[mapserver-commits] r10425 - trunk/docs/en/mapfile
Fri Jul 30 13:20:51 EDT 2010
Author: jmckenna
Date: 2010-07-30 17:20:51 +0000 (Fri, 30 Jul 2010)
New Revision: 10425
   trunk/docs/en/mapfile/map.txt
   trunk/docs/en/mapfile/web.txt
update debugging text (indirectly related to ticket:3135)
Modified: trunk/docs/en/mapfile/map.txt
--- trunk/docs/en/mapfile/map.txt	2010-07-30 17:13:40 UTC (rev 10424)
+++ trunk/docs/en/mapfile/map.txt	2010-07-30 17:20:51 UTC (rev 10425)
@@ -171,8 +171,9 @@
     The DEBUG setting can also be specified for a layer, by setting the DEBUG
     parameter in the :ref:`LAYER` object.
-    For more details on this debugging mechanism, please see :ref:`RFC28`.
+    For more details on this debugging mechanism, please see the :ref:`debugging`
+    document.
     *Debugging with MapServer versions < 5:*
     Verbose output is generated and sent to the standard error output (STDERR)
Modified: trunk/docs/en/mapfile/web.txt
--- trunk/docs/en/mapfile/web.txt	2010-07-30 17:13:40 UTC (rev 10424)
+++ trunk/docs/en/mapfile/web.txt	2010-07-30 17:20:51 UTC (rev 10425)
@@ -45,8 +45,13 @@
         LEGENDFORMAT "image/svg+xml"
 LOG [filename]
+    Since MapServer 5.0 the recommeded parameters to use for debugging are the :ref:`MAP`
+    object's CONFIG and DEBUG parameters instead (see the :ref:`debugging` document).
     File to log MapServer activity in. Must be writable by the user the web
     server is running as.
+    .. deprecated:: 5.0
 .. index::
     pair: MAXSCALEDENOM; WEB
