[mapserver-commits] r10423 - sandbox/sdlime/common-expressions/mapserver
Fri Jul 30 00:27:01 EDT 2010
Author: sdlime
Date: 2010-07-30 04:27:01 +0000 (Fri, 30 Jul 2010)
New Revision: 10423
   sandbox/sdlime/common-expressions/mapserver/mapparser.c
   sandbox/sdlime/common-expressions/mapserver/mapparser.y
   sandbox/sdlime/common-expressions/mapserver/mapquery.c
Added default double => string conversion for string parsing context.
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.c
--- sandbox/sdlime/common-expressions/mapserver/mapparser.c	2010-07-30 04:03:30 UTC (rev 10422)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.c	2010-07-30 04:27:01 UTC (rev 10423)
@@ -394,14 +394,14 @@
 /* YYRLINE[YYN] -- source line where rule number YYN was defined.  */
 static const unsigned short int yyrline[] =
-       0,    66,    66,    67,    80,    86,   102,   110,   119,   127,
-     136,   144,   153,   161,   170,   171,   172,   185,   198,   204,
-     210,   216,   222,   228,   234,   235,   243,   251,   260,   268,
-     276,   284,   290,   296,   302,   308,   314,   320,   341,   362,
-     368,   376,   383,   394,   405,   416,   427,   438,   449,   460,
-     471,   481,   493,   494,   495,   496,   497,   498,   499,   506,
-     507,   508,   509,   517,   520,   521,   522,   534,   535,   536,
-     540,   544,   550,   551
+       0,    66,    66,    67,    80,    94,   110,   118,   127,   135,
+     144,   152,   161,   169,   178,   179,   180,   193,   206,   212,
+     218,   224,   230,   236,   242,   243,   251,   259,   268,   276,
+     284,   292,   298,   304,   310,   316,   322,   328,   349,   370,
+     376,   384,   391,   402,   413,   424,   435,   446,   457,   468,
+     479,   489,   501,   502,   503,   504,   505,   506,   507,   514,
+     515,   516,   517,   525,   528,   529,   530,   542,   543,   544,
+     548,   552,   558,   559
 #endif
@@ -1282,15 +1282,23 @@
   case 4:
 #line 80 "mapparser.y"
-      if((yyvsp[0].dblval) != 0)
-        yypresult.intval = MS_TRUE;
-      else
-        yypresult.intval = MS_FALSE;
+      switch(yypresult_type) {
+      case(MS_PARSE_RESULT_BOOLEAN):
+        if((yyvsp[0].dblval) != 0)
+          yypresult.intval = MS_TRUE;
+        else
+          yypresult.intval = MS_FALSE;
+        break;
+      case(MS_PARSE_RESULT_STRING):
+        yypresult.strval = (char *)malloc(64); // ok?
+        snprintf(yypresult.strval, 64, "%g", (yyvsp[0].dblval));
+        break;
     break;
   case 5:
-#line 86 "mapparser.y"
+#line 94 "mapparser.y"
@@ -1307,7 +1315,7 @@
     break;
   case 6:
-#line 102 "mapparser.y"
+#line 110 "mapparser.y"
 	                                 if((yyvsp[-2].intval) == MS_TRUE)
 		                           (yyval.intval) = MS_TRUE;
@@ -1319,7 +1327,7 @@
     break;
   case 7:
-#line 110 "mapparser.y"
+#line 118 "mapparser.y"
 	                                 if((yyvsp[-2].intval) == MS_TRUE) {
 			                   if((yyvsp[0].intval) == MS_TRUE)
@@ -1332,7 +1340,7 @@
     break;
   case 8:
-#line 119 "mapparser.y"
+#line 127 "mapparser.y"
@@ -1344,7 +1352,7 @@
     break;
   case 9:
-#line 127 "mapparser.y"
+#line 135 "mapparser.y"
@@ -1357,7 +1365,7 @@
     break;
   case 10:
-#line 136 "mapparser.y"
+#line 144 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != 0)
@@ -1369,7 +1377,7 @@
     break;
   case 11:
-#line 144 "mapparser.y"
+#line 152 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != 0) {
@@ -1382,7 +1390,7 @@
     break;
   case 12:
-#line 153 "mapparser.y"
