[mapserver-commits] r9873 - trunk/mapserver
Tue Feb 23 00:06:43 EST 2010
Author: warmerdam
Date: 2010-02-23 00:06:40 -0500 (Tue, 23 Feb 2010)
New Revision: 9873
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapdraw.c
   trunk/mapserver/mapdrawgdal.c
   trunk/mapserver/mapraster.c
   trunk/mapserver/mapresample.c
   trunk/mapserver/mapresample.h
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapsvg.c
   trunk/mapserver/maputil.c
   trunk/mapserver/mapwcs.c
preliminary work on rendering plugin api rasters
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/HISTORY.TXT	2010-02-23 05:06:40 UTC (rev 9873)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Very preliminary render plugin support for raster rendering. (RFC 54)
 - support correct MIME type output for WFS 1.1.0 (#3295)
 - add WMS 1.3.0 LayerLimit support (#3284)
Modified: trunk/mapserver/mapdraw.c
--- trunk/mapserver/mapdraw.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapdraw.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1319,20 +1319,72 @@
+ * msDrawRasterLayerPlugin()
+static int
+msDrawRasterLayerPlugin( mapObj *map, layerObj *layer, imageObj *image)
+    rendererVTableObj *vtable = image->format->vtable;
+    if( vtable->supports_pixel_buffer )
+        rasterBufferObj  rb;
+        /* perhaps later there will be more formal initialization? */
+        memset( &rb, 0, sizeof(rb) );
+        vtable->getRasterBuffer( image, &rb );
+        return msDrawRasterLayerLow( map, layer, image, &rb );
+    else
+        return 0; /* not yet implemented */
+#ifdef notdef /* implement something like this */
+        int ret;
+        vtable->initializeRasterBuffer( &rb, image->width, image->height );
+        ret = msDrawRasterLayerLow( map, layer, image, &rb );
+        if( ret == 0 )
+            vtable->mergeRasterBuffer( image, &rb, 100.0, 0, 0 );
+        msFreeRasterBuffer( &rb );
+        return ret;
+#endif
  * Generic function to render raster layers.
 int msDrawRasterLayer(mapObj *map, layerObj *layer, imageObj *image)
     if (image && map && layer)
-        if( MS_RENDERER_GD(image->format) )
-            return msDrawRasterLayerLow(map, layer, image);
+        if( MS_RENDERER_PLUGIN(image->format) )
+            return msDrawRasterLayerPlugin(map, layer, image);
+        else if( MS_RENDERER_GD(image->format) )
+            return msDrawRasterLayerLow(map, layer, image, NULL);
 #ifdef USE_AGG
         else if( MS_RENDERER_AGG(image->format) )
 #endif
         else if( MS_RENDERER_RAWDATA(image->format) )
 #ifdef USE_MING_FLASH
         else if( MS_RENDERER_SWF(image->format) )
             return  msDrawRasterLayerSWF(map, layer, image);
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapdrawgdal.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -99,16 +99,43 @@
 #define RGB_LEVEL_INDEX(r,g,b) ((r)*GREEN_LEVELS*BLUE_LEVELS + (g)*BLUE_LEVELS+(b))
 #define RGB_INDEX(r,g,b) RGB_LEVEL_INDEX(((r)/RED_DIV),((g)/GREEN_DIV),((b)/BLUE_DIV))
+ * rasterBufferObj setting macros.
