[mapserver-commits] r9858 - in trunk/mapserver: . xmlmapfile
Mon Feb 22 10:05:02 EST 2010
Author: aboudreault
Date: 2010-02-22 10:05:01 -0500 (Mon, 22 Feb 2010)
New Revision: 9858
Added:
   trunk/mapserver/mapxml.c
   trunk/mapserver/Makefile.in
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/mapfile.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/xmlmapfile/mapfile.xsl
Added XML mapfile loading support (#3334)
Modified: trunk/mapserver/Makefile.in
--- trunk/mapserver/Makefile.in	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/Makefile.in	2010-02-22 15:05:01 UTC (rev 9858)
@@ -179,6 +179,16 @@
 XML2_INC=@XML2_INC@
 XML2_LIB=@XML2_LIB@
+# libxslt ... required for xml mapfile
+XSLT_INC=@XSLT_INC@
+XSLT_LIB=@XSLT_LIB@
+# libexslt ... required for xml mapfile
+EXSLT_INC=@EXSLT_INC@
+EXSLT_LIB=@EXSLT_LIB@
 # Optional FastCGI
 FASTCGI=@FASTCGI_ENABLED@
 FASTCGI_INC=@FASTCGI_INC@
@@ -257,7 +267,7 @@
 SUP_LIBS =  $(GD_LIB) $(AGG_LIB) $(OGL_LIB) $(FTGL_LIB) $(PDF_LIB) $(TIFF_LIB) $(PROJ_LIBS) \
           $(JPEG_LIB) $(PNG_LIB) $(SDE_LIB) $(GDAL_LIB) $(MING_LIB) $(POSTGIS_LIB) \
 	  $(MYGIS_LIB) $(CURL_LIB) $(ORACLESPATIAL_LIB) $(GEOS_LIB) \
-	  $(THREAD_LIB) $(ICONV_LIB) $(FASTCGI_LIB) \
+	  $(THREAD_LIB) $(ICONV_LIB) $(FASTCGI_LIB) $(XSLT_LIB) $(EXSLT_LIB) \
 	  $(ZLIB_LIB) $(XML2_LIB) $(FRIBIDI_LIB) $(XTRALIBS)  $(CAIRO_LIB)
 # STATIC_LIBS is full filename with path of libs that will be statically linked
@@ -267,7 +277,7 @@
 RM= /bin/rm -f
-OBJS= $(AGG_OBJ) mapogl.o mapoglrenderer.o mapoglcontext.o mapimageio.o mapcairo.o maprendering.o mapgeomtransform.o maprgbapng.o maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o mapgd.o mapagg.o mapagg2.o mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o  mapwfs11.o mapwfslayer.o mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o mapcopy.o mapogcfilter.o mapogcsld.o maptime.o mapwcs.o mapwcs11.o mapcpl.o cgiutil.o maprasterquery.o mapobject.o mapgeos.o classobject.o layerobject.o mapio.o mappool.o mapsvg.o mapregex.o mappluginlayer.o mapogcsos.o mappostgresql.o mapcrypto.o mapowscommon.o maplibxml2.o mapdebug.o mapchart.o maptclutf.o $(EPPL_OBJ)
+OBJS= $(AGG_OBJ) mapogl.o mapoglrenderer.o mapoglcontext.o mapimageio.o mapcairo.o maprendering.o mapgeomtransform.o maprgbapng.o maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o mapgd.o mapagg.o mapagg2.o mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o  mapwfs11.o mapwfslayer.o mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o mapcopy.o mapogcfilter.o mapogcsld.o maptime.o mapwcs.o mapwcs11.o mapcpl.o cgiutil.o maprasterquery.o mapobject.o mapgeos.o classobject.o layerobject.o mapio.o mappool.o mapsvg.o mapregex.o mappluginlayer.o mapogcsos.o mappostgresql.o mapcrypto.o mapowscommon.o maplibxml2.o mapdebug.o mapchart.o maptclutf.o mapxml.o $(EPPL_OBJ)
