[mapserver-commits] r10316 - branches/branch-5-0/mapserver
Thu Jul 8 17:13:49 EDT 2010
Author: dmorissette
Date: 2010-07-08 21:13:49 +0000 (Thu, 08 Jul 2010)
New Revision: 10316
   branches/branch-5-0/mapserver/HISTORY.TXT
   branches/branch-5-0/mapserver/README.CONFIGURE
   branches/branch-5-0/mapserver/configure
   branches/branch-5-0/mapserver/configure.in
   branches/branch-5-0/mapserver/mapserv.c
Disable insecure mapserv cgi command-line debug params by default (#3485)
Modified: branches/branch-5-0/mapserver/HISTORY.TXT
--- branches/branch-5-0/mapserver/HISTORY.TXT	2010-07-08 21:12:37 UTC (rev 10315)
+++ branches/branch-5-0/mapserver/HISTORY.TXT	2010-07-08 21:13:49 UTC (rev 10316)
@@ -13,9 +13,18 @@
 Current Version (SVN branch, may never be released):
+- Disabled some insecure (and potentially exploitable) mapserv command-line
+  debug arguments (#3485). The --enable-cgi-cl-debug-args configure switch
+  can be used to re-enable them for devs who really cannot get away without
+  them and who understand the potential security risk (not recommended for
+  production servers or those who don't understand the security implications).
+- Fixed possible buffer overflow in msTmpFile() (#3484)
 - Changing imagepath and imageurl no longer allowed via URL (#1836)
-- Fixed several security issues found in an audit of the CGI application (#2939, #2941, #2942, #2944)
+- Fixed several security issues found in an audit of the CGI application
+ (#2939, #2941, #2942, #2944)
 - Fix for CVE-2009-0840 security vulnerability (#2943)
Modified: branches/branch-5-0/mapserver/README.CONFIGURE
--- branches/branch-5-0/mapserver/README.CONFIGURE	2010-07-08 21:12:37 UTC (rev 10315)
+++ branches/branch-5-0/mapserver/README.CONFIGURE	2010-07-08 21:13:49 UTC (rev 10316)
@@ -54,6 +54,12 @@
   --disable-fast-nint     Use safe MS_NINT with reliable rounding
   --enable-debug          Include "-g" in CFLAGS for debugging.
   --disable-debug         Do not include "-g" in CFLAGS (the default).
+  --enable-cgi-cl-debug-args
+                          Enable mapserv CGI command-line debug arguments
+                          (disabled by default). These command-line args may
+                          be insecure and should be enabled only on
+                          development servers and only if you understand the
+                          security implications.
   --enable-gcov           Enable source code coverage testing using gcov
   --enable-perlv-ld-detect (applies to --with-php only)
                           Use perl -V output to figure the command to use to
@@ -629,6 +635,15 @@
Modified: branches/branch-5-0/mapserver/configure
--- branches/branch-5-0/mapserver/configure	2010-07-08 21:12:37 UTC (rev 10315)
+++ branches/branch-5-0/mapserver/configure	2010-07-08 21:13:49 UTC (rev 10316)
@@ -819,6 +819,12 @@
@@ -1005,7 +1011,7 @@
     else
       echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
     fi
-    cd "$ac_popdir"
+    cd $ac_popdir
   done
 fi
@@ -1921,7 +1927,8 @@
   cat conftest.err >&5
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); } &&
-	 { ac_try='test -z "$ac_c_werror_flag"			 || test ! -s conftest.err'
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
   { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -1979,7 +1986,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2095,7 +2103,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2149,7 +2158,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2194,7 +2204,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2238,7 +2249,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2422,7 +2434,8 @@
-	 { ac_try='test -z "$ac_cxx_werror_flag"			 || test ! -s conftest.err'
+	 { ac_try='test -z "$ac_cxx_werror_flag"
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2480,7 +2493,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2551,7 +2565,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2595,7 +2610,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2790,7 +2806,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2856,7 +2873,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -2945,7 +2963,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3054,7 +3073,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3117,7 +3137,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3181,7 +3202,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3257,7 +3279,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3327,7 +3350,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3644,7 +3668,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3857,7 +3882,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -3952,7 +3978,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4047,7 +4074,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4142,7 +4170,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4237,7 +4266,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4451,7 +4481,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4620,7 +4651,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4769,7 +4801,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -4924,7 +4957,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5007,7 +5041,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5153,7 +5188,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5268,7 +5304,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5335,7 +5372,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5439,7 +5477,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5506,7 +5545,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5674,7 +5714,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5746,7 +5787,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5859,7 +5901,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -5931,7 +5974,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6058,7 +6102,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6126,7 +6171,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6194,7 +6240,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6262,7 +6309,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6331,7 +6379,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6400,7 +6449,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6469,7 +6519,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6538,7 +6589,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6612,7 +6664,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6685,7 +6738,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6752,7 +6806,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6819,7 +6874,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6886,7 +6942,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -6954,7 +7011,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7022,7 +7080,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7090,7 +7149,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7158,7 +7218,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7335,7 +7396,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7410,7 +7472,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7485,7 +7548,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7560,7 +7624,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7635,7 +7700,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7710,7 +7776,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7797,7 +7864,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7864,7 +7932,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7931,7 +8000,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -7998,7 +8068,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8065,7 +8136,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8132,7 +8204,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8409,7 +8482,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8476,7 +8550,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8614,7 +8689,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8725,7 +8801,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8849,7 +8926,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8913,7 +8991,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -8974,7 +9053,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9035,7 +9115,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9128,7 +9209,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9189,7 +9271,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9250,7 +9333,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -9795,7 +9879,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -10586,7 +10671,8 @@
   (eval $ac_try) 2>&5
   ac_status=$?