+#define RB_SET_PIXEL(rb,x,y,red,green,blue,alpha) \
+        int _rb_off = (x) * (rb)->pixel_step + (y) * (rb)->row_step;   \
+        (rb)->r[_rb_off] = red; \
+        (rb)->g[_rb_off] = green; \
+        (rb)->b[_rb_off] = blue; \
+        if( (rb)->a ) \
+            (rb)->a[_rb_off] = alpha; \
+#define RB_MIX_PIXEL(rb,x,y,red,green,blue,alpha) \
+        msAlphaBlend2( red, green, blue, alpha, \
+                       (rb)->r + _rb_off, \
+                       (rb)->g + _rb_off, \
+                       (rb)->b + _rb_off, \
+                       ((rb)->a == NULL ) ? NULL : (rb)->a + _rb_off );  \
 /*                       msDrawRasterLayerGDAL()                        */
 int msDrawRasterLayerGDAL(mapObj *map, layerObj *layer, imageObj *image,
-                          void *hDSVoid )
+                          rasterBufferObj *rb, void *hDSVoid )
   int i,j, k; /* loop counters */
   int cmap[MAXCOLORS], cmap_set = FALSE;
+  unsigned char rb_cmap[4][MAXCOLORS], rb_cmap_set = FALSE;
   double adfGeoTransform[6], adfInvGeoTransform[6];
   int	dst_xoff, dst_yoff, dst_xsize, dst_ysize;
   int	src_xoff, src_yoff, src_xsize, src_ysize;
@@ -124,7 +151,9 @@
   GDALDatasetH hDS = hDSVoid;
   GDALColorTableH hColorMap;
   GDALRasterBandH hBand1=NULL, hBand2=NULL, hBand3=NULL, hBandAlpha=NULL;
   memset( cmap, 0xff, MAXCOLORS * sizeof(int) );
+  memset( rb_cmap, 0, sizeof(rb_cmap) );
 /*      Test the image format instead of the map format.                */
@@ -147,6 +176,11 @@
                                               "COLOR_MATCH_THRESHOLD" )));
+  else if( MS_RENDERER_PLUGIN(image->format) )
+      assert( rb != NULL );
+      truecolor = TRUE;
 #ifdef USE_AGG
@@ -313,15 +347,15 @@
    * In RAWDATA mode we don't fool with colors.  Do the raw processing,
    * and return from the function early.
-  if( !gdImg )
+  if( MS_RENDERER_RAWDATA( image->format ) )
-      assert( MS_RENDERER_RAWDATA( image->format ) );
       return msDrawRasterLayerGDAL_RawMode(
           map, layer, image, hDS,
           src_xoff, src_yoff, src_xsize, src_ysize,
           dst_xoff, dst_yoff, dst_xsize, dst_ysize );
+  assert( gdImg != NULL || rb != NULL );
    * Is this image classified?  We consider it classified if there are
@@ -579,10 +613,13 @@
    * class colors are provided by the MAP file, or where we use the native
    * color table.
-  if( classified && gdImg ) {
+  if( classified ) {
     int c, color_count;
-    cmap_set = TRUE;
+    if( gdImg )
+        cmap_set = TRUE;
+    else if( rb )
+        rb_cmap_set = TRUE;
     if( hColorMap == NULL )
@@ -609,7 +646,10 @@
             c = msGetClass(layer, &pixel);
             if(c == -1)/* doesn't belong to any class, so handle like offsite*/
-                cmap[i] = -1;
+                if( gdImg )
+                    cmap[i] = -1;
             else
                 int s;
@@ -625,20 +665,46 @@
                                        sEntry.c1 );
-                RESOLVE_PEN_GD(gdImg, layer->class[c]->styles[0]->color);
-                if( MS_TRANSPARENT_COLOR(layer->class[c]->styles[0]->color) )
-                    cmap[i] = -1;
-                else if( MS_VALID_COLOR(layer->class[c]->styles[0]->color))
+                if( gdImg )
-                    /* use class color */
-                    cmap[i] = layer->class[c]->styles[0]->color.pen;
+                    RESOLVE_PEN_GD(gdImg, layer->class[c]->styles[0]->color);
+                    if( MS_TRANSPARENT_COLOR(layer->class[c]->styles[0]->color) )
+                        cmap[i] = -1;
+                    else if( MS_VALID_COLOR(layer->class[c]->styles[0]->color))
+                        /* use class color */
+                        cmap[i] = layer->class[c]->styles[0]->color.pen;
+                    else /* Use raster color */
+                        cmap[i] = msAddColorGD(map, gdImg, cmt,
+                                               pixel.red, pixel.green, pixel.blue);
-                else /* Use raster color */
-                    cmap[i] = msAddColorGD(map, gdImg, cmt,
-                                           pixel.red, pixel.green, pixel.blue);
