[mapserver-commits] r10302 - branches/branch-5-6/docs/en/development
Thu Jul 8 10:42:59 EDT 2010
Author: jmckenna
Date: 2010-07-08 14:42:59 +0000 (Thu, 08 Jul 2010)
New Revision: 10302
   branches/branch-5-6/docs/en/development/documentation.txt
add more sphinx 1.0 notes
Modified: branches/branch-5-6/docs/en/development/documentation.txt
--- branches/branch-5-6/docs/en/development/documentation.txt	2010-07-08 13:43:37 UTC (rev 10301)
+++ branches/branch-5-6/docs/en/development/documentation.txt	2010-07-08 14:42:59 UTC (rev 10302)
@@ -88,7 +88,12 @@
        easy_install Sphinx
-   ...you should see message: "Finished processing dependencies for Sphinx"
+   ...you should see message: "Finished processing dependencies for Sphinx"
+   .. note::
+      Make sure you install Sphinx 1.0 or more recent.  See note above.
 #. inside the /docs directory, execute:
@@ -118,6 +123,10 @@
        sudo easy_install Sphinx
+   .. note::
 #. to process the docs, from the MapServer /docs directory, run:
@@ -146,6 +155,10 @@
+   .. note::
 # install MacTex from http://www.tug.org/mactex/2009/ if you want to build pdfs
