[mapserver-commits] r9881 - trunk/mapserver
Tue Feb 23 11:36:12 EST 2010
Author: sdlime
Date: 2010-02-23 11:36:12 -0500 (Tue, 23 Feb 2010)
New Revision: 9881
   trunk/mapserver/mapoutput.c
   trunk/mapserver/mapserver.h
Added references to gd2 output format.
Modified: trunk/mapserver/mapoutput.c
--- trunk/mapserver/mapoutput.c	2010-02-23 16:21:17 UTC (rev 9880)
+++ trunk/mapserver/mapoutput.c	2010-02-23 16:36:12 UTC (rev 9881)
@@ -1,3 +1,4 @@
  * $Id$
@@ -152,6 +153,14 @@
         format->extension = strdup("gif");
         format->renderer = MS_RENDER_WITH_GD;
+    if( strcasecmp(driver,"GD2/GIF") == 0 )
+        format = msAllocOutputFormat( map, "gif2", driver );
+        format->mimetype = strdup("image/gif");
+        format->imagemode = MS_IMAGEMODE_PC256;
+        format->extension = strdup("gif");
+        format->renderer = MS_RENDER_WITH_GD2;
 #endif
 #ifdef USE_GD_PNG
@@ -163,9 +172,16 @@
         format->extension = strdup("png");
+    if( strcasecmp(driver,"GD2/PNG") == 0 )
+        format = msAllocOutputFormat( map, "png2", driver );
+        format->mimetype = strdup("image/png");
+        format->extension = strdup("png");
 #endif /* USE_GD_PNG */
 #if defined(USE_GD_PNG) && GD2_VERS > 1
     if( strcasecmp(driver,"GD/PNG24") == 0 )
@@ -186,6 +202,14 @@
         format->extension = strdup("jpg");
+    if( strcasecmp(driver,"GD2/JPEG") == 0 )
+        format = msAllocOutputFormat( map, "jpeg2", driver );
+        format->mimetype = strdup("image/jpeg");
+        format->imagemode = MS_IMAGEMODE_PC256; // ???
+        format->extension = strdup("jpg");
 #endif
 #ifdef USE_GD_WBMP
     if( strcasecmp(driver,"GD/WBMP") == 0 )
@@ -373,15 +397,21 @@
     if( msSelectOutputFormat( map, "gif" ) == NULL )
         msCreateDefaultOutputFormat( map, "GD/GIF" );
+    if( msSelectOutputFormat( map, "gif2" ) == NULL )
+        msCreateDefaultOutputFormat( map, "GD2/GIF" );
     if( msSelectOutputFormat( map, "png" ) == NULL )
         msCreateDefaultOutputFormat( map, "GD/PNG" );
+    if( msSelectOutputFormat( map, "png2" ) == NULL )
+        msCreateDefaultOutputFormat( map, "GD2/PNG" );
     if( msSelectOutputFormat( map, "png24" ) == NULL )
         msCreateDefaultOutputFormat( map, "GD/PNG24" );
     if( msSelectOutputFormat( map, "jpeg" ) == NULL )
         msCreateDefaultOutputFormat( map, "GD/JPEG" );
+    if( msSelectOutputFormat( map, "jpeg2" ) == NULL )
+        msCreateDefaultOutputFormat( map, "GD2/JPEG" );
     if( msSelectOutputFormat( map, "wbmp" ) == NULL )
         msCreateDefaultOutputFormat( map, "GD/WBMP" );
@@ -1065,6 +1095,8 @@
     switch(format->renderer) {
         case MS_RENDER_WITH_AGG2:
             return msPopulateRendererVTableAGG(format->vtable);
+        case MS_RENDER_WITH_GD2:
+            return msPopulateRendererVTableGD(format->vtable);
         case MS_RENDER_WITH_CAIRO_RASTER:
             return msPopulateRendererVTableCairoRaster(format->vtable);
         case MS_RENDER_WITH_CAIRO_PDF:
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-02-23 16:21:17 UTC (rev 9880)
+++ trunk/mapserver/mapserver.h	2010-02-23 16:36:12 UTC (rev 9881)
@@ -323,6 +323,7 @@
 #define MS_IMAGE_EXTENSION(format)  (format->extension ? format->extension : "unknown")
 #define MS_DRIVER_GD(format)  (strncasecmp((format)->driver,"gd/",3)==0)
+#define MS_DRIVER_GD2(format)  (strncasecmp((format)->driver,"gd2/",4)==0)
 #define MS_DRIVER_SWF(format) (strncasecmp((format)->driver,"swf",3)==0)
 #define MS_DRIVER_GDAL(format)  (strncasecmp((format)->driver,"gdal/",5)==0)
 #define MS_DRIVER_PDF(format) (strncasecmp((format)->driver,"pdf",3)==0)
@@ -347,6 +348,7 @@
 #define MS_RENDER_WITH_CAIRO_SVG 11
 #define MS_RENDER_WITH_OGL      12
 #define MS_RENDER_WITH_AGG2 13
+#define MS_RENDER_WITH_GD2 14
 #define MS_RENDERER_GD(format)  ((format)->renderer == MS_RENDER_WITH_GD)
 #define MS_RENDERER_SWF(format) ((format)->renderer == MS_RENDER_WITH_SWF)
@@ -2621,6 +2623,7 @@
 MS_DLL_EXPORT int msPopulateRendererVTableCairoPDF( rendererVTableObj *renderer );
 MS_DLL_EXPORT int msPopulateRendererVTableOGL( rendererVTableObj *renderer );
 MS_DLL_EXPORT int msPopulateRendererVTableAGG( rendererVTableObj *renderer );
+MS_DLL_EXPORT int msPopulateRendererVTableGD( rendererVTableObj *renderer );
 //allocate 50k for starters
 #define MS_DEFAULT_BUFFER_ALLOC 50000