+#line 161 "mapparser.y"
@@ -1394,7 +1402,7 @@
     break;
   case 13:
-#line 161 "mapparser.y"
+#line 169 "mapparser.y"
@@ -1407,17 +1415,17 @@
     break;
   case 14:
-#line 170 "mapparser.y"
+#line 178 "mapparser.y"
     { (yyval.intval) = !(yyvsp[0].intval); }
     break;
   case 15:
-#line 171 "mapparser.y"
+#line 179 "mapparser.y"
     { (yyval.intval) = !(yyvsp[0].dblval); }
     break;
   case 16:
-#line 172 "mapparser.y"
+#line 180 "mapparser.y"
                                          ms_regex_t re;
@@ -1434,7 +1442,7 @@
     break;
   case 17:
-#line 185 "mapparser.y"
+#line 193 "mapparser.y"
                                          ms_regex_t re;
@@ -1451,7 +1459,7 @@
     break;
   case 18:
-#line 198 "mapparser.y"
+#line 206 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) == (yyvsp[0].dblval))
@@ -1461,7 +1469,7 @@
     break;
   case 19:
-#line 204 "mapparser.y"
+#line 212 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) != (yyvsp[0].dblval))
@@ -1471,7 +1479,7 @@
     break;
   case 20:
-#line 210 "mapparser.y"
+#line 218 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) > (yyvsp[0].dblval))
@@ -1481,7 +1489,7 @@
     break;
   case 21:
-#line 216 "mapparser.y"
+#line 224 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) < (yyvsp[0].dblval))
@@ -1491,7 +1499,7 @@
     break;
   case 22:
-#line 222 "mapparser.y"
+#line 230 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) >= (yyvsp[0].dblval))
@@ -1501,7 +1509,7 @@
     break;
   case 23:
-#line 228 "mapparser.y"
+#line 236 "mapparser.y"
 	                                 if((yyvsp[-2].dblval) <= (yyvsp[0].dblval))
@@ -1511,12 +1519,12 @@
     break;
   case 24:
-#line 234 "mapparser.y"
+#line 242 "mapparser.y"
     { (yyval.intval) = (yyvsp[-1].intval); }
     break;
   case 25:
-#line 235 "mapparser.y"
+#line 243 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1528,7 +1536,7 @@
     break;
   case 26:
-#line 243 "mapparser.y"
+#line 251 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) != 0)
@@ -1540,7 +1548,7 @@
     break;
   case 27:
-#line 251 "mapparser.y"
+#line 259 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) > 0)
@@ -1553,7 +1561,7 @@
     break;
   case 28:
-#line 260 "mapparser.y"
+#line 268 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) < 0)
@@ -1565,7 +1573,7 @@
     break;
   case 29:
-#line 268 "mapparser.y"
+#line 276 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) >= 0)
@@ -1577,7 +1585,7 @@
     break;
   case 30:
-#line 276 "mapparser.y"
+#line 284 "mapparser.y"
                                          if(strcmp((yyvsp[-2].strval), (yyvsp[0].strval)) <= 0)
@@ -1589,7 +1597,7 @@
     break;
   case 31:
-#line 284 "mapparser.y"
+#line 292 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) == 0)
@@ -1599,7 +1607,7 @@
     break;
   case 32:
-#line 290 "mapparser.y"
+#line 298 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) != 0)
@@ -1609,7 +1617,7 @@
     break;
   case 33:
-#line 296 "mapparser.y"
+#line 304 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) > 0)
@@ -1619,7 +1627,7 @@
     break;
   case 34:
-#line 302 "mapparser.y"
+#line 310 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) < 0)
@@ -1629,7 +1637,7 @@
     break;
   case 35:
-#line 308 "mapparser.y"
+#line 316 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) >= 0)
@@ -1639,7 +1647,7 @@
     break;
   case 36:
-#line 314 "mapparser.y"
+#line 322 "mapparser.y"
                                      if(msTimeCompare(&((yyvsp[-2].tmval)), &((yyvsp[0].tmval))) <= 0)
