[mapserver-commits] r10428 - branches/branch-5-6/docs/en/mapfile
Fri Jul 30 14:12:21 EDT 2010
Author: jmckenna
Date: 2010-07-30 18:12:21 +0000 (Fri, 30 Jul 2010)
New Revision: 10428
   branches/branch-5-6/docs/en/mapfile/layer.txt
add wfs connectiontype and mygis note (ticket:3135)
Modified: branches/branch-5-6/docs/en/mapfile/layer.txt
--- branches/branch-5-6/docs/en/mapfile/layer.txt	2010-07-30 17:43:04 UTC (rev 10427)
+++ branches/branch-5-6/docs/en/mapfile/layer.txt	2010-07-30 18:12:21 UTC (rev 10428)
@@ -42,14 +42,20 @@
         See :ref:`vector` for specific connection information for various
         data sources.
-CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms|plugin]
+CONNECTIONTYPE [local|sde|ogr|postgis|oraclespatial|wms|wfs|plugin]
     Type of connection. Default is local. See additional documentation for
     any other type.
     .. seealso::
         data sources.
+    .. note::
+        *mygis* is another connectiontype, but it is deprecated; please
+        see the :ref:`MySQL section <mysql>` of the Vector Data document
+        for connection details.
 DATA [filename]|[sde parameters][postgis table/column][oracle table/column]
     Full filename of the spatial data to process. No file extension is
     necessary for shapefiles. Can be specified relative to the
