[mapserver-commits] r9837 - trunk/docs/en/mapscript/php
Sun Feb 21 10:07:13 EST 2010
Author: jmckenna
Date: 2010-02-21 10:07:13 -0500 (Sun, 21 Feb 2010)
New Revision: 9837
   trunk/docs/en/mapscript/php/index.txt
cleanup on symbolObj constructor (ticket:3233)
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-02-21 14:54:52 UTC (rev 9836)
+++ trunk/docs/en/mapscript/php/index.txt	2010-02-21 15:07:13 UTC (rev 9837)
@@ -2294,17 +2294,17 @@
         $oStyle->removebinding(MS_STYLE_BINDING_COLOR);
 symbolObj
 Constructor
 .. code-block:: php
-    symbolid = ms_newSymbolObj(mapObj map, string symbolname);
+    int ms_newSymbolObj(mapObj map, string symbolname)
 Creates a new symbol with default values in the symbolist. Returns the Id of
-the new symbol. If a symbol with the same name exists, It's id will be returned.
+the new symbol. If a symbol with the same name exists, its id will be returned.
 To get a symbol object, you need to use a method on the map object:
