[mapserver-commits] r10374 - trunk/mapserver
Sat Jul 17 10:44:37 EDT 2010
Author: warmerdam
Date: 2010-07-17 14:44:37 +0000 (Sat, 17 Jul 2010)
New Revision: 10374
   trunk/mapserver/mapogcfilter.c
more attempts to return errors in reprojection (#3495)
Modified: trunk/mapserver/mapogcfilter.c
--- trunk/mapserver/mapogcfilter.c	2010-07-17 14:38:41 UTC (rev 10373)
+++ trunk/mapserver/mapogcfilter.c	2010-07-17 14:44:37 UTC (rev 10374)
@@ -153,7 +153,7 @@
     return MS_TRUE;
-int FTLParseEpsgString(char *pszEpsg, projectionObj *psProj)
+int FLTParseEpsgString(char *pszEpsg, projectionObj *psProj)
     int nStatus = MS_FALSE;
     int nTokens = 0;
@@ -329,8 +329,14 @@
     if(szEPSG && map->projection.numargs > 0)
-        if (FTLParseEpsgString(szEPSG, &sProjTmp))
-          msProjectRect(&sProjTmp, &map->projection, &sQueryRect);
+        if (FLTParseEpsgString(szEPSG, &sProjTmp))
+            if( msProjectRect(&sProjTmp, &map->projection, &sQueryRect)
+                != MS_SUCCESS )
+                return MS_FAILURE;
+        else
@@ -343,11 +349,17 @@
     } else if (bPointQuery && psQueryShape && psQueryShape->numlines > 0
              && psQueryShape->line[0].numpoints > 0) /* && dfDistance >=0) */
-        if (psNode->pszSRS &&  map->projection.numargs > 0 &&
-            FTLParseEpsgString(psNode->pszSRS, &sProjTmp))
-           msProjectShape(&sProjTmp, &map->projection, psQueryShape);
+        if (psNode->pszSRS &&  map->projection.numargs > 0 )
+            if( !FLTParseEpsgString(psNode->pszSRS, &sProjTmp) )
-      if (bUseGeos)
+            status = msProjectShape(&sProjTmp, &map->projection, psQueryShape);
+            if( status != MS_SUCCESS )
+                return status;
+        if (bUseGeos)
             if ((strcasecmp(psNode->pszValue, "DWithin") == 0 ||
                  strcasecmp(psNode->pszValue, "Beyond") == 0 ) &&
@@ -405,7 +417,7 @@
         /*reproject shape if epsg was set*/
-            if( !FTLParseEpsgString(psNode->pszSRS, &sProjTmp) )
                 return MS_FAILURE;
