[mapserver-commits] r9762 - trunk/docs/en/mapscript/php
Tue Jan 26 12:18:00 EST 2010
Author: jmckenna
Date: 2010-01-26 12:17:59 -0500 (Tue, 26 Jan 2010)
New Revision: 9762
   trunk/docs/en/mapscript/php/index.txt
more attempts are standardizing class object names in doc
Modified: trunk/docs/en/mapscript/php/index.txt
--- trunk/docs/en/mapscript/php/index.txt	2010-01-26 16:51:16 UTC (rev 9761)
+++ trunk/docs/en/mapscript/php/index.txt	2010-01-26 17:17:59 UTC (rev 9762)
@@ -316,13 +316,13 @@
 int removeMetaData(string name)
     Remove a metadata entry for the class.  Returns MS_SUCCESS/MS_FAILURE.
-ColorObj
+colorObj
 Constructor
-Instances of ColorObj are always embedded inside other classes.
+Instances of colorObj are always embedded inside other classes.
@@ -393,7 +393,7 @@
         $error = $error->next();
-GridObj
+gridObj
 Constructor
@@ -443,7 +443,7 @@
 Instance of hashTableObj is always embedded inside the `classObj`_, `layerObj`_,
-and `WebObj`_. It is uses a read only.
+and `webObj`_. It is uses a read only.
 .. code-block:: php
@@ -472,13 +472,13 @@
     Return the next key or first key if previousKey = NULL.
     Return NULL if no item is in the hashTable or end of hashTable is reached
-ImageObj
+imageObj
 Constructor
-Instances of ImageObj are always created by the `mapObj`_ class methods.
+Instances of imageObj are always created by the `mapObj`_ class methods.
@@ -532,7 +532,7 @@
     specify the CENTER of the destination area.
     Note: this function works only with 8 bits GD images (PNG or GIF).
-LabelcacheMemberObj
+labelcacheMemberObj
 Accessible only through the `mapObj`_ (map->getLabel()).
@@ -558,7 +558,7 @@
 None
-LabelcacheObj
+labelcacheObj
 Accessible only through the `mapObj`_ (map->labelcache). This object
@@ -574,13 +574,13 @@
     occurs.
     Ex : (map->labelcache->free();
-LabelObj
+labelObj
 Constructor
-LabelObj are always embedded inside other classes.
+labelObj are always embedded inside other classes.
@@ -1013,7 +1013,7 @@
     load by mapserver. For the other connection types this parameter
     is not used.
-LegendObj
+legendObj
 Constructor
@@ -1053,7 +1053,7 @@
 int set(string property_name, new_value)
     Set object property to a new value. Returns -1 on error.
-LineObj
+lineObj
 Constructor
@@ -1577,7 +1577,7 @@
     Remove a layer from the mapObj. The argument is the index of the layer
     to be removed. Returns the removed layerObj on success, else null.
-OutputformatObj
+outputformatObj
 Constructor
@@ -1675,7 +1675,7 @@
 string getvaluebyname(string name)
     Return the value associated with the parameter *name*.
-PointObj
+pointObj
 Constructor
@@ -1739,7 +1739,7 @@
 void free()
    Releases all resources used by the object.
-ProjectionObj
+projectionObj
 Constructor
@@ -1747,7 +1747,7 @@
 .. code-block:: php
-    ProjectionObjObj ms_newProjectionObj(string projectionstring)
+    ProjectionObj ms_newProjectionObj(string projectionstring)
 Creates a projection object based on the projection string passed
 as argument.
@@ -1776,7 +1776,7 @@
 int getUnits()
     Returns the units of a projection object. Returns -1 on error.
-QuerymapObj
+querymapObj
 Constructor
@@ -1805,13 +1805,13 @@
-RectObj
+rectObj
 Constructor
-RectObj are sometimes embedded inside other objects.  New ones can
+rectObj are sometimes embedded inside other objects.  New ones can
 also be created with:
 .. code-block:: php
@@ -1890,13 +1890,13 @@
-ResultCacheMemberObj
+resultCacheMemberObj
 Constructor
-Instances of ResultCacheMemberObj are always obtained through
+Instances of resultCacheMemberObj are always obtained through
 `layerObj`_'s getResult() method.
@@ -1915,7 +1915,7 @@
 None
-ScalebarObj
+scalebarObj
 Constructor
@@ -1960,7 +1960,7 @@
     Sets the imagecolor propery (baclground) of the object.
     Returns false on error.
-ShapefileObj
+shapefileObj
 Constructor
@@ -2013,7 +2013,7 @@
     Closes a shape file (and commits all changes in write mode) and
     releases all resources used by the object.
-ShapeObj
+shapeObj
 Constructor
@@ -2199,7 +2199,7 @@
     Must be called to calculate new bounding box after new parts have been
     added.  Returns true if successful, else return false.
-StyleObj
+styleObj
 Constructor
@@ -2285,7 +2285,7 @@
         $oStyle->removebinding(MS_STYLE_BINDING_COLOR);
-SymbolObj
+symbolObj
 Constructor
@@ -2293,7 +2293,7 @@
 .. code-block:: php
-    symboldid = ms_newSymbolObj(mapObj map, string symbolname);
+    symbolid = ms_newSymbolObj(mapObj map, string symbolname);
 Creates a new symbol with default values in the symbolist. Returns the Id of
 the new symbol. If a symbol with the same name exists, It's id will be returned.
