[mapserver-commits] r10372 - trunk/msautotest/wxs
Sat Jul 17 10:04:22 EDT 2010
Author: warmerdam
Date: 2010-07-17 14:04:22 +0000 (Sat, 17 Jul 2010)
New Revision: 10372
   trunk/msautotest/wxs/wms_sld_proj.map
updated to use EPSG:3978
Modified: trunk/msautotest/wxs/wms_sld_proj.map
--- trunk/msautotest/wxs/wms_sld_proj.map	2010-07-17 02:42:14 UTC (rev 10371)
+++ trunk/msautotest/wxs/wms_sld_proj.map	2010-07-17 14:04:22 UTC (rev 10372)
@@ -42,14 +42,19 @@
   METADATA
     "wms_title"		   "Test simple wms"
     "wms_onlineresource"   "http://localhost/path/to/wms_simple?"
-    "wms_srs"		   "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
+    "wms_srs"		   "EPSG:3978 EPSG:42101 EPSG:4269 EPSG:4326"
     "ows_schemas_location" "http://ogc.dmsolutions.ca"
   END
 END
 PROJECTION
-#  "init=./data/epsg2:42304"
-  "init=epsg:42304"
+  "init=epsg:3978"
+# Note, EPSG:3978 may require a fairly new epsg dictionary.  If you don't have
+# it, enter it as follow.  This also used to be known as 42304 in data/epsg2.
+# NAD83 / Canada Atlas Lambert
+# <3978> +proj=lcc +lat_1=49 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs  <>
 END
@@ -70,8 +75,7 @@
   TYPE POINT
   STATUS ON
   PROJECTION
-    "init=epsg:42304"
+    "init=epsg:3978"
   END
   DUMP TRUE
@@ -97,8 +101,7 @@
   TYPE POINT
   STATUS ON
   PROJECTION
-    "init=epsg:42304"
+    "init=epsg:3978"
   END
   DUMP TRUE
@@ -134,8 +137,7 @@
   TYPE LINE
   STATUS ON
   PROJECTION
-    "init=epsg:42304"
+    "init=epsg:3978"
   END
   DUMP TRUE
