[mapserver-commits] r9887 - branches/branch-5-6/mapserver
Tue Feb 23 14:30:58 EST 2010
Author: assefa
Date: 2010-02-23 14:30:57 -0500 (Tue, 23 Feb 2010)
New Revision: 9887
   branches/branch-5-6/mapserver/HISTORY.TXT
   branches/branch-5-6/mapserver/mapdraw.c
   branches/branch-5-6/mapserver/mapfile.c
   branches/branch-5-6/mapserver/mapgml.c
   branches/branch-5-6/mapserver/mapogcfilter.c
   branches/branch-5-6/mapserver/mapows.h
   branches/branch-5-6/mapserver/mappostgis.c
   branches/branch-5-6/mapserver/mapquery.c
   branches/branch-5-6/mapserver/mapserver.h
   branches/branch-5-6/mapserver/mapwfs.c
issues with one pass query and flters #3305 #3346
Modified: branches/branch-5-6/mapserver/HISTORY.TXT
--- branches/branch-5-6/mapserver/HISTORY.TXT	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/HISTORY.TXT	2010-02-23 19:30:57 UTC (rev 9887)
@@ -27,7 +27,14 @@
 - Got rid of invalid warning about missing EPSG proj in WMs GetCapabilities
   when map has a valid EPSG proj, but layer doesn't (#2028)
+Current Version
+- Correct one pass query problems and OGC filter query (#3305)
+- Correct QueryByOperator (#3346)
 Version 5.6.1 (2010-01-08):
Modified: branches/branch-5-6/mapserver/mapdraw.c
--- branches/branch-5-6/mapserver/mapdraw.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapdraw.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -1212,7 +1212,10 @@
   msInitShape(&shape);
   for(i=0; i<layer->resultcache->numresults; i++) {
-    status = msLayerResultsGetShape(layer, &shape, layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+    if(layer->resultcache->usegetshape)
+       status = msLayerGetShape(layer, &shape, layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
+    else
+      status = msLayerResultsGetShape(layer, &shape, layer->resultcache->results[i].tileindex, layer->resultcache->results[i].shapeindex);
     if(status != MS_SUCCESS) {
         msFree(colorbuffer);
         msFree(mindistancebuffer);
Modified: branches/branch-5-6/mapserver/mapfile.c
--- branches/branch-5-6/mapserver/mapfile.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapfile.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -5616,3 +5616,14 @@
+void initResultCache(resultCacheObj *resultcache)
+    if (resultcache)
+        resultcache->results = NULL;
+        resultcache->numresults = 0;
+        resultcache->cachesize = 0;
+        resultcache->bounds.minx = resultcache->bounds.miny = resultcache->bounds.maxx = resultcache->bounds.maxy = -1;
+        resultcache->usegetshape = MS_FALSE;
Modified: branches/branch-5-6/mapserver/mapgml.c
--- branches/branch-5-6/mapserver/mapgml.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapgml.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -1413,8 +1413,11 @@
 ** msGMLWriteWFSQuery()
 ** Similar to msGMLWriteQuery() but tuned for use with WFS 1.0.0
+** bUseGetShape is used when the query passed through a commplex filter
+** encoding #3305
-int msGMLWriteWFSQuery(mapObj *map, FILE *stream, int maxfeatures, char *default_namespace_prefix, int outputformat)
+int msGMLWriteWFSQuery(mapObj *map, FILE *stream, int maxfeatures, char *default_namespace_prefix,
+                       int outputformat, int bUseGetShape)
 #ifdef USE_WFS_SVR
   int status;
@@ -1510,7 +1513,11 @@
       for(j=0; j<lp->resultcache->numresults; j++) {
-        status = msLayerResultsGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+        if (bUseGetShape)
+          status = msLayerGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
+        else
+          status =  msLayerResultsGetShape(lp, &shape, lp->resultcache->results[j].tileindex, lp->resultcache->results[j].shapeindex);
             return(status);
Modified: branches/branch-5-6/mapserver/mapogcfilter.c
--- branches/branch-5-6/mapserver/mapogcfilter.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapogcfilter.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -633,14 +633,11 @@
     psLayer->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj));
+    initResultCache(psLayer->resultcache);
-    psLayer->resultcache->results = NULL;
-    psLayer->resultcache->numresults =  0;
-    psLayer->resultcache->cachesize = 0;
-    psLayer->resultcache->bounds.minx = -1;
-    psLayer->resultcache->bounds.miny = -1;