@@ -1649,7 +1657,7 @@
     break;
   case 37:
-#line 320 "mapparser.y"
+#line 328 "mapparser.y"
 					 char *delim,*bufferp;
@@ -1674,7 +1682,7 @@
     break;
   case 38:
-#line 341 "mapparser.y"
+#line 349 "mapparser.y"
@@ -1699,7 +1707,7 @@
     break;
   case 39:
-#line 362 "mapparser.y"
+#line 370 "mapparser.y"
@@ -1709,7 +1717,7 @@
     break;
   case 40:
-#line 368 "mapparser.y"
+#line 376 "mapparser.y"
                                          if(strcasecmp((yyvsp[-2].strval), (yyvsp[0].strval)) == 0)
@@ -1721,7 +1729,7 @@
     break;
   case 41:
-#line 376 "mapparser.y"
+#line 384 "mapparser.y"
@@ -1731,7 +1739,7 @@
     break;
   case 42:
-#line 383 "mapparser.y"
+#line 391 "mapparser.y"
       int rval;
       rval = msGEOSEquals((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1746,7 +1754,7 @@
     break;
   case 43:
-#line 394 "mapparser.y"
+#line 402 "mapparser.y"
       int rval;
       rval = msGEOSIntersects((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1761,7 +1769,7 @@
     break;
   case 44:
-#line 405 "mapparser.y"
+#line 413 "mapparser.y"
       int rval;
       rval = msGEOSDisjoint((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1776,7 +1784,7 @@
     break;
   case 45:
-#line 416 "mapparser.y"
+#line 424 "mapparser.y"
       int rval;
       rval = msGEOSTouches((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1791,7 +1799,7 @@
     break;
   case 46:
-#line 427 "mapparser.y"
+#line 435 "mapparser.y"
       int rval;
       rval = msGEOSOverlaps((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1806,7 +1814,7 @@
     break;
   case 47:
-#line 438 "mapparser.y"
+#line 446 "mapparser.y"
       int rval;
       rval = msGEOSCrosses((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1821,7 +1829,7 @@
     break;
   case 48:
-#line 449 "mapparser.y"
+#line 457 "mapparser.y"
       int rval;
       rval = msGEOSWithin((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1836,7 +1844,7 @@
     break;
   case 49:
-#line 460 "mapparser.y"
+#line 468 "mapparser.y"
       int rval;
@@ -1851,7 +1859,7 @@
     break;
   case 50:
-#line 471 "mapparser.y"
+#line 479 "mapparser.y"
       double d;
       d = msGEOSDistance((yyvsp[-2].shpval), (yyvsp[0].shpval));
@@ -1865,7 +1873,7 @@
     break;
   case 51:
-#line 481 "mapparser.y"
+#line 489 "mapparser.y"
       double d;
@@ -1879,32 +1887,32 @@
     break;
   case 53:
-#line 494 "mapparser.y"
+#line 502 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-1].dblval); }
     break;
   case 54:
-#line 495 "mapparser.y"
+#line 503 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) + (yyvsp[0].dblval); }
     break;
   case 55:
-#line 496 "mapparser.y"
+#line 504 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) - (yyvsp[0].dblval); }
     break;
   case 56:
-#line 497 "mapparser.y"
+#line 505 "mapparser.y"
     { (yyval.dblval) = (yyvsp[-2].dblval) * (yyvsp[0].dblval); }
     break;
   case 57:
-#line 498 "mapparser.y"
+#line 506 "mapparser.y"
     { (yyval.dblval) = (int)(yyvsp[-2].dblval) % (int)(yyvsp[0].dblval); }
     break;
   case 58:
-#line 499 "mapparser.y"
+#line 507 "mapparser.y"
       if((yyvsp[0].dblval) == 0.0) {
         yyerror("Division by zero.");
@@ -1915,22 +1923,22 @@
     break;
   case 59:
-#line 506 "mapparser.y"
+#line 514 "mapparser.y"
     { (yyval.dblval) = (yyvsp[0].dblval); }
     break;
   case 60:
-#line 507 "mapparser.y"
+#line 515 "mapparser.y"
     { (yyval.dblval) = pow((yyvsp[-2].dblval), (yyvsp[0].dblval)); }
     break;
