[mapserver-commits] r9661 - trunk/docs/en/development
Mon Jan 4 10:01:45 EST 2010
Author: hobu
Date: 2010-01-04 10:01:43 -0500 (Mon, 04 Jan 2010)
New Revision: 9661
   trunk/docs/en/development/documentation.txt
mac notes
Modified: trunk/docs/en/development/documentation.txt
--- trunk/docs/en/development/documentation.txt	2010-01-03 16:54:22 UTC (rev 9660)
+++ trunk/docs/en/development/documentation.txt	2010-01-04 15:01:43 UTC (rev 9661)
@@ -107,7 +107,7 @@
-       sudo easy_install sphynx
+       sudo easy_install Sphinx
 #. to process the docs, from the MapServer /docs directory, run:
@@ -129,6 +129,35 @@
     build all translations.
+**On OS X:**
+#. install sphinx using easy_install:
+# install MacTex from http://www.tug.org/mactex/2009/ if you want to build pdfs
+#. to process the docs, from the MapServer /docs directory, run:
+       make html
+   or
+       make latex
+   the HTML output will be written to the build/html sub-directory.
+.. note::
+    If there are more than one translation, the above commands will automatically
+    build all translations.
 How translations are handled
