[mapserver-commits] r9713 - trunk/mapserver
Wed Jan 20 14:16:57 EST 2010
Author: assefa
Date: 2010-01-20 14:16:55 -0500 (Wed, 20 Jan 2010)
New Revision: 9713
   trunk/mapserver/mapogcfilter.c
Using function NONE for oracle layers when filter has only attribute query (#2725)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2010-01-20 16:59:36 UTC (rev 9712)
+++ trunk/mapserver/mapogcfilter.c	2010-01-20 19:16:55 UTC (rev 9713)
@@ -925,6 +925,21 @@
+/*                        FLTIsSimpleFilterNoSpatial                    */
+/*      Filter encoding with only attribute queries                     */
+int FLTIsSimpleFilterNoSpatial(FilterEncodingNode *psNode)
+    if (FLTIsSimpleFilter(psNode) &&
+        FLTNumberOfFilterType(psNode, "BBOX") == 0)
+      return MS_TRUE;
+    return MS_FALSE;
 /*                      FLTApplySimpleSQLFilter()                       */
@@ -941,7 +956,8 @@
     char *pszBuffer = NULL;
     int bConcatWhere = 0;
     int bHasAWhere =0;
-    char *pszTmp = NULL;
+    char *pszTmp = NULL, *pszTmp2 = NULL;
     char *tmpfilename = NULL;
     lp = (GET_LAYER(map, iLayerIndex));
@@ -1110,11 +1126,59 @@
+    /*for oracle connection, if we have a simple filter with no spatial constraints
+      we should set the connection function to NONE to have a better performance
+      (#2725)*/
+    if (lp->connectiontype ==  MS_ORACLESPATIAL && FLTIsSimpleFilterNoSpatial(psNode))
+        if (msCaseFindSubstring(lp->data, "USING") == 0)
+          lp->data = msStringConcatenate(lp->data, " USING NONE");
+        else if (msCaseFindSubstring(lp->data, "NONE") == 0)
+            /*if one of the functions is used, just replace it with NONE*/
+            if (msCaseFindSubstring(lp->data, "FILTER"))
+              lp->data = msCaseReplaceSubstring(lp->data, "FILTER", "NONE");
+            else if (msCaseFindSubstring(lp->data, "GEOMRELATE"))
+              lp->data = msCaseReplaceSubstring(lp->data, "GEOMRELATE", "NONE");
+            else if (msCaseFindSubstring(lp->data, "RELATE"))
+              lp->data = msCaseReplaceSubstring(lp->data, "RELATE", "NONE");
+            else if (msCaseFindSubstring(lp->data, "VERSION"))
+                /*should add NONE just before the VERSION. Cases are:
+                  DATA "ORA_GEOMETRY FROM data USING VERSION 10g
+                  DATA "ORA_GEOMETRY FROM data  USING UNIQUE FID VERSION 10g"
+                pszTmp = (char *)msCaseFindSubstring(lp->data, "VERSION");
+                pszTmp2 = msStringConcatenate(pszTmp2, " NONE ");
+                pszTmp2 = msStringConcatenate(pszTmp2, pszTmp);
+                lp->data = msCaseReplaceSubstring(lp->data, pszTmp, pszTmp2);
+                msFree(pszTmp2);
+            else if (msCaseFindSubstring(lp->data, "SRID"))
+                lp->data = msStringConcatenate(lp->data, " NONE");
     return msQueryByRect(map);
     /* return MS_SUCCESS; */
+/*                            FLTIsSimpleFilter                         */
+/*      Filter encoding with only attribute queries and only one bbox.  */
 int FLTIsSimpleFilter(FilterEncodingNode *psNode)
     if (FLTValidForBBoxFilter(psNode))