+                else if( rb )
+                    if( MS_TRANSPARENT_COLOR(layer->class[c]->styles[0]->color))
+                        /* leave it transparent */;
+                        rb_cmap[0][i] = layer->class[c]->styles[0]->color.red;
+                        rb_cmap[1][i] = layer->class[c]->styles[0]->color.green;
+                        rb_cmap[2][i] = layer->class[c]->styles[0]->color.blue;
+                        rb_cmap[3][i] = 255;
+                        rb_cmap[0][i] = pixel.red;
+                        rb_cmap[1][i] = pixel.green;
+                        rb_cmap[2][i] = pixel.blue;
-        } else
-            cmap[i] = -1;
+        } else {
+            if( gdImg )
+                cmap[i] = -1;
   } else if( hColorMap != NULL && !truecolor && gdImg ) {
     int color_count;
@@ -662,7 +728,7 @@
             cmap[i] = -1;
-  else if( hBand2 == NULL && hColorMap != NULL )
+  else if( hBand2 == NULL && hColorMap != NULL && gdImg )
       int color_count;
       cmap_set = TRUE;
@@ -685,6 +751,31 @@
               cmap[i] = -1;
+  else if( hBand2 == NULL && hColorMap != NULL && rb )
+      int color_count;
+      color_count = MIN(256,GDALGetColorEntryCount(hColorMap));
+      for(i=0; i < color_count; i++) {
+          GDALColorEntry sEntry;
+          GDALGetColorEntryAsRGB( hColorMap, i, &sEntry );
+          if( sEntry.c4 != 0
+              && (!MS_VALID_COLOR( layer->offsite )
+                  || layer->offsite.red != sEntry.c1
+                  || layer->offsite.green != sEntry.c2
+                  || layer->offsite.blue != sEntry.c3 ) )
+              rb_cmap[0][i] = sEntry.c1;
+              rb_cmap[1][i] = sEntry.c2;
+              rb_cmap[2][i] = sEntry.c3;
+              rb_cmap[3][i] = sEntry.c4;
   else if( !truecolor && gdImg )
       allocColorCube( map, gdImg, anColorCube );
@@ -790,7 +881,7 @@
-/*      Single band plus colormap and alpha to truecolor.               */
+/*      Single band plus colormap and alpha to truecolor. (GD)          */
   else if( hBand2 == NULL && truecolor && gdImg && hBandAlpha != NULL )
@@ -822,8 +913,51 @@
-/*      Single band plus colormap (no alpha) to truecolor               */
+/*      Single band plus colormap and alpha to truecolor. (RB)          */
+  else if( hBand2 == NULL && truecolor && rb && hBandAlpha != NULL )
+      assert( rb_cmap_set );
+      k = 0;
+      for( i = dst_yoff; i < dst_yoff + dst_ysize; i++ )
+          for( j = dst_xoff; j < dst_xoff + dst_xsize; j++ )
+              int	src_pixel, src_alpha, cmap_alpha, merged_alpha;
+              src_alpha = pabyRawAlpha[k];
+              cmap_alpha = rb_cmap[3][k];
+              merged_alpha = (src_alpha * cmap_alpha) / 256;
+              src_pixel = pabyRaw1[k];
+              if( merged_alpha < 2 )
+                  /* do nothing - transparent */;
+              else if( merged_alpha > 253 )
+                  RB_SET_PIXEL( rb, j, i,
+                                rb_cmap[0][src_pixel],
+                                rb_cmap[1][src_pixel],
+                                rb_cmap[2][src_pixel],
+                                cmap_alpha );
+              else
+                  RB_MIX_PIXEL( rb, j, i,
+                                merged_alpha );
+              k++;
+/*      Single band plus colormap (no alpha) to truecolor (GD)          */
   else if( hBand2 == NULL && truecolor && gdImg )
       assert( cmap_set );
@@ -843,10 +977,82 @@
+/*      Single band plus colormap (no alpha) to truecolor (RB)          */
+  else if( hBand2 == NULL && truecolor && rb )
+      k = 0;
+              int src_pixel = pabyRaw1[k++];
+              if( rb_cmap[3][src_pixel] > 253 )
+                                rb_cmap[3][src_pixel] );
+              else if( rb_cmap[3][src_pixel] > 1 )
 /*      Input is 3 band RGB.  Alpha blending is mixed into the loop     */
 /*      since this case is less commonly used and has lots of other     */
-/*      overhead.                                                       */
+/*      overhead. (RB)                                                  */
