[mapserver-commits] r10295 - trunk/msautotest/renderers
Thu Jul 8 03:48:48 EDT 2010
Author: tbonfort
Date: 2010-07-08 07:48:48 +0000 (Thu, 08 Jul 2010)
New Revision: 10295
Added:
   trunk/msautotest/renderers/embed_legend.map
   trunk/msautotest/renderers/embed_legend_rgba.map
   trunk/msautotest/renderers/embed_legend_rgba_tr.map
   trunk/msautotest/renderers/embed_legend_tr.map
   trunk/msautotest/renderers/embed_sb_rgb.map
   trunk/msautotest/renderers/embed_sb_rgb_tr.map
   trunk/msautotest/renderers/plb_embed_legend.map
   trunk/msautotest/renderers/plb_embed_legend_rgba.map
   trunk/msautotest/renderers/plb_embed_legend_rgba_tr.map
   trunk/msautotest/renderers/plb_embed_legend_tr.map
   trunk/msautotest/renderers/point_pixmap_gif.map
   trunk/msautotest/renderers/symbolset
   trunk/msautotest/renderers/transparent_layer.map
Removed:
   trunk/msautotest/renderers/legend.map
   trunk/msautotest/renderers/polygon-hatch.map
add tests
Copied: trunk/msautotest/renderers/embed_legend.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/embed_legend.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_legend.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,55 @@
+# Simple test of embedded legend support.
+# REQUIRES: OUTPUT=PNG
+MAP
+STATUS ON
+EXTENT 478300 4762880 481650 4765610
+SIZE 400 300
+shapepath "../misc/data"
+IMAGETYPE png
+fontset "../misc/fonts.lst"
+imagecolor 255 200 0
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  imagecolor 255 255 255
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  DATA "shppoly/poly.shp"
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    EXPRESSION ([AREA] >= 500000)
+    COLOR 255 0 0
+    OUTLINECOLOR 0 0 0
+  END
+  CLASS
+    NAME "Medium"
+    EXPRESSION ([AREA] >= 100000 and [AREA] < 500000)
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    EXPRESSION ([AREA] < 100000)
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/embed_legend_rgba.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/embed_legend_rgba.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_legend_rgba.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,55 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+transparent on
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/embed_legend_rgba_tr.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/embed_legend_rgba_tr.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_legend_rgba_tr.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,55 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+transparent on
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  TRANSPARENT ON
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/embed_legend_tr.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/embed_legend_tr.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_legend_tr.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,54 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  TRANSPARENT ON
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Added: trunk/msautotest/renderers/embed_sb_rgb.map
--- trunk/msautotest/renderers/embed_sb_rgb.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_sb_rgb.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,35 @@
+# Test embedded scalebar ... without transparency to RGBA output file.
+MAP
+EXTENT -180 -90 180 90
+SIZE 400 300
+IMAGECOLOR 255 200 0
+TRANSPARENT OFF
+IMAGETYPE png
+SCALEBAR
+  TRANSPARENT OFF
+  LABEL
+    COLOR 0 0 0
+    size 9
+    type truetype
+    font "default"
+  END
+  SIZE 150 3
+  COLOR 0 0 0
+  BACKGROUNDCOLOR 255 255 255
+  UNITS kilometers
+  INTERVALS 3
+  STATUS EMBED
+END
+END
Added: trunk/msautotest/renderers/embed_sb_rgb_tr.map
--- trunk/msautotest/renderers/embed_sb_rgb_tr.map	                        (rev 0)
+++ trunk/msautotest/renderers/embed_sb_rgb_tr.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,33 @@
+# Test embedded scalebar ... with transparency to RGBA output file.
+MAP
+SIZE 400 300
+TRANSPARENT OFF
+IMAGETYPE png
+SCALEBAR
+  TRANSPARENT ON
+  LABEL
+    COLOR 0 0 0
+    size 9
+    type truetype
+    font "default"
+  END
+  SIZE 150 3
+  COLOR 0 0 0
+  UNITS kilometers
+  INTERVALS 3
+  STATUS EMBED
+END
+END
Deleted: trunk/msautotest/renderers/legend.map
--- trunk/msautotest/renderers/legend.map	2010-07-08 07:47:25 UTC (rev 10294)
+++ trunk/msautotest/renderers/legend.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -1,54 +0,0 @@
-# Simple test of embedded legend support.