 EXE_LIST = 	shp2img shp2pdf legend mapserv shptree shptreevis \
 		shptreetst scalebar sortshp mapscriptvars tile4ms \
@@ -302,7 +312,7 @@
 mapagg.o: mapagg.cpp mapagg.h
 	$(CXX) -c $(CXXFLAGS) -Wno-uninitialized mapagg.cpp -o mapagg.o
-mapagg2.o: mapagg2.cpp mapagg.h
+mapagg2.o: mapagg2.cpp mapagg.h
 	$(CXX) -c $(CXXFLAGS) -Wno-uninitialized mapagg2.cpp -o mapagg2.o
 php3_mapscript:: $(LIBMAP_STATIC)
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/configure	2010-02-22 15:05:01 UTC (rev 9858)
@@ -309,7 +309,7 @@
 # include <unistd.h>
 #endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN ZLIB_ENABLED ZLIB_INC ZLIB_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN PDF_ENABLED PDF_INC PDF_LIB FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_ENABLED AGG_INC AGG_OBJ RGBA_PNG_ENABLED PNG_INC PNG_LIB EPPL_ENABLED EPPL_OBJ PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_ENABLED OGR_ENABLED GDAL_INC GDAL_LIB TIFF_ENABLED TIFF_INC TIFF_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYGIS_ENABLED MYGIS_INC MYGIS_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB MING_ENABLED MING_INC MING_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX RANLIB ac_ct_RANLIB LEX LEXLIB LEX_OUTPUT_ROOT YACC XTRALIBS CPP EGREP C_PIC STRINGS MS_VERSION PKG_CONFIG FT_BIN ZLIB_ENABLED ZLIB_INC ZLIB_LIB JPEG_ENABLED JPEG_INC JPEG_LIB ICONV_ENABLED ICONV_INC ICONV_LIB GD_DEF GD_INC GD_LIB GD_STATIC MAKE_GD MAKE_GD_CLEAN PDF_ENABLED PDF_INC PDF_LIB FTGL_ENABLED FTGL_INC FTGL_LIB OGL_ENABLED OGL_INC OGL_LIB AGG_ENABLED AGG_INC AGG_OBJ RGBA_PNG_ENABLED PNG_INC PNG_LIB EPPL_ENABLED EPPL_OBJ PROJ_ENABLED PROJ_INC PROJ_LIBS THREAD_FLAG THREAD_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_CONFIG GEOS_ENABLED GEOS_INC GEOS_LIB GDAL_CONFIG GDAL_ENABLED OGR_ENABLED GDAL_INC GDAL_LIB TIFF_ENABLED TIFF_INC TIFF_LIB PG_CONFIG POSTGIS_ENABLED POSTGIS_INC POSTGIS_LIB MY_CONFIG MYGIS_ENABLED MYGIS_INC MYGIS_LIB ORACLESPATIAL_ENABLED ORACLESPATIAL_INC ORACLESPATIAL_LIB MING_ENABLED MING_INC MING_LIB WMS_SVR_ENABLED WFS_SVR_ENABLED WCS_SVR_ENABLED LIBCURL_CONFIG CURL_INC CURL_LIB LIBXML2_CONFIG XML2_INC XML2_LIB WMS_LYR_ENABLED WFS_LYR_ENABLED SOS_SVR_ENABLED XSLT_ENABLED XSLT_INC XSLT_LIB EXSLT_ENABLED EXSLT_INC EXSLT_LIB FRIBIDI_CONFIG FRIBIDI_ENABLED FRIBIDI_INC FRIBIDI_LIB CAIRO_ENABLED CAIRO_INC CAIRO_LIB FASTCGI_ENABLED FASTCGI_INC FASTCGI_LIB HTTPD MS_INC MS_LIB IGNORE_MISSING_DATA USE_POINT_Z_M USE_NINT DEBUG_FLAGS LD_SHARED SO_EXT SO_COMMAND_NAME PHP_LD_SHARED PHP_VERSION_FLAG PHP_SRC_DIR PHP_CC PHP_LD PHP_REGEX_INC PHP_REGEX_OBJ USE_PHP_REGEX MAKE_PHPMS MAKE_PHPMS_CLEAN APACHE_INC OS_INCLUDE_DIR ALL_ENABLED ALL_INC ALL_LIB ALL_STATIC_LIB RPATHS LIBOBJS LTLIBOBJS'
 ac_subst_files=''
 # Initialize some variables set by options.
@@ -922,6 +922,11 @@
                           OGR required).