+  else if( hBand3 != NULL && rb )
+      k = 0;
+          for( j = dst_xoff; j < dst_xoff + dst_xsize; j++, k++ )
+              if( MS_VALID_COLOR( layer->offsite )
+                  && pabyRaw1[k] == layer->offsite.red
+                  && pabyRaw2[k] == layer->offsite.green
+                  && pabyRaw3[k] == layer->offsite.blue )
+                  continue;
+              if( pabyRawAlpha == NULL || pabyRawAlpha[k] == 255 )
+                                pabyRaw1[k],
+                                pabyRaw2[k],
+                                pabyRaw3[k],
+                                255 );
+              else if( pabyRawAlpha[k] != 0 )
+                                pabyRaw1[k],
+                                pabyRaw2[k],
+                                pabyRaw3[k],
+                                pabyRawAlpha[k] );
+/*      Input is 3 band RGB.  Alpha blending is mixed into the loop     */
+/*      since this case is less commonly used and has lots of other     */
+/*      overhead. (GD)                                                  */
   else if( hBand3 != NULL && gdImg )
       /* Dithered 24bit to 8bit conversion */
Modified: trunk/mapserver/mapraster.c
--- trunk/mapserver/mapraster.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapraster.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1194,7 +1194,8 @@
 /*      tile indexing.                                                  */
-int msDrawRasterLayerLow(mapObj *map, layerObj *layer, imageObj *image)
+int msDrawRasterLayerLow(mapObj *map, layerObj *layer, imageObj *image,
+                         rasterBufferObj *rb )
   int status, i, done;
   FILE *f;
@@ -1575,7 +1576,7 @@
                                         &(layer->projection) )
                 || CSLFetchNameValue( layer->processing, "RESAMPLE" ) != NULL )
-                status = msResampleGDALToMap( map, layer, image, hDS );
+                status = msResampleGDALToMap( map, layer, image, rb, hDS );
             else
 #endif
@@ -1590,7 +1591,7 @@
                             layer->name );
-                status = msDrawRasterLayerGDAL(map, layer, image, hDS );
+                status = msDrawRasterLayerGDAL(map, layer, image, rb, hDS );
             if( status == -1 )
Modified: trunk/mapserver/mapresample.c
--- trunk/mapserver/mapresample.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapresample.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1309,7 +1309,7 @@
 int msResampleGDALToMap( mapObj *map, layerObj *layer, imageObj *image,
-                         GDALDatasetH hDS )
+                         rasterBufferObj *rb, GDALDatasetH hDS )
@@ -1579,7 +1579,8 @@
         layer->processing = papszAlteredProcessing;
-        result = msDrawRasterLayerGDAL( &sDummyMap, layer, srcImage, hDS );
+        result = msDrawRasterLayerGDAL( &sDummyMap, layer, srcImage,
+                                        NULL, hDS );
         layer->processing = papszSavedProcessing;
         CSLDestroy( papszAlteredProcessing );
Modified: trunk/mapserver/mapresample.h
--- trunk/mapserver/mapresample.h	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapresample.h	2010-02-23 05:06:40 UTC (rev 9873)
@@ -51,7 +51,7 @@
                        double *x, double *y, int *panSuccess );
 #ifdef USE_GDAL
-                         imageObj *image,
+                         imageObj *image, rasterBufferObj *rb,
                          GDALDatasetH hDS );
 #endif
 #endif /* ndef RESAMPLE_H */
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapserver.h	2010-02-23 05:06:40 UTC (rev 9873)
@@ -2152,7 +2152,7 @@
 MS_DLL_EXPORT int msJoinClose(joinObj *join);
 /*in mapraster.c */
-MS_DLL_EXPORT int msDrawRasterLayerLow(mapObj *map, layerObj *layer, imageObj *image);
+MS_DLL_EXPORT int msDrawRasterLayerLow(mapObj *map, layerObj *layer, imageObj *image, rasterBufferObj *rb );
 MS_DLL_EXPORT int msAddColorGD(mapObj *map, gdImagePtr img, int cmt, int r, int g, int b);
 #ifdef USE_AGG
 MS_DLL_EXPORT int msAddColorAGG(mapObj *map, gdImagePtr img, int cmt, int r, int g, int b);
@@ -2161,7 +2161,7 @@
