[mapserver-commits] r10364 - trunk/msautotest/wxs/expected
Fri Jul 16 16:26:08 EDT 2010
Author: warmerdam
Date: 2010-07-16 20:26:08 +0000 (Fri, 16 Jul 2010)
New Revision: 10364
   trunk/msautotest/wxs/expected/wcs_cap.xml
   trunk/msautotest/wxs/expected/wcs_describe.xml
   trunk/msautotest/wxs/expected/wcs_get_caps.xml
   trunk/msautotest/wxs/expected/wfs_cap.xml
   trunk/msautotest/wxs/expected/wfs_describe.xml
   trunk/msautotest/wxs/expected/wfs_describe_feature_type_gml2.xml
   trunk/msautotest/wxs/expected/wfs_describe_feature_type_gml3l0.xml
   trunk/msautotest/wxs/expected/wfs_filter_bbox.xml
   trunk/msautotest/wxs/expected/wfs_filter_dwithin.xml
   trunk/msautotest/wxs/expected/wfs_filter_greater_than_or_equalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_intersects.xml
   trunk/msautotest/wxs/expected/wfs_filter_is_not_equal.xml
   trunk/msautotest/wxs/expected/wfs_filter_isbetween.xml
   trunk/msautotest/wxs/expected/wfs_filter_isbetween_and_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_isbetween_and_not_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_isbetween_or_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto_reverse.xml
   trunk/msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto_reverse.xml
   trunk/msautotest/wxs/expected/wfs_filter_isgreater_than.xml
   trunk/msautotest/wxs/expected/wfs_filter_isless_than.xml
   trunk/msautotest/wxs/expected/wfs_filter_isless_than_or_equalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_islike.xml
   trunk/msautotest/wxs/expected/wfs_filter_not_isequalto.xml
   trunk/msautotest/wxs/expected/wfs_filter_property_is_equal.xml
   trunk/msautotest/wxs/expected/wfs_get_caps.xml
   trunk/msautotest/wxs/expected/wfs_get_feature.xml
   trunk/msautotest/wxs/expected/wfs_get_feature_gml2.xml
   trunk/msautotest/wxs/expected/wfs_get_feature_gml3l0.xml
   trunk/msautotest/wxs/expected/wms_cap.xml
   trunk/msautotest/wxs/expected/wms_describe.xml
   trunk/msautotest/wxs/expected/wms_describe_layer.xml
   trunk/msautotest/wxs/expected/wms_get_caps.xml
   trunk/msautotest/wxs/expected/wms_get_feature_info_raster.html
   trunk/msautotest/wxs/expected/wms_get_feature_info_vector.html
   trunk/msautotest/wxs/expected/wms_time_cap.xml
   trunk/msautotest/wxs/expected/wms_time_no_default_value.xml
   trunk/msautotest/wxs/expected/wms_time_out_of_extents_multi.xml
   trunk/msautotest/wxs/expected/wms_time_out_of_extents_multi_ranges.xml
   trunk/msautotest/wxs/expected/wms_time_out_of_extents_single.xml
   trunk/msautotest/wxs/expected/wms_time_out_of_extents_single_range.xml
remove binary type from xml and html files
Property changes on: trunk/msautotest/wxs/expected/wcs_cap.xml
___________________________________________________________________
Deleted: svn:mime-type
   - application/octet-stream
Property changes on: trunk/msautotest/wxs/expected/wcs_describe.xml
Property changes on: trunk/msautotest/wxs/expected/wcs_get_caps.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_cap.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_describe.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_describe_feature_type_gml2.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_describe_feature_type_gml3l0.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_bbox.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_dwithin.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_greater_than_or_equalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_intersects.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_is_not_equal.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isbetween.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isbetween_and_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isbetween_and_not_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isbetween_or_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isequalto_and_isequalto_reverse.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isequalto_or_isequalto_reverse.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isgreater_than.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isless_than.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_isless_than_or_equalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_islike.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_not_isequalto.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_filter_property_is_equal.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_get_caps.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_get_feature.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_get_feature_gml2.xml
Property changes on: trunk/msautotest/wxs/expected/wfs_get_feature_gml3l0.xml
Property changes on: trunk/msautotest/wxs/expected/wms_cap.xml
   - text/xml
Property changes on: trunk/msautotest/wxs/expected/wms_describe.xml
Property changes on: trunk/msautotest/wxs/expected/wms_describe_layer.xml
Property changes on: trunk/msautotest/wxs/expected/wms_get_caps.xml
Property changes on: trunk/msautotest/wxs/expected/wms_get_feature_info_raster.html
Property changes on: trunk/msautotest/wxs/expected/wms_get_feature_info_vector.html
Property changes on: trunk/msautotest/wxs/expected/wms_time_cap.xml
Property changes on: trunk/msautotest/wxs/expected/wms_time_no_default_value.xml
Property changes on: trunk/msautotest/wxs/expected/wms_time_out_of_extents_multi.xml
Property changes on: trunk/msautotest/wxs/expected/wms_time_out_of_extents_multi_ranges.xml
Property changes on: trunk/msautotest/wxs/expected/wms_time_out_of_extents_single.xml
Property changes on: trunk/msautotest/wxs/expected/wms_time_out_of_extents_single_range.xml
