[mapserver-commits] r10270 - sandbox/mapserver6
Thu Jul 1 06:16:17 EDT 2010
Author: tbonfort
Date: 2010-07-01 10:16:17 +0000 (Thu, 01 Jul 2010)
New Revision: 10270
   sandbox/mapserver6/mapagg.h
   sandbox/mapserver6/mapagg2.cpp
   sandbox/mapserver6/mapimageio.c
   sandbox/mapserver6/mapoutput.c
   sandbox/mapserver6/maprendering.c
   sandbox/mapserver6/maputil.c
memory allocation cleanups
Modified: sandbox/mapserver6/mapagg.h
--- sandbox/mapserver6/mapagg.h	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/mapagg.h	2010-07-01 10:16:17 UTC (rev 10270)
@@ -27,126 +27,8 @@
  * DEALINGS IN THE SOFTWARE.
-#include "renderers/agg/include/agg_array.h"
 #include "renderers/agg/include/agg_rendering_buffer.h"
-template<class T> class mapserv_row_ptr_cache
-public:
-	typedef mapserver::const_row_info<T> row_data;
-	mapserv_row_ptr_cache() :
-            m_buf(0),
-            m_rows(),
-            m_width(0),
-            m_height(0),
-            m_stride(0)
-	mapserv_row_ptr_cache( const gdImagePtr pImg ) :
-            m_buf(0),
-            m_rows(),
-            m_width(0),
-            m_height(0),
-            m_stride(0)
-		attach( pImg->tpixels, pImg->sx, pImg->sy, pImg->sx * sizeof( T ) );
-	void attach( T **ppRows, unsigned width, unsigned height, int stride )
-		m_width	= width;
-		m_height = height;
-		m_stride = stride;
-		if( height > m_rows.size() )
-			m_rows.resize( height );
-		T** rows	= &m_rows[0];
-		int iRowIndex = 0;
-		while( height--)
-			*rows = ppRows[iRowIndex];
-			rows++;
-			iRowIndex++;
-        AGG_INLINE       T* buf()          { return m_buf;    }
-        AGG_INLINE const T* buf()    const { return m_buf;    }
-        AGG_INLINE unsigned width()  const { return m_width;  }
-        AGG_INLINE unsigned height() const { return m_height; }
-        AGG_INLINE int      stride() const { return m_stride; }
-        AGG_INLINE unsigned stride_abs() const
-            return (m_stride < 0) ? unsigned(-m_stride) : unsigned(m_stride);
-        AGG_INLINE       T* row_ptr(int, int y, unsigned)
-            return m_rows[y];
-        AGG_INLINE       T* row_ptr(int y)       { return m_rows[y]; }
-        AGG_INLINE const T* row_ptr(int y) const { return m_rows[y]; }
-        AGG_INLINE row_data row    (int y) const
-            return row_data(0, m_width-1, m_rows[y]);
-        T const* const* rows() const { return &m_rows[0]; }
-        template<class RenBuf>
-        void copy_from(const RenBuf& src)
-            unsigned h = height();
-            if(src.height() < h) h = src.height();
-            unsigned l = stride_abs();
-            if(src.stride_abs() < l) l = src.stride_abs();
-            l *= sizeof(T);
-            unsigned y;
-            unsigned w = width();
-            for (y = 0; y < h; y++)
-                memcpy(row_ptr(0, y, w), src.row_ptr(y), l);
-        void clear(T value)
-            unsigned y;
-            unsigned stride = stride_abs();
-            for(y = 0; y < height(); y++)
-                T* p = row_ptr(0, y, w);
-                unsigned x;
-                for(x = 0; x < stride; x++)
-                    *p++ = value;
-    private:
-        T*            m_buf;        /* Pointer to rendering buffer */
-        mapserver::pod_array<T*> m_rows;  /* Pointers to each row of the buffer */
-        unsigned      m_width;      /* Width in pixels */
-        unsigned      m_height;     /* Height in pixels */
-        int           m_stride;     /* Number of bytes per row. Can be < 0 */
  * interface to a shapeObj representing lines, providing the functions
  * needed by the agg rasterizer. treats shapeObjs with multiple linestrings.