   --with-curl-config=PATH Specify path to curl-config.
   --with-xml2-config=PATH Specify path to xml2-config.
+  --with-xml-mapfile=                Include xml-mapfile Support (ARG=yes/no).
+  --with-xslt=DIR         Include xslt Support (ARG=yes/path to
+                          to xslt install dir).
+  --with-exslt=DIR         Include exslt Support (ARG=yes/path to
+                           to exslt install dir).
   --with-fribidi-config[=ARG]
                           Include FriBidi Support (ARG=yes/path to
                           fribidi-config or fribidi.pc)
@@ -11416,8 +11421,81 @@
       POSTGIS_LIB="-L`$PG_CONFIG --libdir` -lpq"
   fi
   POSTGIS_INC="-I`$PG_CONFIG --includedir`"
+  old_LDFLAGS="$LDFLAGS"
+  LDFLAGS="$LDFLAGS -L`$PG_CONFIG --libdir`"
+  echo "$as_me:$LINENO: checking for PQserverVersion in -lpq" >&5
+echo $ECHO_N "checking for PQserverVersion in -lpq... $ECHO_C" >&6
+if test "${ac_cv_lib_pq_PQserverVersion+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-lpq  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char PQserverVersion ();
+int
+main ()
+PQserverVersion ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  ac_cv_lib_pq_PQserverVersion=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_lib_pq_PQserverVersion=no
 fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_pq_PQserverVersion" >&5
+echo "${ECHO_T}$ac_cv_lib_pq_PQserverVersion" >&6
+if test $ac_cv_lib_pq_PQserverVersion = yes; then
+  POSTGIS_ENABLED="$POSTGIS_ENABLED -DPOSTGIS_HAS_SERVER_VERSION"
+fi
+  LDFLAGS="$old_LDFLAGS"
+fi
 POSTGIS_ENABLED=$POSTGIS_ENABLED
 POSTGIS_INC=$POSTGIS_INC
@@ -12089,6 +12167,174 @@
+# Check whether --with-xml-mapfile or --without-xml-mapfile was given.
+if test "${with_xml_mapfile+set}" = set; then
+  withval="$with_xml_mapfile"
+  XMLMAPFILE_REQUESTED=""
+fi;
+echo "$as_me:$LINENO: checking if xml-mapfile is requested" >&5
+echo $ECHO_N "checking if xml-mapfile is requested... $ECHO_C" >&6
+XMLMAPFILE_ENABLED=""
+if test "$with_xml_mapfile" = "yes"; then
+  XMLMAPFILE_ENABLED="-DUSE_XMLMAPFILE"
+  echo "$as_me:$LINENO: result: yes.. xslt and exslt support needed" >&5
+echo "${ECHO_T}yes.. xslt and exslt support needed" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+ALL_ENABLED="$XMLMAPFILE_ENABLED $ALL_ENABLED"
+# Check whether --with-xslt or --without-xslt was given.
+if test "${with_xslt+set}" = set; then
+  withval="$with_xslt"
+  XSLT_DIR=$withval
+else
+  XSLT_DIR=''
+fi;
+echo "$as_me:$LINENO: checking if xslt is requested" >&5
+echo $ECHO_N "checking if xslt is requested... $ECHO_C" >&6
+XSLT_LIB=''
+if test -z "$XMLMAPFILE_ENABLED" -a \( "$with_xslt" = "no" -o "$with_xslt" = ""  \); then
+else
+  if test "$XSLT_DIR" = "yes" -o "$XSLT_DIR" = ""; then
