[mapserver-commits] r10324 - sandbox/mapserver6
Fri Jul 9 03:09:13 EDT 2010
Author: tbonfort
Date: 2010-07-09 07:09:12 +0000 (Fri, 09 Jul 2010)
New Revision: 10324
   sandbox/mapserver6/mapimageio.c
libgif error reporting
Modified: sandbox/mapserver6/mapimageio.c
--- sandbox/mapserver6/mapimageio.c	2010-07-09 04:06:36 UTC (rev 10323)
+++ sandbox/mapserver6/mapimageio.c	2010-07-09 07:09:12 UTC (rev 10324)
@@ -833,6 +833,87 @@
+static char const *gif_error_msg() {
+  static char msg[80];
+  int code = GifLastError();
+  switch (code) {
+  case E_GIF_ERR_OPEN_FAILED: /* should not see this */
+    return "Failed to open given file";
+  case E_GIF_ERR_WRITE_FAILED:
+    return "Write failed";
+  case E_GIF_ERR_HAS_SCRN_DSCR: /* should not see this */
+    return "Screen descriptor already passed to giflib";
+  case E_GIF_ERR_HAS_IMAG_DSCR: /* should not see this */
+    return "Image descriptor already passed to giflib";
+  case E_GIF_ERR_NO_COLOR_MAP: /* should not see this */
+    return "Neither global nor local color map set";
+  case E_GIF_ERR_DATA_TOO_BIG: /* should not see this */
+    return "Too much pixel data passed to giflib";
+  case E_GIF_ERR_NOT_ENOUGH_MEM:
+    return "Out of memory";
+  case E_GIF_ERR_DISK_IS_FULL:
+    return "Disk is full";
+  case E_GIF_ERR_CLOSE_FAILED: /* should not see this */
+    return "File close failed";
+  case E_GIF_ERR_NOT_WRITEABLE: /* should not see this */
+    return "File not writable";
+  case D_GIF_ERR_OPEN_FAILED:
+    return "Failed to open file";
+  case D_GIF_ERR_READ_FAILED:
+    return "Failed to read from file";
+  case D_GIF_ERR_NOT_GIF_FILE:
+    return "File is not a GIF file";
+  case D_GIF_ERR_NO_SCRN_DSCR:
+    return "No screen descriptor detected - invalid file";
+  case D_GIF_ERR_NO_IMAG_DSCR:
+    return "No image descriptor detected - invalid file";
+  case D_GIF_ERR_NO_COLOR_MAP:
+    return "No global or local color map found";
+  case D_GIF_ERR_WRONG_RECORD:
+    return "Wrong record type detected - invalid file?";
+  case D_GIF_ERR_DATA_TOO_BIG:
+    return "Data in file too big for image";
+  case D_GIF_ERR_NOT_ENOUGH_MEM:
+  case D_GIF_ERR_CLOSE_FAILED:
+    return "Close failed";
+  case D_GIF_ERR_NOT_READABLE:
+    return "File not opened for read";
+  case D_GIF_ERR_IMAGE_DEFECT:
+    return "Defective image";
+  case D_GIF_ERR_EOF_TOO_SOON:
+    return "Unexpected EOF - invalid file";
+  default:
+    sprintf(msg, "Unknown giflib error code %d", code);
+    return msg;
 /* not fully implemented and tested */
 /* missing: set the first pointer to a,r,g,b */
 int readGIF(FILE *stream, rasterBufferObj *rb)
@@ -852,7 +933,7 @@
    rb->type = MS_BUFFER_BYTE_RGBA;
    image =  DGifOpenFileHandle(fileno(stream));
    if (image == NULL) {
-      msSetError(MS_MISCERR,"failed to load gif image","readGIF()");
+	  msSetError(MS_MISCERR,"failed to load gif image: %s","readGIF()", gif_error_msg());
       return MS_FAILURE;
    rb->width = image->SWidth;
@@ -880,7 +961,7 @@
    do
       if (DGifGetRecordType(image, &recordType) == GIF_ERROR) {
-         msSetError(MS_MISCERR,"corrupted gif image?","readGIF()");
+         msSetError(MS_MISCERR,"corrupted gif image?: %s","readGIF()", gif_error_msg());
          return MS_FAILURE;
@@ -891,7 +972,7 @@
          break;
       case IMAGE_DESC_RECORD_TYPE:
          if (DGifGetImageDesc(image) == GIF_ERROR) {
             return MS_FAILURE;
          if (!firstImageRead)
@@ -919,7 +1000,7 @@
                      g = rb->data.rgba.g + offset;
                      b = rb->data.rgba.b + offset;
                      if (DGifGetLine(image, line, width) == GIF_ERROR) {
+                        msSetError(MS_MISCERR,"corrupted gif image?: %s","readGIF()",gif_error_msg());
                         return MS_FAILURE;
@@ -948,7 +1029,7 @@
                      return MS_FAILURE;
                   for(j=0; j<width; j++) {
@@ -974,12 +1055,12 @@
          else
          {  /* Skip all next images */
             if (DGifGetCode(image, &codeSize, &codeBlock) == GIF_ERROR) {
                return MS_FAILURE;
             while (codeBlock != NULL) {
                if (DGifGetCodeNext(image, &codeBlock) == GIF_ERROR) {
                   return MS_FAILURE;
@@ -988,14 +1069,14 @@
       case EXTENSION_RECORD_TYPE:
          /* skip all extension blocks */
          if (DGifGetExtension(image, &extCode, &extension) == GIF_ERROR) {
             return MS_FAILURE;
          if(extCode == 249 && (extension[1] & 1))
             transIdx = extension[4];
          for (;;) {
             if (DGifGetExtensionNext(image, &extension) == GIF_ERROR) {
                return MS_FAILURE;
             if (extension == NULL)
@@ -1015,7 +1096,7 @@
    } while (recordType != TERMINATE_RECORD_TYPE);
    if (DGifCloseFile(image) == GIF_ERROR) {
-      msSetError(MS_MISCERR,"failed to close gif after loading","readGIF()");
+      msSetError(MS_MISCERR,"failed to close gif after loading: %s","readGIF()", gif_error_msg());
       return MS_FAILURE;
