[mapserver-commits] r9746 - trunk/docs/en/mapscript/php
svn at osgeo.org
svn at osgeo.org
Mon Jan 25 12:19:49 EST 2010
Author: aboudreault
Date: 2010-01-25 12:19:48 -0500 (Mon, 25 Jan 2010)
New Revision: 9746
trunk/docs/en/mapscript/php/index.txt
Added labelcachemember object documentation
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt 2010-01-25 16:52:57 UTC (rev 9745)
+++ trunk/docs/en/mapscript/php/index.txt 2010-01-25 17:19:48 UTC (rev 9746)
@@ -296,6 +296,17 @@
int drawLabelCache(imageObj image)
Renders the labels for a map. Returns -1 on error.
+labelcacheMemberObj getLabel(int index)
+ Returns a labelcacheMemberObj from the map given an index value (0=first label)
+ Labelcache have to be enabled.
+.. code-block:: php
+ while ($oLabelCacheMember = $oMap->getLabel($i)) {
+ /* do something with the labelcachemember */
+ ++$i;
layerObj getLayer(int index)
Returns a layerObj from the map given an index value (0=first layer)
@@ -2210,6 +2221,33 @@
+LabelcacheMemberObj Class
+Accessible only through the map object (map->getLabel()).
+Members
+Type Name
+int classindex (Read-Only)
+int featuresize (Read-Only)
+int layerindex (Read-Only)
+int numstyles (Read-Only)
+int shapeindex (Read-Only)
+int status (Read-Only)
+string text (Read-Only)
+int tileindex (Read-Only)
+Method
+None
SymbolObj Class
More information about the mapserver-commits