+     XSLT_DIR="/usr"
+  fi
+  test -f $XSLT_DIR/include/libxslt/xslt.h && XSLT_INCDIR="$XSLT_DIR/include"
+  test -f $XSLT_DIR/lib/libxslt.so && XSLT_LIBDIR="$XSLT_DIR/lib"
+  if test -n "$XSLT_LIBDIR" -a -n "$XSLT_INCDIR" ; then
+                XSLT_ENABLED="-DUSE_XSLT"
+    XSLT_INC="-I$XSLT_INCDIR"
+    XSLT_LIB="-L$XSLT_LIBDIR -lxslt"
+    echo "$as_me:$LINENO: result: using xslt from $XSLT_LIB ($XSLT_ENABLED)" >&5
+echo "${ECHO_T}using xslt from $XSLT_LIB ($XSLT_ENABLED)" >&6
+  if test ""$XSLT_DIR"" != "/usr/lib"; then
+  if test -z ""$XSLT_DIR"" || echo ""$XSLT_DIR"" | grep '^/' >/dev/null ; then
+    ai_p=""$XSLT_DIR""
+  else
+    ai_p="`pwd`/"$XSLT_DIR""
+  fi
+  unique=`echo $ac_n "$ai_p$ac_c" | tr -c -d a-zA-Z0-9`
+  cmd="echo $ac_n \"\$LIBPATH$unique$ac_c\""
+  if test -n "$unique" && test "`eval $cmd`" = "" ; then
+    eval "LIBPATH$unique=set"
+      EXTRA_LIBS="$EXTRA_LIBS -L$ai_p"
+        RPATHS="$RPATHS ${ld_runpath_switch}$ai_p"
+  fi
+  fi
+  else
+    { { echo "$as_me:$LINENO: error: '$XSLT_DIR' not a valid installation path of xslt." >&5
+echo "$as_me: error: '$XSLT_DIR' not a valid installation path of xslt." >&2;}
+   { (exit 1); exit 1; }; }
+  fi
+fi
+XSLT_ENABLED=$XSLT_ENABLED
+XSLT_INC=$XSLT_INC
+XSLT_LIB=$XSLT_LIB
+ALL_ENABLED="$XSLT_ENABLED $ALL_ENABLED"
+ALL_INC="$XSLT_INC $ALL_INC"
+ALL_LIB="$XSLT_LIB $ALL_LIB"
+# Check whether --with-exslt or --without-exslt was given.
+if test "${with_exslt+set}" = set; then
+  withval="$with_exslt"
+  EXSLT_DIR=$withval
+else
+  EXSLT_DIR=''
+fi;
+echo "$as_me:$LINENO: checking if exslt is requested" >&5
+echo $ECHO_N "checking if exslt is requested... $ECHO_C" >&6
+EXSLT_LIB=''
+if test -z "$XMLMAPFILE_ENABLED" -a \( "$with_exslt" = "no" -o "$with_exslt" = ""  \); then
+else
+  if test "$EXSLT_DIR" = "yes" -o "$EXSLT_DIR" = ""; then
+     EXSLT_DIR="/usr"
+  fi
+  test -f $EXSLT_DIR/include/libexslt/exslt.h && EXSLT_INCDIR="$EXSLT_DIR/include"
+  test -f $EXSLT_DIR/lib/libexslt.so && EXSLT_LIBDIR="$EXSLT_DIR/lib"
+  if test -n "$EXSLT_LIBDIR" -a -n "$EXSLT_INCDIR" ; then
+                EXSLT_ENABLED="-DUSE_EXSLT"
+    EXSLT_INC="-I$EXSLT_INCDIR"
+    EXSLT_LIB="-L$EXSLT_LIBDIR -lexslt"
+    echo "$as_me:$LINENO: result: using exslt from $EXSLT_LIB ($EXSLT_ENABLED)" >&5
+echo "${ECHO_T}using exslt from $EXSLT_LIB ($EXSLT_ENABLED)" >&6
+  if test ""$EXSLT_DIR"" != "/usr/lib"; then
+  if test -z ""$EXSLT_DIR"" || echo ""$EXSLT_DIR"" | grep '^/' >/dev/null ; then
+    ai_p=""$EXSLT_DIR""
+  else
+    ai_p="`pwd`/"$EXSLT_DIR""
+  fi
+  fi
+  fi
+  else
+    { { echo "$as_me:$LINENO: error: '$EXSLT_DIR' not a valid installation path of exslt." >&5
+echo "$as_me: error: '$EXSLT_DIR' not a valid installation path of exslt." >&2;}
+  fi