-    psLayer->resultcache->bounds.maxx = -1;
-    psLayer->resultcache->bounds.maxy = -1;
+    /*this will force the queries to retrive the shapes using
+     their unique id #3305*/
+    psLayer->resultcache->usegetshape = MS_TRUE;
     status = msLayerOpen(psLayer);
@@ -662,7 +659,8 @@
     for (i=0; i<nSize; i++)
-        status = msLayerResultsGetShape(psLayer, &shape, -1, anValues[i]);
+        /*status = msLayerResultsGetShape(psLayer, &shape, -1, anValues[i]);*/
+        status = msLayerGetShape(psLayer, &shape, -1, anValues[i]);
         if (status != MS_SUCCESS)
           nClassIndex = -1;
Modified: branches/branch-5-6/mapserver/mapows.h
--- branches/branch-5-6/mapserver/mapows.h	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapows.h	2010-02-23 19:30:57 UTC (rev 9887)
@@ -399,7 +399,8 @@
 #ifdef USE_WFS_SVR
-MS_DLL_EXPORT int msGMLWriteWFSQuery(mapObj *map, FILE *stream, int maxfeatures, char *wfs_namespace, int outputformat);
+MS_DLL_EXPORT int msGMLWriteWFSQuery(mapObj *map, FILE *stream, int maxfeatures, char *wfs_namespace,
+                                     int outputformat,  int bUseGetShape);
 #endif
Modified: branches/branch-5-6/mapserver/mappostgis.c
--- branches/branch-5-6/mapserver/mappostgis.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mappostgis.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -1363,7 +1363,7 @@
-int msPostGISReadShape(layerObj *layer, shapeObj *shape, int random) {
+int msPostGISReadShape(layerObj *layer, shapeObj *shape) {
     char *wkbstr = NULL;
     unsigned char *wkb = NULL;
@@ -1461,26 +1461,21 @@
-        if( random ) {
-            /* t is the geometry, t+1 is the uid */
-            tmp = PQgetvalue(layerinfo->pgresult, layerinfo->rownum, t + 1);
-            if( tmp ) {
-                uid = strtol( tmp, NULL, 10 );
-            else {
-                uid = 0;
-            if( layer->debug > 4 ) {
-                msDebug("msPostGISReadShape: Setting shape->index = %d\n", uid);
-            shape->index = uid;
-        } else {
-                msDebug("msPostGISReadShape: Setting shape->index = %d\n", layerinfo->rownum);
-            shape->index = layerinfo->rownum;
+        /* t is the geometry, t+1 is the uid */
+        tmp = PQgetvalue(layerinfo->pgresult, layerinfo->rownum, t + 1);
+        if( tmp ) {
+            uid = strtol( tmp, NULL, 10 );
+        else {
+            uid = 0;
+        if( layer->debug > 4 ) {
+            msDebug("msPostGISReadShape: Setting shape->index = %d\n", uid);
+            msDebug("msPostGISReadShape: Setting shape->tileindex = %d\n", layerinfo->rownum);
+        shape->index = uid;
+        shape->tileindex = layerinfo->rownum;
         if( layer->debug > 2 ) {
             msDebug("msPostGISReadShape: [index] %d\n",  shape->index);
@@ -1845,7 +1840,7 @@
         if (layerinfo->rownum < PQntuples(layerinfo->pgresult)) {
             int rv;
             /* Retrieve this shape, cursor access mode. */
-            rv = msPostGISReadShape(layer, shape, 0);
+            rv = msPostGISReadShape(layer, shape);
             if( shape->type != MS_SHAPE_NULL ) {
                 (layerinfo->rownum)++; /* move to next shape */
                 return MS_SUCCESS;
@@ -1887,9 +1882,14 @@
     assert(layer->layerinfo != NULL);
     if (layer->debug) {
-        msDebug("msPostGISLayerGetShape called for record = %i\n", record);
+        msDebug("msPostGISLayerResultsGetShape called for record = %i\n", record);
+    if( tile < 0 ) {
+        return msPostGISLayerResultsGetShape(layer, shape, tile, record);
     layerinfo = (msPostGISLayerInfo*) layer->layerinfo;
     /* Check the validity of the open result. */
@@ -1912,21 +1912,21 @@
     /* Check the validity of the requested record number. */
-    if( record >= PQntuples(pgresult) ) {
-        msDebug("msPostGISLayerResultsGetShape got record request (%d) but only has %d tuples.\n", record, PQntuples(pgresult));
+    if( tile >= PQntuples(pgresult) ) {
+        msDebug("msPostGISLayerResultsGetShape got request for (%d) but only has %d tuples.\n", tile, PQntuples(pgresult));
         msSetError( MS_MISCERR,
                     "Got request larger than result set.",
                     "msPostGISLayerResultsGetShape()");
         return MS_FAILURE;
-    layerinfo->rownum = record; /* Only return one result. */