 MS_DLL_EXPORT int msGetClass_Float(layerObj *layer, float fValue);
 /* in mapdrawgdal.c */
-MS_DLL_EXPORT int msDrawRasterLayerGDAL(mapObj *map, layerObj *layer, imageObj *image, void *hDSVoid );
+MS_DLL_EXPORT int msDrawRasterLayerGDAL(mapObj *map, layerObj *layer, imageObj *image, rasterBufferObj *rb, void *hDSVoid );
 MS_DLL_EXPORT int msGetGDALGeoTransform(void *hDS, mapObj *map, layerObj *layer, double *padfGeoTransform );
 MS_DLL_EXPORT int *msGetGDALBandList( layerObj *layer, void *hDS, int max_bands, int *band_count );
 MS_DLL_EXPORT double msGetGDALNoDataValue( layerObj *layer, void *hBand, int *pbGotNoData );
@@ -2227,6 +2227,11 @@
 MS_DLL_EXPORT imageObj *msImageCreate(int width, int height, outputFormatObj *format, char *imagepath, char *imageurl, mapObj *map);
 MS_DLL_EXPORT int msAlphaBlend (int dst, int src);
+MS_DLL_EXPORT void msAlphaBlend2(
+    int red_src, int green_src,
+    int blue_src, int alpha_src,
+    unsigned char *red_dst, unsigned char *green_dst,
+    unsigned char *blue_dst, unsigned char *alpha_dst );
 MS_DLL_EXPORT int msCheckParentPointer(void* p, char* objname);
Modified: trunk/mapserver/mapsvg.c
--- trunk/mapserver/mapsvg.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapsvg.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1789,7 +1789,7 @@
     /* TODO : msDrawRasterLayerLow returns 0 (ms_success) in some cases */
     /* without drawing anything (ex : if it does not fit in scale) */
-    if (msDrawRasterLayerLow(map, layer, imagetmp) != MS_FAILURE)
+    if (msDrawRasterLayerLow(map, layer, imagetmp, NULL) != MS_FAILURE)
         pszTmpfile = msTmpFile(map->mappath,map->web.imagepath,format->extension);
         if (!pszTmpfile)
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/maputil.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1851,6 +1851,65 @@
     return ((alpha << 24) + (red << 16) + (green << 8) + blue);
+/*                           msAlphaBlend2()                            */
+/*      Function to overlay/blend an RGBA value into an existing        */
+/*      RGBA value.  Primarily intended for use with rasterBufferObj    */
+/*      raster rendering.  The "src" is the overlay value, and "dst"    */
+/*      is the existing value being overlaid.                           */
+/*      NOTE: alpha_dst may be NULL.                                    */
+void msAlphaBlend2( int red_src, int green_src,
+    int src_weight, dst_weight, tot_weight;
+/*      Simple cases we want to handle fast.                            */
+    if( alpha_src < 2 )
+        return;
+    if( alpha_src > 253 || (alpha_dst && *alpha_dst < 2) )
+        *red_dst = red_src;
+        *green_dst = green_src;
+        *blue_dst = blue_src;
+        *alpha_dst = alpha_src;
+        return;
+/*      What will the source and destination alphas be?  Note that      */
+/*      the destination weighting is substantially reduced as the       */
+/*      overlay becomes quite opaque.                                   */
+    src_weight = alpha_src;
+    if( alpha_dst )
+        dst_weight = *alpha_dst * (255-alpha_src) / 255;
+    else
+        dst_weight = 255 - alpha_src;
+    tot_weight = src_weight + dst_weight;
+/*      What red, green and blue result values will we use?             */
+    if( alpha_dst != NULL )
+        *alpha_dst = tot_weight;
+    *red_dst   = ((src_weight * *red_dst  ) + (dst_weight * red_src  ))
+        / tot_weight;
+    *green_dst = ((src_weight * *green_dst) + (dst_weight * green_src))
+        / tot_weight;
+    *blue_dst  = ((src_weight * *blue_dst ) + (dst_weight * blue_src ))
+        / tot_weight;
  RFC 24: check if the parent pointer is NULL and raise an error otherwise
Modified: trunk/mapserver/mapwcs.c
--- trunk/mapserver/mapwcs.c	2010-02-23 01:18:49 UTC (rev 9872)
+++ trunk/mapserver/mapwcs.c	2010-02-23 05:06:40 UTC (rev 9873)
@@ -1750,7 +1750,7 @@
       return msWCSException(map, NULL, NULL, params->version );
   /* Actually produce the "grid". */
-  status = msDrawRasterLayerLow( map, lp, image );
+  status = msDrawRasterLayerLow( map, lp, image, NULL );
   if( status != MS_SUCCESS ) {