-# REQUIRES: OUTPUT=PNG
-MAP
-STATUS ON
-EXTENT 478300 4762880 481650 4765610
-SIZE 400 300
-shapepath "../misc/data"
-IMAGETYPE png
-fontset "../misc/fonts.lst"
-LEGEND
-  POSITION LR
-  STATUS EMBED
-  TRANSPARENT ON
-  label
-    type truetype
-    color 0 0 0
-    font "default"
-    size 9
-  end
-  #postlabelcache true
-END
-LAYER
-  NAME shppoly
-  TYPE polygon
-  DATA "shppoly/poly.shp"
-  STATUS default
-  CLASSITEM "AREA"
-  CLASS
-    NAME "Big"
-    EXPRESSION ([AREA] >= 500000)
-    COLOR 255 0 0
-    OUTLINECOLOR 0 0 0
-  END
-  CLASS
-    NAME "Medium"
-    EXPRESSION ([AREA] >= 100000 and [AREA] < 500000)
-    COLOR 0 255 0
-  END
-  CLASS
-    NAME "Small"
-    EXPRESSION ([AREA] < 100000)
-    COLOR 0 0 255
-  END
-END
-END
Copied: trunk/msautotest/renderers/plb_embed_legend.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/plb_embed_legend.map	                        (rev 0)
+++ trunk/msautotest/renderers/plb_embed_legend.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,56 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+    postlabelcache true
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/plb_embed_legend_rgba.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/plb_embed_legend_rgba.map	                        (rev 0)
+++ trunk/msautotest/renderers/plb_embed_legend_rgba.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,56 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+transparent on
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/plb_embed_legend_rgba_tr.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/plb_embed_legend_rgba_tr.map	                        (rev 0)
+++ trunk/msautotest/renderers/plb_embed_legend_rgba_tr.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,56 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+transparent on
+LEGEND
+  POSITION LR
+  STATUS EMBED
+postlabelcache true
+TRANSPARENT ON
+  label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/plb_embed_legend_tr.map (from rev 10240, trunk/msautotest/renderers/legend.map)
--- trunk/msautotest/renderers/plb_embed_legend_tr.map	                        (rev 0)
+++ trunk/msautotest/renderers/plb_embed_legend_tr.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,55 @@
+MAP
+STATUS ON
+SIZE 400 300
+IMAGETYPE png
+LEGEND
+  POSITION LR
+  STATUS EMBED
+  TRANSPARENT ON
+label
+    type truetype
+    color 0 0 0
+    font "default"
+    size 9
+  end
+END
+LAYER
+  NAME shppoly
+  TYPE polygon
+  STATUS default
+  CLASSITEM "AREA"
+  CLASS
+    NAME "Big"
+    COLOR 255 0 0
+  END
+  CLASS
+    NAME "Medium"
+    COLOR 0 255 0
+  END
+  CLASS
+    NAME "Small"
+    COLOR 0 0 255
+  END
+END
+END
Copied: trunk/msautotest/renderers/point_pixmap_gif.map (from rev 10240, trunk/msautotest/renderers/point_pixmap.map)
--- trunk/msautotest/renderers/point_pixmap_gif.map	                        (rev 0)
+++ trunk/msautotest/renderers/point_pixmap_gif.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,71 @@
+# entity-encoded text rendering test.
+# this test may potentially segfault
+MAP
+STATUS ON
+EXTENT 0 0 400 300
+SIZE 400 300
+FONTSET "../misc/fonts.lst"
+IMAGETYPE png24
+symbolset "symbolset"
+CONFIG MS_ERRORFILE "stderr"
+DEBUG ON
+LAYER
+  NAME "symbol"
+  TYPE point
+  STATUS default
+  CLASS
+    NAME "test1"
+    STYLE
+        SYMBOL "gdalicongif"
+    END
+  END
+  FEATURE
+    POINTS
+        50 50
+    END
+  END
+END
+LAYER
+  NAME "symbol rotated"
+  TYPE point
+  STATUS default
+  CLASS
+    NAME "test1"
+    STYLE
+        SIZE 55
+        ANGLE 45
+    END
+  END
+  FEATURE
+    POINTS
+        200 200
+    END
+  END
+END
+LAYER
+    NAME "anchors"
+    TYPE POINT
+    STATUS default
+    CLASS
+        STYLE
+            COLOR 255 0 0
+            SIZE 8
+            WIDTH 1
+            SYMBOL "circle"
+        END
+    END
+    FEATURE POINTS 50 50 END END
+    FEATURE POINTS 200 200 END END
+END
+END
Modified: trunk/msautotest/renderers/polygon-hatch.map
--- trunk/msautotest/renderers/polygon-hatch.map	2010-07-08 07:47:25 UTC (rev 10294)
+++ trunk/msautotest/renderers/polygon-hatch.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -38,7 +38,7 @@
         COLOR 180 180 180
         symbol "hatch"
         SIZE 20
-        WIDTH 10
+        WIDTH 14
         ANGLE 45
     END
   END
Added: trunk/msautotest/renderers/symbolset
--- trunk/msautotest/renderers/symbolset	                        (rev 0)
+++ trunk/msautotest/renderers/symbolset	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,49 @@
+symbolset
+symbol
+    name "circle"
+    type ellipse
+    points 1 1 end
+    filled true
+end
+symbol
+    name "ellipse"
+    type ellipse
+    points 2 1 end
+    filled true
+end
+symbol
+    name "vector arrow"
+    type vector
+    points
+        0 1
+        3 1
+        -99 -99
+        2 0
+        3 1
+        2 2
+    end
+end
+symbol
+    name "ttf"
+    type truetype
+    font "default"
+    character "A"
+end
+symbol
+    name "gdalicon"
+    type pixmap
+    image "../misc/data/gdalicon.png"
+end
+symbol
+    name "gdalicongif"
+    type pixmap
+    image "../misc/data/gdalicon.gif"
+end
+end
Added: trunk/msautotest/renderers/transparent_layer.map
--- trunk/msautotest/renderers/transparent_layer.map	                        (rev 0)
+++ trunk/msautotest/renderers/transparent_layer.map	2010-07-08 07:48:48 UTC (rev 10295)
@@ -0,0 +1,60 @@
+MAP
+STATUS ON
+EXTENT -125.549477 -69.508628 101.670954 15.840339
+SIZE 400 300
+IMAGETYPE png24
+DEBUG ON
+SYMBOL
+    name "hatch"
+    type hatch
+end
+LAYER
+  NAME "world"
+  TYPE polygon
+  STATUS on
+  DATA "world_testpoly"
+  CLASS
+    NAME "test1"
+    STYLE
+        COLOR 180 0 0
+    END
+  END
+END
+LAYER
+  NAME "world2"
+  TYPE polygon
+  STATUS on
+  OPACITY 50
+  CLASS
+    NAME "test1"
+    STYLE
+        COLOR 0 0 0
+        symbol "hatch"
+        SIZE 20
+        WIDTH 14
+        ANGLE 45
+    END
+  END
+END
+END
+END
