to annotate a layer, legend or scalebar       */
+typedef struct {
+  char *font;
+  enum MS_FONT_TYPE type;
+  colorObj color;
+  colorObj outlinecolor;
+  int outlinewidth;
+  colorObj shadowcolor;
+  int shadowsizex, shadowsizey;
+  colorObj backgroundcolor;
+  colorObj backgroundshadowcolor;
+  int backgroundshadowsizex, backgroundshadowsizey;
+  double size;
+  double minsize, maxsize;
+  int position;
+  int offsetx, offsety;
+  double angle;
+  int autoangle; /* true or false */
+  int autofollow;  /* true or false, bug #1620 implementation */
+  int buffer; /* space to reserve around a label */
+  int antialias;
+  int align;
+  char wrap;
+  int maxlength;
+  int minlength;
+  double space_size_10; /*cached size of a single space character -
+                       used for label text alignment of rfc40 */
+  int minfeaturesize; /* minimum feature size (in pixels) to label */
+  int autominfeaturesize; /* true or false */
+  double minscaledenom, maxscaledenom;
+  int mindistance;
+  int repeatdistance;
+  int partials; /* can labels run of an image */
+  int force; /* labels *must* be drawn */
+  char *encoding;
+  int priority;  /* Priority level 1 to MS_MAX_LABEL_PRIORITY, default=1 */
+#ifndef SWIG
+  styleObj **styles;
+  int maxstyles;
+#endif
+  int numstyles;
+#ifndef SWIG
+  attributeBindingObj bindings[MS_LABEL_BINDING_LENGTH];
+  int numbindings;
+#endif
+} labelObj;
 /*                               classObj                               */
 /*      basic symbolization and classification information              */
@@ -850,7 +855,6 @@
   styleObj **styles;
   int maxstyles;
 #endif
   int numstyles;
 #ifdef SWIG
@@ -1598,7 +1602,8 @@
 MS_DLL_EXPORT int initClass(classObj *_class);
 MS_DLL_EXPORT int freeClass( classObj * );
 MS_DLL_EXPORT styleObj *msGrowClassStyles( classObj *_class );
-MS_DLL_EXPORT int msMaybeAllocateStyle(classObj* c, int idx);
+MS_DLL_EXPORT styleObj *msGrowLabelStyles( labelObj *label );
+MS_DLL_EXPORT int msMaybeAllocateClassStyle(classObj* c, int idx);
 MS_DLL_EXPORT void initLabel(labelObj *label);
 MS_DLL_EXPORT void resetClassStyle(classObj *_class);
 MS_DLL_EXPORT int initStyle(styleObj *style);
