[mapserver-commits] r10319 - trunk/mapserver
Thu Jul 8 17:30:02 EDT 2010
Author: dmorissette
Date: 2010-07-08 21:30:02 +0000 (Thu, 08 Jul 2010)
New Revision: 10319
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/README.CONFIGURE
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/mapserv.c
Disable insecure mapserv cgi command-line debug params by default (#3485)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-07-08 21:26:54 UTC (rev 10318)
+++ trunk/mapserver/HISTORY.TXT	2010-07-08 21:30:02 UTC (rev 10319)
@@ -14,6 +14,12 @@
 Current Version (SVN trunk):
+- Disabled some insecure (and potentially exploitable) mapserv command-line
+  debug arguments (#3485). The --enable-cgi-cl-debug-args configure switch
+  can be used to re-enable them for devs who really cannot get away without
+  them and who understand the potential security risk (not recommended for
+  production servers or those who don't understand the security implications).
 - Fixed possible buffer overflow in msTmpFile() (#3484)
 - Fixed Using STYLEITEM AUTO, loadExpression fails when the label text contains a double quote (#3481)
Modified: trunk/mapserver/README.CONFIGURE
--- trunk/mapserver/README.CONFIGURE	2010-07-08 21:26:54 UTC (rev 10318)
+++ trunk/mapserver/README.CONFIGURE	2010-07-08 21:30:02 UTC (rev 10319)
@@ -54,6 +54,12 @@
   --disable-fast-nint     Use safe MS_NINT with reliable rounding
   --enable-debug          Include "-g" in CFLAGS for debugging.
   --disable-debug         Do not include "-g" in CFLAGS (the default).
+  --enable-cgi-cl-debug-args
+                          Enable mapserv CGI command-line debug arguments
+                          (disabled by default). These command-line args may
+                          be insecure and should be enabled only on
+                          development servers and only if you understand the
+                          security implications.
   --enable-gcov           Enable source code coverage testing using gcov
   --enable-perlv-ld-detect (applies to --with-php only)
                           Use perl -V output to figure the command to use to
@@ -673,6 +679,15 @@
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2010-07-08 21:26:54 UTC (rev 10318)
+++ trunk/mapserver/configure	2010-07-08 21:30:02 UTC (rev 10319)
@@ -857,6 +857,12 @@
@@ -12979,6 +12985,21 @@
   CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
 fi
+{ echo "$as_me:$LINENO: checking whether we should enable mapserv CGI command-line debug arguments..." >&5
+echo "$as_me: checking whether we should enable mapserv CGI command-line debug arguments..." >&6;}
+# Check whether --enable-cgi-cl-debug-args or --disable-cgi-cl-debug-args was given.
+if test "${enable_cgi_cl_debug_args+set}" = set; then
+  enableval="$enable_cgi_cl_debug_args"
+fi;
+if test "$enable_cgi_cl_debug_args" = "yes" ; then
+  DEBUG_FLAGS="$DEBUG_FLAGS -DMS_ENABLE_CGI_CL_DEBUG_ARGS"
+  echo "$as_me:$LINENO: result:         Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&5
+echo "${ECHO_T}        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS." >&6
+fi
 DEBUG_FLAGS=$DEBUG_FLAGS
 ALL_ENABLED="$DEBUG_FLAGS $ALL_ENABLED"
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2010-07-08 21:26:54 UTC (rev 10318)
+++ trunk/mapserver/configure.in	2010-07-08 21:30:02 UTC (rev 10319)
@@ -2447,6 +2447,24 @@
 fi
+dnl ---------------------------------------------------------------------
+dnl Check --enable-cgi-cl-debug-args option (OFF by default)
+AC_CHECKING(whether we should enable mapserv CGI command-line debug arguments)
+AC_ARG_ENABLE(cgi-cl-debug-args,
+[  --enable-cgi-cl-debug-args
+                          security implications.],,)
+  AC_MSG_RESULT([        Enabling (potentially insecure) mapserv CGI command-line debug arguments: -DMS_ENABLE_CGI_CL_DEBUG_ARGS.])
+fi
 AC_SUBST(DEBUG_FLAGS, $DEBUG_FLAGS)
Modified: trunk/mapserver/mapserv.c
--- trunk/mapserver/mapserv.c	2010-07-08 21:26:54 UTC (rev 10318)
+++ trunk/mapserver/mapserv.c	2010-07-08 21:30:02 UTC (rev 10319)
@@ -1139,13 +1139,23 @@
   /*      purposes, and to query the version info.                        */
   for( iArg = 1; iArg < argc; iArg++ ) {
+    /* Keep only "-v", "-nh" and "QUERY_STRING=..." enabled by default.
+     * The others will require an explicit -DMS_ENABLE_CGI_CL_DEBUG_ARGS
+     * at compile time.
     if( strcmp(argv[iArg],"-v") == 0 ) {
       printf("%s\n", msGetVersion());
       fflush(stdout);
       exit(0);
     } else if(strcmp(argv[iArg], "-nh") == 0) {
       sendheaders = MS_FALSE;
-    } else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
+    } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0 ) {
+      /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
+      putenv( "REQUEST_METHOD=GET" );
+      putenv( argv[iArg] );
+#ifdef MS_ENABLE_CGI_CL_DEBUG_ARGS
+    else if( iArg < argc-1 && strcmp(argv[iArg], "-tmpbase") == 0) {
       msForceTmpFileBase( argv[++iArg] );
     } else if( iArg < argc-1 && strcmp(argv[iArg], "-t") == 0) {
       char **tokens;
@@ -1161,16 +1171,13 @@
       exit(0);
-    } else if( strncmp(argv[iArg], "QUERY_STRING=", 13) == 0 ||
-               strncmp(argv[iArg], "XMLPOST_QUERY_STRING=", 13) == 0) {
-      /* Debugging hook... pass "QUERY_STRING=..." on the command-line */
-      putenv( "REQUEST_METHOD=GET" );
-      putenv( argv[iArg] );
     } else if( strncmp(argv[iArg], "MS_ERRORFILE=", 13) == 0 ) {
       msSetErrorFile( argv[iArg] + 13 );
     } else if( strncmp(argv[iArg], "MS_DEBUGLEVEL=", 14) == 0) {
       msSetGlobalDebugLevel( atoi(argv[iArg] + 14) );
-    } else {
+#endif /* MS_ENABLE_CGI_CL_DEBUG_ARGS */
+    else {
       /* we don't produce a usage message as some web servers pass junk arguments */