+fi
+EXSLT_ENABLED=$EXSLT_ENABLED
+EXSLT_INC=$EXSLT_INC
+EXSLT_LIB=$EXSLT_LIB
+ALL_ENABLED="$EXSLT_ENABLED $ALL_ENABLED"
+ALL_INC="$EXSLT_INC $ALL_INC"
+ALL_LIB="$EXSLT_LIB $ALL_LIB"
 echo "$as_me:$LINENO: checking if FriBidi support requested" >&5
 echo $ECHO_N "checking if FriBidi support requested... $ECHO_C" >&6
@@ -14116,6 +14362,12 @@
 s, at WMS_LYR_ENABLED@,$WMS_LYR_ENABLED,;t t
 s, at WFS_LYR_ENABLED@,$WFS_LYR_ENABLED,;t t
 s, at SOS_SVR_ENABLED@,$SOS_SVR_ENABLED,;t t
+s, at XSLT_ENABLED@,$XSLT_ENABLED,;t t
+s, at XSLT_INC@,$XSLT_INC,;t t
+s, at XSLT_LIB@,$XSLT_LIB,;t t
+s, at EXSLT_ENABLED@,$EXSLT_ENABLED,;t t
+s, at EXSLT_INC@,$EXSLT_INC,;t t
+s, at EXSLT_LIB@,$EXSLT_LIB,;t t
 s, at FRIBIDI_CONFIG@,$FRIBIDI_CONFIG,;t t
 s, at FRIBIDI_ENABLED@,$FRIBIDI_ENABLED,;t t
 s, at FRIBIDI_INC@,$FRIBIDI_INC,;t t
@@ -14480,6 +14732,12 @@
 echo "${ECHO_T}  Threading support:         ${THREAD_FLAG}" >&6
 echo "$as_me:$LINENO: result:   GEOS support:              ${GEOS_ENABLED}" >&5
 echo "${ECHO_T}  GEOS support:              ${GEOS_ENABLED}" >&6
+echo "$as_me:$LINENO: result:   XML Mapfile support:        ${XMLMAPFILE_ENABLED}" >&5
+echo "${ECHO_T}  XML Mapfile support:        ${XMLMAPFILE_ENABLED}" >&6
+echo "$as_me:$LINENO: result:   XSLT support:              ${XSLT_ENABLED}" >&5
+echo "${ECHO_T}  XSLT support:              ${XSLT_ENABLED}" >&6
+echo "$as_me:$LINENO: result:   EXSLT support:              ${EXSLT_ENABLED}" >&5
+echo "${ECHO_T}  EXSLT support:              ${EXSLT_ENABLED}" >&6
 echo "$as_me:$LINENO: result: " >&5
 echo "${ECHO_T}" >&6
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/configure.in	2010-02-22 15:05:01 UTC (rev 9858)
@@ -2042,7 +2042,118 @@
 ALL_ENABLED="$WMS_LYR_ENABLED $WFS_LYR_ENABLED $SOS_SVR_ENABLED $XML2_ENABLED $CURL_ENABLED $ALL_ENABLED"
+dnl ---------------------------------------------------------------------
+dnl Check if xml-mapfile requested
+AC_ARG_WITH(xml-mapfile,
+[  --with-xml-mapfile=                Include xml-mapfile Support (ARG=yes/no).],
+   XMLMAPFILE_REQUESTED="")
+AC_MSG_CHECKING(if xml-mapfile is requested)
+  AC_MSG_RESULT(yes.. xslt and exslt support needed)
+else
+  AC_MSG_RESULT(no)
+fi
+dnl Check if xslt requested
+AC_ARG_WITH(xslt,
+[  --with-xslt=DIR         Include xslt Support (ARG=yes/path to
+                          to xslt install dir).],
+    XSLT_DIR=$withval,XSLT_DIR='')
+AC_MSG_CHECKING(if xslt is requested)
+XSLT_LIB=''
+  AC_MSG_RESULT(no)
+else
+     XSLT_DIR="/usr"
+  fi
+    dnl
+    dnl Found xslt runtime and headers. Enable USE_XSLT .
+    dnl
+    AC_MSG_RESULT([using xslt from $XSLT_LIB ($XSLT_ENABLED)])
+    AC_ADD_RUNPATH("$XSLT_DIR")
+  else
+    AC_MSG_ERROR(['$XSLT_DIR' not a valid installation path of xslt.])
