[mapserver-commits] r10240 - trunk/msautotest/renderers
Wed Jun 23 06:03:45 EDT 2010
Author: tbonfort
Date: 2010-06-23 10:03:45 +0000 (Wed, 23 Jun 2010)
New Revision: 10240
   trunk/msautotest/renderers/embed_sb_rgba_tr.map
   trunk/msautotest/renderers/legend.map
   trunk/msautotest/renderers/marker_pixmap.map
   trunk/msautotest/renderers/point_ellipse.map
   trunk/msautotest/renderers/point_pixmap.map
   trunk/msautotest/renderers/point_truetype.map
   trunk/msautotest/renderers/point_vector.map
   trunk/msautotest/renderers/polygon-pixmap.map
   trunk/msautotest/renderers/polygon-simple.map
   trunk/msautotest/renderers/polygon-ttf.map
   trunk/msautotest/renderers/polygon-vector.map
   trunk/msautotest/renderers/run_test.py
props, aggpng24 -> png24
Modified: trunk/msautotest/renderers/embed_sb_rgba_tr.map
--- trunk/msautotest/renderers/embed_sb_rgba_tr.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/embed_sb_rgba_tr.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 IMAGECOLOR 0 0 0
 fontset "../misc/fonts.lst"
 TRANSPARENT ON
+imagecolor 255 255 255
 IMAGETYPE png
 SCALEBAR
Modified: trunk/msautotest/renderers/legend.map
--- trunk/msautotest/renderers/legend.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/legend.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -22,6 +22,7 @@
     font "default"
     size 9
   end
+  #postlabelcache true
 END
 LAYER
Modified: trunk/msautotest/renderers/marker_pixmap.map
--- trunk/msautotest/renderers/marker_pixmap.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/marker_pixmap.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT 0 0 400 300
 SIZE 400 300
 FONTSET "../misc/fonts.lst"
-IMAGETYPE aggpng24
+IMAGETYPE png24
 symbolset "symbolset"
 CONFIG MS_ERRORFILE "stderr"
Modified: trunk/msautotest/renderers/point_ellipse.map
--- trunk/msautotest/renderers/point_ellipse.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/point_ellipse.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT 0 0 400 300
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
Modified: trunk/msautotest/renderers/point_pixmap.map
--- trunk/msautotest/renderers/point_pixmap.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/point_pixmap.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT 0 0 400 300
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
Modified: trunk/msautotest/renderers/point_truetype.map
--- trunk/msautotest/renderers/point_truetype.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/point_truetype.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT 0 0 400 300
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
 LAYER
Modified: trunk/msautotest/renderers/point_vector.map
--- trunk/msautotest/renderers/point_vector.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/point_vector.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT 0 0 400 300
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
 LAYER
Modified: trunk/msautotest/renderers/polygon-pixmap.map
--- trunk/msautotest/renderers/polygon-pixmap.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/polygon-pixmap.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 EXTENT -125.549477 -69.508628 101.670954 15.840339
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
 shapepath "../misc/data"
Modified: trunk/msautotest/renderers/polygon-simple.map
--- trunk/msautotest/renderers/polygon-simple.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/polygon-simple.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
Modified: trunk/msautotest/renderers/polygon-ttf.map
--- trunk/msautotest/renderers/polygon-ttf.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/polygon-ttf.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
Modified: trunk/msautotest/renderers/polygon-vector.map
--- trunk/msautotest/renderers/polygon-vector.map	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/polygon-vector.map	2010-06-23 10:03:45 UTC (rev 10240)
@@ -10,7 +10,7 @@
 SIZE 400 300
-IMAGETYPE aggpng24
+IMAGETYPE png24
Modified: trunk/msautotest/renderers/run_test.py
--- trunk/msautotest/renderers/run_test.py	2010-06-23 09:43:55 UTC (rev 10239)
+++ trunk/msautotest/renderers/run_test.py	2010-06-23 10:03:45 UTC (rev 10240)
@@ -1,6 +1,6 @@
 #!/usr/bin/env python
-# $Id: run_test.py 1931 2003-03-05 15:30:09Z frank $
+# $Id$
 # Project:  MapServer
 # Purpose:  Test harnass script for MapServer autotest.
@@ -44,7 +44,7 @@
 # main()
 if __name__ == '__main__':
-    for renderer in ['aggpng24','cairopng','png']:
+    for renderer in ['png24','cairopng','png']:
         args = sys.argv[1:]
         args.extend(['-renderer',renderer])
         mstestlib.run_tests( args )
Property changes on: trunk/msautotest/renderers/run_test.py
___________________________________________________________________
Added: svn:keywords
   + Author Date Id Revision