   case 61:
-#line 508 "mapparser.y"
+#line 516 "mapparser.y"
     { (yyval.dblval) = strlen((yyvsp[-1].strval)); }
     break;
   case 62:
-#line 509 "mapparser.y"
+#line 517 "mapparser.y"
       if((yyvsp[-1].shpval)->type != MS_SHAPE_POLYGON) {
         yyerror("Area can only be computed for polygon shapes.");
@@ -1942,17 +1950,17 @@
     break;
   case 63:
-#line 517 "mapparser.y"
+#line 525 "mapparser.y"
     { (yyval.dblval) = (MS_NINT((yyvsp[-3].dblval)/(yyvsp[-1].dblval)))*(yyvsp[-1].dblval); }
     break;
   case 65:
-#line 521 "mapparser.y"
+#line 529 "mapparser.y"
     { (yyval.shpval) = (yyvsp[-1].shpval); }
     break;
   case 66:
-#line 522 "mapparser.y"
+#line 530 "mapparser.y"
       shapeObj *s;
       s = msShapeFromWKT((yyvsp[-1].strval));
@@ -1966,12 +1974,12 @@
     break;
   case 68:
-#line 535 "mapparser.y"
+#line 543 "mapparser.y"
     { (yyval.strval) = (yyvsp[-1].strval); }
     break;
   case 69:
-#line 536 "mapparser.y"
+#line 544 "mapparser.y"
       (yyval.strval) = (char *)malloc(strlen((yyvsp[-2].strval)) + strlen((yyvsp[0].strval)) + 1);
       sprintf((yyval.strval), "%s%s", (yyvsp[-2].strval), (yyvsp[0].strval)); free((yyvsp[-2].strval)); free((yyvsp[0].strval));
@@ -1979,7 +1987,7 @@
     break;
   case 70:
-#line 540 "mapparser.y"
+#line 548 "mapparser.y"
       (yyval.strval) = (char *) malloc(strlen((yyvsp[-1].strval)) + 64); /* Plenty big? Should use snprintf below... */
       sprintf((yyval.strval), (yyvsp[-1].strval), (yyvsp[-3].dblval));
@@ -1987,7 +1995,7 @@
     break;
   case 71:
-#line 544 "mapparser.y"
+#line 552 "mapparser.y"
       (yyvsp[-1].strval) = msCommifyString((yyvsp[-1].strval));
@@ -1995,7 +2003,7 @@
     break;
   case 73:
-#line 551 "mapparser.y"
+#line 559 "mapparser.y"
     { (yyval.tmval) = (yyvsp[-1].tmval); }
     break;
@@ -2003,7 +2011,7 @@
 /* Line 1037 of yacc.c.  */
-#line 2007 "mapparser.c"
+#line 2015 "mapparser.c"
   yyvsp -= yylen;
   yyssp -= yylen;
@@ -2231,7 +2239,7 @@
-#line 554 "mapparser.y"
+#line 562 "mapparser.y"
Modified: sandbox/sdlime/common-expressions/mapserver/mapparser.y
--- sandbox/sdlime/common-expressions/mapserver/mapparser.y	2010-07-30 04:03:30 UTC (rev 10422)
+++ sandbox/sdlime/common-expressions/mapserver/mapparser.y	2010-07-30 04:27:01 UTC (rev 10423)
@@ -78,10 +78,18 @@
   | math_exp {
-      if($1 != 0)
-      else
+        if($1 != 0)
+        else
+        break;
+        snprintf(yypresult.strval, 64, "%g", $1);
+        break;
   | string_exp {
Modified: sandbox/sdlime/common-expressions/mapserver/mapquery.c
--- sandbox/sdlime/common-expressions/mapserver/mapquery.c	2010-07-30 04:03:30 UTC (rev 10422)
+++ sandbox/sdlime/common-expressions/mapserver/mapquery.c	2010-07-30 04:27:01 UTC (rev 10423)
@@ -677,6 +677,171 @@
   return(MS_FAILURE);
+int msQueryByFilter(mapObj *map)
+  layerObj *lp;
+  int status;
+  int old_filtertype=-1;
+  char *old_filterstring=NULL, *old_filteritem=NULL;
+  rectObj searchrect;
+  shapeObj shape;
+  int nclasses = 0;
+  int *classgroup = NULL;
+  if(map->query.type != MS_QUERY_BY_ATTRIBUTE) {
+    msSetError(MS_QUERYERR, "The query is not properly defined.", "msQueryByAttribute()");
+    return(MS_FAILURE);
+  if(map->query.layer < 0 || map->query.layer >= map->numlayers) {
+    msSetError(MS_MISCERR, "No query layer defined.", "msQueryByAttributes()");
+  lp = (GET_LAYER(map, map->query.layer));
+  /* conditions may have changed since this layer last drawn, so set
+     layer->project true to recheck projection needs (Bug #673) */
+  lp->project = MS_TRUE;
