[mapserver-commits] r9696 - trunk/docs/en/mapscript/php
Fri Jan 15 12:28:20 EST 2010
Author: aboudreault
Date: 2010-01-15 12:28:20 -0500 (Fri, 15 Jan 2010)
New Revision: 9696
   trunk/docs/en/mapscript/php/index.txt
Update php mapscript deprecated class properties (#2170)
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-01-15 17:02:28 UTC (rev 9695)
+++ trunk/docs/en/mapscript/php/index.txt	2010-01-15 17:28:20 UTC (rev 9696)
@@ -237,10 +237,10 @@
 labelcacheObj   labelcache (no members. Used only to be able to free the
                 the label cache (ex : map->labelcache->free())
 projectionObj   projection
-int             transparent   (deprecated, use outputFormatObj)
-int             interlace     (deprecated, use outputFormatObj)
-int             imagetype     (deprecated, use outputFormatObj)
-int             imagequality  (deprecated, use outputFormatObj)
+int             transparent   (Deprecated, use outputFormatObj)
+int             interlace     (Deprecated, use outputFormatObj)
+int             imagetype     (Deprecated, use outputFormatObj)
+int             imagequality  (Deprecated, use outputFormatObj)
 Methods
@@ -1867,8 +1867,8 @@
 int             units
 int             status //MS_ON, MS_OFF, MS_EMBED
 int             position //for embeded scalebars, MS_UL, MS_UC, ...
-int             transparent
-int             interlace
+int             transparent (Deprecated in v4.6)
+int             interlace (Deprecated in v4.6)
 int             postlabelcache
 labelObj        label
 colorObj        imagecolor
@@ -1911,8 +1911,8 @@
 colorObj        outlinecolor //Color of outline of box, -1 for no outline
 int             position //for embeded legends, MS_UL, MS_UC, ...
-int             transparent
-int             interlace
 int             postlabelcache //MS_TRUE, MS_FALSE
 labelObj        label
 colorObj        imagecolor
@@ -2251,7 +2251,7 @@
 string          character
 int             antialias
 string          font
-int             gap
+int             gap (Deprecated in v6.0)
 int             position