Modified: sandbox/mapserver6/mapagg2.cpp
--- sandbox/mapserver6/mapagg2.cpp	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/mapagg2.cpp	2010-07-01 10:16:17 UTC (rev 10270)
@@ -438,7 +438,7 @@
 	rasterBufferObj *pixmap = symbol->pixmap_buffer;
 	assert(pixmap->type == MS_BUFFER_BYTE_RGBA);
     if(!symbol->renderer_cache) {
-        band_type *data = new band_type[pixmap->width*pixmap->height*4];
+        band_type *data = (band_type*)malloc(pixmap->width*pixmap->height*4*sizeof(band_type));
         memcpy(data,pixmap->data.rgba.pixels,pixmap->width*pixmap->height*4);
         rendering_buffer *b = new rendering_buffer(data, pixmap->width, pixmap->height, (int)pixmap->width*4);
         symbol->renderer_cache = (void*)b;
@@ -658,7 +658,7 @@
    image = (imageObj *) calloc(1, sizeof (imageObj));
    AGG2Renderer *r = new AGG2Renderer();
-   r->buffer = new band_type[width * height * 4];
+   r->buffer = (band_type*)malloc(width * height * 4 * sizeof(band_type));
    r->m_rendering_buffer.attach(r->buffer, width, height, width * 4);
    r->m_pixel_format.attach(r->m_rendering_buffer);
    r->m_renderer_base.attach(r->m_pixel_format);
@@ -759,7 +759,7 @@
 int agg2FreeImage(imageObj * image) {
    AGG2Renderer *r = agg2GetRenderer(image);
-   delete[] r->buffer;
+   free(r->buffer);
    delete r;
    image->img.plugin = NULL;
    return MS_SUCCESS;
@@ -770,6 +770,16 @@
 int agg2FreeSymbol(symbolObj * symbol) {
+	switch(symbol->type) {
+	case MS_SYMBOL_PIXMAP:
+	   if(symbol->renderer_cache) {
+	      rendering_buffer *rb = (rendering_buffer*)symbol->renderer_cache;
+	      free(rb->buf());
+	      delete (rendering_buffer*)symbol->renderer_cache;
+	   symbol->renderer_cache = NULL;
+	   break;
 	return MS_SUCCESS;
Modified: sandbox/mapserver6/mapimageio.c
--- sandbox/mapserver6/mapimageio.c	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/mapimageio.c	2010-07-01 10:16:17 UTC (rev 10270)
@@ -737,6 +737,7 @@
 int msLoadMSRasterBufferFromFile(char *path, rasterBufferObj *rb) {
     FILE *stream;
     unsigned char signature[8];
+    int ret = MS_FAILURE;
     stream = fopen(path,"rb");
     if(!stream) {
         msSetError(MS_MISCERR, "unable to open file %s for reading", "msLoadRasterBuffer()", path);
@@ -745,7 +746,7 @@
     fread(signature,1,8,stream);
     rewind(stream);
     if(png_check_sig(signature,8)) {
-         return readPNG(stream,rb);
+         ret = readPNG(stream,rb);
 #if 0
     } else if () {//GIF loading
 #endif
@@ -753,7 +754,8 @@
         msSetError(MS_MISCERR,"unsupported pixmap format","readImage()");
         return MS_FAILURE;
-    return MS_FAILURE;
+    fclose(stream);
+    return ret;
 int saveGdImage(gdImagePtr ip, FILE *fp, outputFormatObj *format) {
Modified: sandbox/mapserver6/mapoutput.c
--- sandbox/mapserver6/mapoutput.c	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/mapoutput.c	2010-07-01 10:16:17 UTC (rev 10270)
@@ -1019,9 +1019,7 @@
 int msInitializeRendererVTable(outputFormatObj *format) {
     assert(format);
     if(format->vtable) {
-        /* TODO?: clean up caches before switch
-        msFreeRendererVTable(format->vtable); */
-        msFree(format->vtable);
+       return MS_SUCCESS;
     format->vtable = (rendererVTableObj*)malloc(sizeof(rendererVTableObj));
Modified: sandbox/mapserver6/maprendering.c
--- sandbox/mapserver6/maprendering.c	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/maprendering.c	2010-07-01 10:16:17 UTC (rev 10270)
@@ -156,10 +156,6 @@
     MS_COPYCOLOR(&dst->backgroundcolor,&src->backgroundcolor);
-void freeTileCache(tileCacheObj *cache) {
 /* add a cached tile to the current image's cache */
 tileCacheObj *addTileCache(imageObj *img,
         imageObj *tile, symbolObj *symbol, symbolStyleObj *style, int width, int height) {
Modified: sandbox/mapserver6/maputil.c
--- sandbox/mapserver6/maputil.c	2010-07-01 03:49:04 UTC (rev 10269)
+++ sandbox/mapserver6/maputil.c	2010-07-01 10:16:17 UTC (rev 10270)
@@ -770,19 +770,17 @@
     if (image)
-        if(MS_RENDERER_PLUGIN(image->format)) {
-            rendererVTableObj *renderer = image->format->vtable;
-            if(renderer->supports_imagecache) {
-                tileCacheObj *next,*cur = image->tilecache;
-                while(cur) {
-                    renderer->freeImage(cur->image);
-                    next = cur->next;
-                    free(cur);
-                    cur = next;
-                image->ntiles = 0;
-        	renderer->freeImage(image);
+       if(MS_RENDERER_PLUGIN(image->format)) {
+          rendererVTableObj *renderer = image->format->vtable;
+          tileCacheObj *next,*cur = image->tilecache;
+          while(cur) {
+             msFreeImage(cur->image);
+             next = cur->next;
+             free(cur);
+             cur = next;
+          image->ntiles = 0;
+          renderer->freeImage(image);
         } else if( MS_RENDERER_IMAGEMAP(image->format) )
             msFreeImageIM(image);
         else if( MS_RENDERER_RAWDATA(image->format) )