+  fi
+fi
+AC_SUBST(XSLT_ENABLED,$XSLT_ENABLED)
+AC_SUBST(XSLT_INC,    $XSLT_INC)
+AC_SUBST(XSLT_LIB,    $XSLT_LIB)
+dnl Check if exslt requested
+AC_ARG_WITH(exslt,
+[  --with-exslt=DIR         Include exslt Support (ARG=yes/path to
+                           to exslt install dir).],
+    EXSLT_DIR=$withval,EXSLT_DIR='')
+AC_MSG_CHECKING(if exslt is requested)
+EXSLT_LIB=''
+  AC_MSG_RESULT(no)
+else
+     EXSLT_DIR="/usr"
+  fi
+    dnl
+    dnl Found exslt runtime and headers. Enable USE_EXSLT .
+    dnl
+    AC_MSG_RESULT([using exslt from $EXSLT_LIB ($EXSLT_ENABLED)])
+    AC_ADD_RUNPATH("$EXSLT_DIR")
+  else
+    AC_MSG_ERROR(['$EXSLT_DIR' not a valid installation path of exslt.])
+  fi
+fi
+AC_SUBST(EXSLT_ENABLED,$EXSLT_ENABLED)
+AC_SUBST(EXSLT_INC,    $EXSLT_INC)
+AC_SUBST(EXSLT_LIB,    $EXSLT_LIB)
 dnl ---------------------------------------------------------------------------
 dnl Look for FriBidi if requested.
@@ -2755,6 +2866,9 @@
 AC_MSG_RESULT([  FastCGI support:           ${FASTCGI_ENABLED}])
 AC_MSG_RESULT([  Threading support:         ${THREAD_FLAG}])
 AC_MSG_RESULT([  GEOS support:              ${GEOS_ENABLED}])
+AC_MSG_RESULT([  XML Mapfile support:        ${XMLMAPFILE_ENABLED}])
+AC_MSG_RESULT([  XSLT support:              ${XSLT_ENABLED}])
+AC_MSG_RESULT([  EXSLT support:              ${EXSLT_ENABLED}])
 AC_MSG_RESULT()
 AC_MSG_RESULT([ -------------- Data Format Drivers ------- ])
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/mapfile.c	2010-02-22 15:05:01 UTC (rev 9858)
@@ -5236,7 +5236,7 @@
       return(NULL);
   ** Allocate mapObj structure
@@ -5252,12 +5252,37 @@
   msAcquireLock( TLOCK_PARSER );  /* Steve: might need to move this lock a bit higher; Umberto: done */
-  if((msyyin = fopen(filename,"r")) == NULL) {
-    msSetError(MS_IOERR, "(%s)", "msLoadMap()", filename);
-    msReleaseLock( TLOCK_PARSER );
-    return(NULL);
+#ifdef USE_XMLMAPFILE
+  /* If the mapfile is an xml mapfile, transform it */
+  if ((getenv("MS_XMLMAPFILE_XSLT")) &&
+      (msEvalRegex(MS_DEFAULT_XMLMAPFILE_PATTERN, filename) == MS_TRUE)) {
+      msyyin = tmpfile();
+      if (msyyin == NULL)
+          msSetError(MS_IOERR, "tmpfile() failed to create temporary file", "msLoadMap()");
+          msReleaseLock( TLOCK_PARSER );
+      if (msTransformXmlMapfile(getenv("MS_XMLMAPFILE_XSLT"), filename, msyyin) != MS_SUCCESS)
+          fclose(msyyin);
+          return NULL;
+      fseek ( msyyin , 0 , SEEK_SET );
+  else
+#endif
+      if((msyyin = fopen(filename,"r")) == NULL) {
+          msSetError(MS_IOERR, "(%s)", "msLoadMap()", filename);
+          return NULL;
+#endif
   msyystate = MS_TOKENIZE_FILE;
   msyylex(); /* sets things up, but doesn't process any tokens */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/mapserver.h	2010-02-22 15:05:01 UTC (rev 9858)
@@ -182,8 +182,12 @@
 /* General defines, not wrapable */
 #ifndef SWIG
+#define MS_DEFAULT_MAPFILE_PATTERN "\\.(map|xml)$"
+#define MS_DEFAULT_XMLMAPFILE_PATTERN "\\.xml$"
+#else
 #define MS_DEFAULT_MAPFILE_PATTERN "\\.map$"
+#endif
 #define MS_TEMPLATE_MAGIC_STRING "MapServer Template"
 #define MS_TEMPLATE_EXPR "\\.(xml|wml|html|htm|svg|kml|gml|js|tmpl)$"
