[mapserver-commits] r9737 - trunk/mapserver
svn at osgeo.org
svn at osgeo.org
Sat Jan 23 21:04:05 EST 2010
Author: pramsey
Date: 2010-01-23 21:04:03 -0500 (Sat, 23 Jan 2010)
New Revision: 9737
trunk/mapserver/mappostgis.c
trunk/mapserver/mappostgis.h
Handle !BOX! replacement more carefully in getting items and also in general. (#3274)
Modified: trunk/mapserver/mappostgis.c
--- trunk/mapserver/mappostgis.c 2010-01-23 21:03:29 UTC (rev 9736)
+++ trunk/mapserver/mappostgis.c 2010-01-24 02:04:03 UTC (rev 9737)
@@ -847,7 +847,6 @@
return 0;
** msPostGISBuildSQLBox()
@@ -888,6 +887,7 @@
** msPostGISBuildSQLItems()
@@ -1050,42 +1050,22 @@
return strSRID;
-** msPostGISBuildSQLFrom()
+** msPostGISReplaceBoxToken()
+** Convert a fromsource data statement into something usable by replacing the !BOX! token.
** Returns malloc'ed char* that must be freed by caller.
-char *msPostGISBuildSQLFrom(layerObj *layer, rectObj *rect) {
- char *fromsource =0;
- char *strFrom = 0;
- static char *boxToken = "!BOX!";
- static int boxTokenLength = 5;
- msPostGISLayerInfo *layerinfo;
- if (layer->debug) {
- msDebug("msPostGISBuildSQLFrom called.\n");
- assert( layer->layerinfo != NULL);
- layerinfo = (msPostGISLayerInfo *)layer->layerinfo;
- if ( ! layerinfo->fromsource ) {
- msSetError(MS_MISCERR, "Layerinfo->fromsource is not initialized.", "msPostGISBuildSQLFrom()");
- return 0;
+static char *msPostGISReplaceBoxToken(layerObj *layer, rectObj *rect, const char *fromsource)
+ char *result = NULL;
- fromsource = layerinfo->fromsource;
+ if ( strstr(fromsource, BOXTOKEN) && rect ) {
+ char *strBox = NULL;
+ char *strSRID = NULL;
- ** If there's a '!BOX!' in our source we need to substitute the
- ** current rectangle for it...
- if ( strstr(fromsource, boxToken) && rect ) {
- char *result = NULL;
- char *strBox;
- char *strSRID;
/* We see to set the SRID on the box, but to what SRID? */
strSRID = msPostGISBuildSQLSRID(layer);
if ( ! strSRID ) {
@@ -1095,17 +1075,17 @@
/* Create a suitable SQL string from the rectangle and SRID. */
strBox = msPostGISBuildSQLBox(layer, rect, strSRID);
if ( ! strBox ) {
- msSetError(MS_MISCERR, "Unable to build box SQL.", "msPostGISBuildSQLFrom()");
+ msSetError(MS_MISCERR, "Unable to build box SQL.", "msPostGISReplaceBoxToken()");
if (strSRID) free(strSRID);
return 0;
/* Do the substitution. */
- while ( strstr(fromsource,boxToken) ) {
+ while ( strstr(fromsource, BOXTOKEN) ) {
char *start, *end;
char *oldresult = result;
- start = strstr(fromsource, boxToken);
- end = start + boxTokenLength;
+ start = strstr(fromsource, BOXTOKEN);
+ end = start + BOXTOKENLENGTH;
result = (char*)malloc((start - fromsource) + strlen(strBox) + strlen(end) +1);
@@ -1120,12 +1100,42 @@
if (strBox) free(strBox);
+ else
+ result = strdup(fromsource);
+ return result;
+** msPostGISBuildSQLFrom()
+** Returns malloc'ed char* that must be freed by caller.
+char *msPostGISBuildSQLFrom(layerObj *layer, rectObj *rect) {
+ char *strFrom = 0;
+ msPostGISLayerInfo *layerinfo;
+ if (layer->debug) {
+ msDebug("msPostGISBuildSQLFrom called.\n");
+ assert( layer->layerinfo != NULL);
+ layerinfo = (msPostGISLayerInfo *)layer->layerinfo;
+ if ( ! layerinfo->fromsource ) {
+ msSetError(MS_MISCERR, "Layerinfo->fromsource is not initialized.", "msPostGISBuildSQLFrom()");
+ return 0;
- ** Otherwise we can just take the fromsource "as is".