+  /* free any previous search results, do now in case one of the following tests fails */
+  if(lp->resultcache) {
+    if(lp->resultcache->results) free(lp->resultcache->results);
+    free(lp->resultcache);
+    lp->resultcache = NULL;
+  if(!msIsLayerQueryable(lp)) {
+    msSetError(MS_QUERYERR, "Requested layer has no templates defined so is not queryable.", "msQueryByAttributes()");
+  if(!map->query.str) {
+    msSetError(MS_QUERYERR, "No query expression defined.", "msQueryByAttributes()");
+  /* save any previously defined filter */
+  if(lp->filter.string) {
+    old_filtertype = lp->filter.type;
+    old_filterstring = strdup(lp->filter.string);
+    if(lp->filteritem)
+      old_filteritem = strdup(lp->filteritem);
+  /* apply the passed query parameters */
+  if(map->query.item && map->query.item[0] != '\0')
+    lp->filteritem = strdup(map->query.item);
+  else
+    lp->filteritem = NULL;
+  msLoadExpressionString(&(lp->filter), map->query.str);
+  msInitShape(&shape);
+  /* open this layer */
+  status = msLayerOpen(lp);
+  if(status != MS_SUCCESS) {
+    msRestoreOldFilter(lp, old_filtertype, old_filteritem, old_filterstring); /* manually reset the filter */
+  /* build item list, we want *all* items */
+  status = msLayerWhichItems(lp, MS_TRUE, NULL);
+  /* identify candidate shapes */
+  searchrect = map->query.rect;
+#ifdef USE_PROJ
+  if(lp->project && msProjectionsDiffer(&(lp->projection), &(map->projection)))
+    msProjectRect(&(map->projection), &(lp->projection), &searchrect); /* project the searchrect to source coords */
+  else
+    lp->project = MS_FALSE;
+#endif
+  status = msLayerWhichShapes(lp, searchrect);
+  if(status == MS_DONE) { /* no overlap */
+    msLayerClose(lp);
+    msSetError(MS_NOTFOUND, "No matching record(s) found, layer and area of interest do not overlap.", "msQueryByAttributes()");
+  } else if(status != MS_SUCCESS) {
+    msLayerClose(lp);
+  lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /* allocate and initialize the result cache */
+  initResultCache( lp->resultcache);
+  nclasses = 0;
+  classgroup = NULL;
+  if (lp->classgroup && lp->numclasses > 0)
+    classgroup = msAllocateValidClassGroups(lp, &nclasses);
+  while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step through the shapes */
+    shape.classindex = msShapeGetClass(lp, &shape, map->scaledenom, classgroup, nclasses);
+    if(!(lp->template) && ((shape.classindex == -1) || (lp->class[shape.classindex]->status == MS_OFF))) { /* not a valid shape */
+      msFreeShape(&shape);
+      continue;
+    if(!(lp->template) && !(lp->class[shape.classindex]->template)) { /* no valid template */
+      continue;
+#ifdef USE_PROJ
+      msProjectShape(&(lp->projection), &(map->projection), &shape);
+    else
+#endif
+    addResult(lp->resultcache, shape.classindex, shape.index, shape.tileindex);
+    if(lp->resultcache->numresults == 1)
+      lp->resultcache->bounds = shape.bounds;
+    else
+      msMergeRect(&(lp->resultcache->bounds), &shape.bounds);
+    if(map->query.mode == MS_QUERY_SINGLE) { /* no need to look any further */
+      status = MS_DONE;
+      break;
+  if (classgroup)
+    msFree(classgroup);
+  if(status != MS_DONE) {
+    msLayerClose(lp);
+  /* was anything found? (if yes, don't close the layer) */
+  if(lp->resultcache && lp->resultcache->numresults > 0)
+    return(MS_SUCCESS);
+  msLayerClose(lp);
+  msSetError(MS_NOTFOUND, "No matching record(s) found.", "msQueryByAttributes()");
 int msQueryByRect(mapObj *map)
   int l; /* counters */