@@ -1679,6 +1683,7 @@
 MS_DLL_EXPORT int msGetLayerIndex(mapObj *map, char *name);
 MS_DLL_EXPORT int msGetSymbolIndex(symbolSetObj *set, char *name, int try_addimage_if_notfound);
 MS_DLL_EXPORT mapObj  *msLoadMap(char *filename, char *new_mappath);
+MS_DLL_EXPORT int msTransformXmlMapfile(const char *stylesheet, const char *xmlMapfile, FILE *tmpfile);
 MS_DLL_EXPORT int msSaveMap(mapObj *map, char *filename);
 MS_DLL_EXPORT void msFreeCharArray(char **array, int num_items);
 MS_DLL_EXPORT int msUpdateScalebarFromString(scalebarObj *scalebar, char *string, int url_string);
Added: trunk/mapserver/mapxml.c
--- trunk/mapserver/mapxml.c	                        (rev 0)
+++ trunk/mapserver/mapxml.c	2010-02-22 15:05:01 UTC (rev 9858)
@@ -0,0 +1,91 @@
+ * $id: mapfile.c 7854 2008-08-14 19:22:48Z dmorissette $
+ * Project:  MapServer
+ * Purpose:  High level Map file parsing code.
+ * Author:   Steve Lime and the MapServer team.
+ * Copyright (c) 1996-2005 Regents of the University of Minnesota.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in
+ * all copies of this Software or works derived from this Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include "mapserver.h"
+#include <libxslt/xslt.h>
+#include "libexslt/exslt.h"
+#include <libxslt/transform.h>
+#include <libxslt/xsltInternals.h>
+#include <libxslt/extensions.h>
+#include <libxslt/xsltutils.h>
+extern int xmlLoadExtDtdDefaultValue;
+int msTransformXmlMapfile(const char *stylesheet, const char *xmlMapfile, FILE *tmpfile)
+    xsltStylesheetPtr cur = NULL;
+    int status = MS_FAILURE;
+    xmlDocPtr doc, res;
+    exsltRegisterAll();
+    xsltRegisterTestModule();
+    xmlSubstituteEntitiesDefault(1);
+    xmlLoadExtDtdDefaultValue = 1;
+    cur = xsltParseStylesheetFile((const xmlChar *)stylesheet);
+    if (cur == NULL)
+        msSetError(MS_MISCERR, "Failed to load xslt stylesheet", "msTransformXmlMapfile()");
+        goto done;
+    doc = xmlParseFile(xmlMapfile);
+    if (doc == NULL)
+        msSetError(MS_MISCERR, "Failed to load xml mapfile", "msTransformXmlMapfile()");
+        goto done;
+    res = xsltApplyStylesheet(cur, doc, NULL);
+    if (res == NULL)
+        msSetError(MS_MISCERR, "Failed to apply style sheet to %s", "msTransformXmlMapfile()", xmlMapfile);
+        goto done;
+    if ( xsltSaveResultToFile(tmpfile, res, cur) != -1 )
+        status =  MS_SUCCESS;
+done:
+    if (cur)
+        xsltFreeStylesheet(cur);
+    if (res)
+        xmlFreeDoc(res);
+    if (doc)
+        xmlFreeDoc(doc);
+    xsltCleanupGlobals();
+    xmlCleanupParser();
+    return status;
+#endif
Modified: trunk/mapserver/xmlmapfile/mapfile.xsl
--- trunk/mapserver/xmlmapfile/mapfile.xsl	2010-02-22 14:29:13 UTC (rev 9857)
+++ trunk/mapserver/xmlmapfile/mapfile.xsl	2010-02-22 15:05:01 UTC (rev 9858)
@@ -1282,7 +1282,7 @@
       <xsl:with-param name="indent" select="$indent + 1"/>
     </xsl:apply-templates>
     <xsl:call-template name="print">
-      <xsl:with-param name="text" select="'END'"/>
+      <xsl:with-param name="text" select="'END&#xa;'"/>
       <xsl:with-param name="indent" select="$indent - 1"/>
     </xsl:call-template>
   </xsl:template>
