[mapserver-commits] r9670 - trunk/mapserver
Tue Jan 5 15:55:37 EST 2010
Author: aboudreault
Date: 2010-01-05 15:55:36 -0500 (Tue, 05 Jan 2010)
New Revision: 9670
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maprasterquery.c
Added support to get the extent of a raster layer that use a tileindex (#3252)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-05 14:58:01 UTC (rev 9669)
+++ trunk/mapserver/HISTORY.TXT	2010-01-05 20:55:36 UTC (rev 9670)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Added support to get the extent of a raster layer that use a tileindex (#3252)
 - Fixed configure to support FTGL 2.1.2 (#3247)
 - Changed msSaveImageBufferGD to be in accordance with msSaveImageGD (#3201)
Modified: trunk/mapserver/maprasterquery.c
--- trunk/mapserver/maprasterquery.c	2010-01-05 14:58:01 UTC (rev 9669)
+++ trunk/mapserver/maprasterquery.c	2010-01-05 20:55:36 UTC (rev 9670)
@@ -1379,6 +1379,8 @@
   double adfGeoTransform[6];
   int nXSize, nYSize;
   GDALDatasetH hDS;
+  shapefileObj *tileshpfile;
+  int tilelayerindex = -1;
   ** For the time being we only automatically derive extents from
@@ -1388,9 +1390,9 @@
   ** the polygons but that is quite complicated code wise, so I am leaving
   ** that till someone cares more about the issue.  (#79)
-  if( !layer->data
-      || strlen(layer->data) == 0
-      || layer->tileindex != NULL )
+  if( (!layer->data || strlen(layer->data) == 0)
+      && layer->tileindex == NULL)
     /* should we be issuing a specific error about not supporting
        extents for tileindexed raster layers? */
@@ -1400,6 +1402,26 @@
   if( map == NULL )
     return MS_FAILURE;
+  /* If the layer use a tileindex...*/
+  if (layer->tileindex)
+    tilelayerindex = msGetLayerIndex(map, layer->tileindex);
+    if(tilelayerindex != -1) /* does the tileindex reference another layer */
+      return msLayerGetExtent(GET_LAYER(map, tilelayerindex), extent);
+    else
+      tileshpfile = (shapefileObj *) malloc(sizeof(shapefileObj));
+      if(msShapefileOpen(tileshpfile, "rb", msBuildPath3(szPath, map->mappath, map->shapepath, layer->tileindex), MS_TRUE) == -1)
+        if(msShapefileOpen(tileshpfile, "rb", msBuildPath(szPath, map->mappath, layer->tileindex), MS_TRUE) == -1)
+          return MS_FAILURE;
+      *extent = tileshpfile->bounds;
+      msShapefileClose(tileshpfile);
+      free(tileshpfile);
+      return MS_SUCCESS;
   msTryBuildPath3(szPath, map->mappath, map->shapepath, layer->data);
   msAcquireLock( TLOCK_GDAL );