+ ** If there's a '!BOX!' in our source we need to substitute the
+ ** current rectangle for it...
- strFrom = strdup(fromsource);
+ strFrom = msPostGISReplaceBoxToken(layer, rect, layerinfo->fromsource);
return strFrom;
@@ -1157,7 +1167,7 @@
+ msSetError(MS_MISCERR, "Layerinfo->fromsource is not initialized.", "msPostGISBuildSQLWhere()");
return 0;
@@ -1274,12 +1284,20 @@
strFrom = msPostGISBuildSQLFrom(layer, rect);
if ( ! strFrom ) {
msSetError(MS_MISCERR, "Failed to build SQL 'from'.", "msPostGISBuildSQL()");
return 0;
- strWhere = msPostGISBuildSQLWhere(layer, rect, uid);
+ /* If there's BOX hackery going on, we don't want to append a box index test at
+ the end of the query, the user is going to be responsible for making things
+ work with their hackery. */
+ if ( strstr(layerinfo->fromsource, BOXTOKEN) )
+ strWhere = msPostGISBuildSQLWhere(layer, NULL, uid);
+ else
+ strWhere = msPostGISBuildSQLWhere(layer, rect, uid);
if ( ! strWhere ) {
msSetError(MS_MISCERR, "Failed to build SQL 'where'.", "msPostGISBuildSQL()");
return 0;
@@ -1579,7 +1597,7 @@
#else
msSetError( MS_MISCERR,
"PostGIS support is not available.",
- "msPostGISLayerOpen()");
+ "msPostGISLayerClose()");
return MS_FAILURE;
#endif
@@ -1819,7 +1837,7 @@
assert(layer->layerinfo != NULL);
if (layer->debug) {
- msDebug("msPostGISLayerGetShape called for record = %i\n", record);
+ msDebug("msPostGISLayerResultsGetShape called for record = %i\n", record);
layerinfo = (msPostGISLayerInfo*) layer->layerinfo;
@@ -1967,15 +1985,19 @@
int msPostGISLayerGetItems(layerObj *layer) {
#ifdef USE_POSTGIS
- char *sql = 0;
+ msPostGISLayerInfo *layerinfo = NULL;
static char *strSQLTemplate = "select * from %s where false limit 0";
- PGresult *pgresult;
- int t;
- char *col;
- char found_geom = 0;
- int item_num;
+ PGresult *pgresult = NULL;
+ char *col = NULL;
+ char *sql = NULL;
+ char *strFrom = NULL;
+ char found_geom = NULL;
+ int t, item_num;
+ rectObj rect;
+ /* A useless rectangle for our useless query */
+ rect.minx = rect.miny = rect.maxx = rect.maxy = 0.0;
assert(layer != NULL);
@@ -1994,12 +2016,16 @@
+ /* This allocates a fresh string, so remember to free it... */
+ strFrom = msPostGISReplaceBoxToken(layer, &rect, layerinfo->fromsource);
** Both the "table" and "(select ...) as sub" cases can be handled with the
** same SQL.
- sql = (char*) malloc(strlen(strSQLTemplate) + strlen(layerinfo->fromsource));
- sprintf(sql, strSQLTemplate, layerinfo->fromsource);
+ sql = (char*) malloc(strlen(strSQLTemplate) + strlen(strFrom));
+ sprintf(sql, strSQLTemplate, strFrom);
+ free(strFrom);
if (layer->debug) {
msDebug("msPostGISLayerGetItems executing SQL: %s\n", sql);
@@ -2046,7 +2072,7 @@
#else
- "msPostGISLayerGetShape()");
+ "msPostGISLayerGetItems()");
return MS_FAILURE;
#endif
Modified: trunk/mapserver/mappostgis.h
--- trunk/mapserver/mappostgis.h 2010-01-23 21:03:29 UTC (rev 9736)
+++ trunk/mapserver/mappostgis.h 2010-01-24 02:04:03 UTC (rev 9737)
@@ -12,6 +12,10 @@
/* HEX = 16 or BASE64 = 64*/
#define TRANSFER_ENCODING 16
+/* Substitution token for box hackery */
+#define BOXTOKEN "!BOX!"
+#define BOXTOKENLENGTH 5
** msPostGISLayerInfo
More information about the mapserver-commits
