[mapserver-commits] r9741 - branches/branch-5-6/docs
Mon Jan 25 02:30:48 EST 2010
Author: gislars
Date: 2010-01-25 02:30:48 -0500 (Mon, 25 Jan 2010)
New Revision: 9741
   branches/branch-5-6/docs/make.bat
added init target to make.bat (copy untranslated files)
Modified: branches/branch-5-6/docs/make.bat
--- branches/branch-5-6/docs/make.bat	2010-01-25 07:28:42 UTC (rev 9740)
+++ branches/branch-5-6/docs/make.bat	2010-01-25 07:30:48 UTC (rev 9741)
@@ -4,8 +4,9 @@
 REM using delayed expansion of variables...
 setlocal enableextensions enabledelayedexpansion
-REM ...to get a list of directories to be processed
-FOR /D  %%i IN ("??") do (SET LANGUAGES=!LANGUAGES! %%i)
+REM ...build a list of directories to be processed (language directories)
+SET TRANSLATIONS=de
+SET LANGUAGES=en %TRANSLATIONS%
 set SPHINXBUILD=sphinx-build
 set ALLSPHINXOPTS= -d _build/doctrees/%%L -c . -A language=%%L -D language=%%L -A languages="%LANGUAGES%"
@@ -18,6 +19,7 @@
 if "%1" == "help" (
 	:help
 	echo.Please use `make ^<target^>` where ^<target^> is one of
+  echo.  init      to preprocess translation directories
 	echo.  html      to make standalone HTML files
 	echo.  latex     to make LaTeX files, you can set PAPER=a4 or PAPER=letter
 	echo.  changes   to make an overview over all changed/added/deprecated items
@@ -25,6 +27,14 @@
 	goto end
+if "%1" == "init" (
+  FOR  %%L in (%TRANSLATIONS%) DO (
+  	xcopy en %%L /d /y /c /s /q
+	echo.Init finished.
+  goto end
 if "%1" == "clean" (
 	for /d %%i in (_build\*) do rmdir /q /s %%i
 	del /q /s _build\*