+    layerinfo->rownum = tile; /* Only return one result. */
     /* We don't know the shape type until we read the geometry. */
     shape->type = MS_SHAPE_NULL;
 	/* Return the shape, cursor access mode. */
-    result = msPostGISReadShape(layer, shape, 0);
+    result = msPostGISReadShape(layer, shape);
     return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : MS_SUCCESS;
 #else
@@ -2013,7 +2013,7 @@
     if (num_tuples > 0) {
         /* Get shape in random access mode. */
-        result = msPostGISReadShape(layer, shape, 1);
     return (shape->type == MS_SHAPE_NULL) ? MS_FAILURE : ( (num_tuples > 0) ? MS_SUCCESS : MS_DONE );
Modified: branches/branch-5-6/mapserver/mapquery.c
--- branches/branch-5-6/mapserver/mapquery.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapquery.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -362,9 +362,7 @@
   if(map->query.clear_resultcache || lp->resultcache == NULL) {
     lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /* allocate and initialize the result cache */
-    lp->resultcache->results = NULL;
-    lp->resultcache->numresults = lp->resultcache->cachesize = 0;
-    lp->resultcache->bounds.minx = lp->resultcache->bounds.miny = lp->resultcache->bounds.maxx = lp->resultcache->bounds.maxy = -1;
+    initResultCache( lp->resultcache);
@@ -521,9 +519,7 @@
   nclasses = 0;
   classgroup = NULL;
@@ -674,9 +670,7 @@
     nclasses = 0;
     classgroup = NULL;
@@ -908,9 +902,7 @@
       if(i == 0) {
       nclasses = 0;
@@ -1166,9 +1158,7 @@
     nclasses = 0;
     classgroup = NULL;
@@ -1357,9 +1347,7 @@
     nclasses = 0;
     classgroup = NULL;
@@ -1528,11 +1516,8 @@
     if(status != MS_SUCCESS) return(MS_FAILURE);
     /* identify target shapes */
-    searchrect.minx = map->extent.minx;
-    searchrect.miny = map->extent.miny;
-    searchrect.maxx = map->extent.maxx;
-    searchrect.maxy = map->extent.maxy;
+    searchrect = qshape->bounds;
 #ifdef USE_PROJ
     if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
       msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
@@ -1549,9 +1534,7 @@
     classgroup = NULL;
     if (lp->classgroup && lp->numclasses > 0)
Modified: branches/branch-5-6/mapserver/mapserver.h
--- branches/branch-5-6/mapserver/mapserver.h	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapserver.h	2010-02-23 19:30:57 UTC (rev 9887)
@@ -997,6 +997,9 @@
 %mutable;
 #endif /* SWIG */
+  /*used to force the result retreiving to use getshape instead of msLayerResultGetShape #3305*/
+  int usegetshape;
 } resultCacheObj;
@@ -1599,6 +1602,7 @@
 MS_DLL_EXPORT void initGrid( graticuleObj *pGraticule );
 MS_DLL_EXPORT void initWeb(webObj *web);
 MS_DLL_EXPORT void freeWeb(webObj *web);
+MS_DLL_EXPORT void initResultCache(resultCacheObj *resultcache);
 MS_DLL_EXPORT featureListNodeObjPtr insertFeatureList(featureListNodeObjPtr *list, shapeObj *shape);
 MS_DLL_EXPORT void freeFeatureList(featureListNodeObjPtr list);
Modified: branches/branch-5-6/mapserver/mapwfs.c
--- branches/branch-5-6/mapserver/mapwfs.c	2010-02-23 18:28:46 UTC (rev 9886)
+++ branches/branch-5-6/mapserver/mapwfs.c	2010-02-23 19:30:57 UTC (rev 9887)
@@ -1025,9 +1025,13 @@
   char **papszPropertyName = NULL;
   int nPropertyNames = 0;
+  /*use msLayerGetShape instead of msLayerResultsGetShape of complex filter #3305*/
+  int bUseGetShape = MS_FALSE;
   /* Default filter is map extents */
   bbox = map->extent;
   /* Read CGI parameters */
   /* __TODO__ Need to support XML encoded requests */
@@ -1453,6 +1457,9 @@
                 return msWFSException(map, "mapserv", "NoApplicableCode", paramsObj->pszVersion);
+        if (bUseGetShape == MS_FALSE)
+          bUseGetShape = (!FLTIsSimpleFilter(psNode));
         FLTFreeFilterEncodingNode( psNode );
         psNode = NULL;
@@ -1548,6 +1555,9 @@
                      psNode = NULL;
                      break;
@@ -1804,7 +1814,7 @@
     /* handle case of maxfeatures = 0 */
     if(maxfeatures != 0 && iResultTypeHits == 0)
-      msGMLWriteWFSQuery(map, stdout, maxfeatures, pszNameSpace, outputformat);
+      msGMLWriteWFSQuery(map, stdout, maxfeatures, pszNameSpace, outputformat,bUseGetShape);
     if (((iNumberOfFeatures==0) || (maxfeatures == 0)) && iResultTypeHits == 0) {
       msIO_printf("   <gml:boundedBy>\n");
