[mapserver-commits] r9672 - trunk/mapserver
Wed Jan 6 14:46:49 EST 2010
Author: pramsey
Date: 2010-01-06 14:46:48 -0500 (Wed, 06 Jan 2010)
New Revision: 9672
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapfile.c
Make %substitutions% case insensitive (#3250)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-01-05 20:58:34 UTC (rev 9671)
+++ trunk/mapserver/HISTORY.TXT	2010-01-06 19:46:48 UTC (rev 9672)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Made %substitution% strings case insensitive (#3250)
 - Added support to get the extent of a raster layer that use a tileindex (#3252)
 - Fixed configure to support FTGL 2.1.2 (#3247)
Modified: trunk/mapserver/mapfile.c
--- trunk/mapserver/mapfile.c	2010-01-05 20:58:34 UTC (rev 9671)
+++ trunk/mapserver/mapfile.c	2010-01-06 19:46:48 UTC (rev 9672)
@@ -5449,17 +5449,17 @@
 /* look in places authorized for url substitution and replace "from" by "to" */
 void msLayerSubstituteString(layerObj *layer, const char *from, const char *to) {
   int k;
-  if(layer->data && (strstr(layer->data, from) != NULL))
-    layer->data = msReplaceSubstring(layer->data, from, to);
-  if(layer->tileindex && (strstr(layer->tileindex, from) != NULL))
-    layer->tileindex = msReplaceSubstring(layer->tileindex, from, to);
-  if(layer->connection && (strstr(layer->connection, from) != NULL))
-    layer->connection = msReplaceSubstring(layer->connection, from, to);
-  if(layer->filter.string && (strstr(layer->filter.string, from) != NULL))
-    layer->filter.string = msReplaceSubstring(layer->filter.string, from, to);
+  if(layer->data && (strcasestr(layer->data, from) != NULL))
+    layer->data = msCaseReplaceSubstring(layer->data, from, to);
+  if(layer->tileindex && (strcasestr(layer->tileindex, from) != NULL))
+    layer->tileindex = msCaseReplaceSubstring(layer->tileindex, from, to);
+  if(layer->connection && (strcasestr(layer->connection, from) != NULL))
+    layer->connection = msCaseReplaceSubstring(layer->connection, from, to);
+  if(layer->filter.string && (strcasestr(layer->filter.string, from) != NULL))
+    layer->filter.string = msCaseReplaceSubstring(layer->filter.string, from, to);
   for(k=0; k<layer->numclasses; k++) {
-    if(layer->class[k]->expression.string && (strstr(layer->class[k]->expression.string, from) != NULL))
-      layer->class[k]->expression.string = msReplaceSubstring(layer->class[k]->expression.string, from, to);
+    if(layer->class[k]->expression.string && (strcasestr(layer->class[k]->expression.string, from) != NULL))
+      layer->class[k]->expression.string = msCaseReplaceSubstring(layer->class[k]->expression.string, from, to);