@@ -10897,6 +10983,21 @@
   CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
 fi
+{ echo "$as_me:$LINENO: checking whether we should enable mapserv CGI command-line debug arguments..." >&5
+echo "$as_me: checking whether we should enable mapserv CGI command-line debug arguments..." >&6;}
+# Check whether --enable-cgi-cl-debug-args or --disable-cgi-cl-debug-args was given.
+if test "${enable_cgi_cl_debug_args+set}" = set; then
+  enableval="$enable_cgi_cl_debug_args"
+fi;
+if test "$enable_cgi_cl_debug_args" = "yes" ; then
+  DEBUG_FLAGS="$DEBUG_FLAGS -DMS_ENABLE_CGI_CL_DEBUG_ARGS"
+  echo "$as_me:$LINENO: result:         Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&5
+echo "${ECHO_T}        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&6
+fi
 DEBUG_FLAGS=$DEBUG_FLAGS
 ALL_ENABLED="$DEBUG_FLAGS $ALL_ENABLED"
@@ -12535,6 +12636,11 @@
+  if test x"$ac_file" != x-; then
+    { echo "$as_me:$LINENO: creating $ac_file" >&5
+echo "$as_me: creating $ac_file" >&6;}
+    rm -f "$ac_file"
+  fi
   # Let's still pretend it is `configure' which instantiates (i.e., don't
   # use $as_me), people would be surprised to read:
   #    /* config.h.  Generated by config.status.  */
@@ -12573,12 +12679,6 @@
 	 fi;;
       esac
     done` || { (exit 1); exit 1; }
-  if test x"$ac_file" != x-; then
-    { echo "$as_me:$LINENO: creating $ac_file" >&5
-echo "$as_me: creating $ac_file" >&6;}
-    rm -f "$ac_file"
-  fi
 _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF
   sed "$ac_vpsub
Modified: branches/branch-5-0/mapserver/configure.in
--- branches/branch-5-0/mapserver/configure.in	2010-07-08 21:12:37 UTC (rev 10315)
+++ branches/branch-5-0/mapserver/configure.in	2010-07-08 21:13:49 UTC (rev 10316)
@@ -2011,6 +2011,24 @@
 fi
+dnl ---------------------------------------------------------------------
+dnl Check --enable-cgi-cl-debug-args option (OFF by default)
+AC_CHECKING(whether we should enable mapserv CGI command-line debug arguments)
+AC_ARG_ENABLE(cgi-cl-debug-args,
+[  --enable-cgi-cl-debug-args
+                          security implications.],,)
+  AC_MSG_RESULT([        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS.])
+fi
 AC_SUBST(DEBUG_FLAGS, $DEBUG_FLAGS)
Modified: branches/branch-5-0/mapserver/mapserv.c
--- branches/branch-5-0/mapserver/mapserv.c	2010-07-08 21:12:37 UTC (rev 10315)
+++ branches/branch-5-0/mapserver/mapserv.c	2010-07-08 21:13:49 UTC (rev 10316)
@@ -1072,11 +1072,21 @@
   /*      purposes, and to query the version info.                        */
   for( iArg = 1; iArg < argc; iArg++ ) {
+    /* Keep only "-v" and "QUERY_STRING=..." enabled by default.
+     * The others will require an explicit -DMS_ENABLE_CGI_CL_DEBUG_ARGS
+     * at compile time.
     if( strcmp(argv[iArg],"-v") == 0 ) {
       printf("%s\n", msGetVersion());
       fflush(stdout);
       exit(0);
-    } else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
+    } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0 ) {
+      /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
+      putenv( "REQUEST_METHOD=GET" );
+      putenv( argv[iArg] );
+#ifdef MS_ENABLE_CGI_CL_DEBUG_ARGS
+    else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
       msForceTmpFileBase( argv[++iArg] );
     } else if( iArg < argc-1 && strcmp(argv[iArg], "-t") == 0) {
       char **tokens;
@@ -1092,11 +1102,9 @@
       exit(0);
-    } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0) {
-      /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
-      putenv( "REQUEST_METHOD=GET" );
-      putenv( argv[1] );
-    } else {
+#endif /* MS_ENABLE_CGI_CL_DEBUG_ARGS */
+    else {
       /* we don't produce a usage message as some web servers pass junk arguments */
