[mapserver-commits] r10260 - trunk/mapserver/mapscript/php
Mon Jun 28 12:01:30 EDT 2010
Author: aboudreault
Date: 2010-06-28 16:01:30 +0000 (Mon, 28 Jun 2010)
New Revision: 10260
   trunk/mapserver/mapscript/php/grid.c
   trunk/mapserver/mapscript/php/layer.c
   trunk/mapserver/mapscript/php/map.c
   trunk/mapserver/mapscript/php/php_mapscript.c
MapScript/PHP Fixed a few bugs related to lazy init
Modified: trunk/mapserver/mapscript/php/grid.c
--- trunk/mapserver/mapscript/php/grid.c	2010-06-28 13:56:58 UTC (rev 10259)
+++ trunk/mapserver/mapscript/php/grid.c	2010-06-28 16:01:30 UTC (rev 10260)
@@ -77,7 +77,7 @@
     php_grid->grid = (graticuleObj *)php_layer->layer->layerinfo;
-    if (Z_TYPE_P(php_layer->grid) == IS_OBJECT) {
+    if (php_layer->grid && (Z_TYPE_P(php_layer->grid) == IS_OBJECT)) {
         php_old_grid = (php_grid_object *) zend_object_store_get_object(php_layer->grid TSRMLS_CC);
         php_old_grid->parent.child_ptr = NULL;
         zend_objects_store_del_ref(php_layer->grid TSRMLS_CC);
Modified: trunk/mapserver/mapscript/php/layer.c
--- trunk/mapserver/mapscript/php/layer.c	2010-06-28 13:56:58 UTC (rev 10259)
+++ trunk/mapserver/mapscript/php/layer.c	2010-06-28 16:01:30 UTC (rev 10260)
@@ -830,7 +830,8 @@
     PHP_MAPSCRIPT_RESTORE_ERRORS(TRUE);
     php_layer = (php_layer_object *) zend_object_store_get_object(zobj TSRMLS_CC);
-    php_projection = (php_projection_object *) zend_object_store_get_object(php_layer->projection TSRMLS_CC);
+    if (php_layer->projection)
+        php_projection = (php_projection_object *) zend_object_store_get_object(php_layer->projection TSRMLS_CC);
     if ((status = layerObj_setProjection(php_layer->layer, projection)) != MS_SUCCESS)
@@ -838,7 +839,8 @@
         RETURN_LONG(status);
-    php_projection->projection = &(php_layer->layer->projection);
+        php_projection->projection = &(php_layer->layer->projection);
@@ -892,7 +894,8 @@
     if ((status = layerObj_setWKTProjection(php_layer->layer, projection)) != MS_SUCCESS)
@@ -900,7 +903,8 @@
         return;
Modified: trunk/mapserver/mapscript/php/map.c
--- trunk/mapserver/mapscript/php/map.c	2010-06-28 13:56:58 UTC (rev 10259)
+++ trunk/mapserver/mapscript/php/map.c	2010-06-28 16:01:30 UTC (rev 10260)
@@ -2106,7 +2106,6 @@
     int status = MS_FAILURE;
     long setUnitsAndExtents = MS_FALSE;
     php_map_object *php_map;
-    php_projection_object *php_projection;
     PHP_MAPSCRIPT_ERROR_HANDLING(TRUE);
     if (zend_parse_parameters(ZEND_NUM_ARGS() TSRMLS_CC, "s|l",
@@ -2117,7 +2116,6 @@
     php_map = (php_map_object *) zend_object_store_get_object(zobj TSRMLS_CC);
-    php_projection = (php_projection_object *) zend_object_store_get_object(php_map->projection TSRMLS_CC);
     status = mapscript_map_setProjection(MS_FALSE, php_map,
                                          projection, setUnitsAndExtents TSRMLS_CC);
@@ -2865,10 +2863,11 @@
         return;
-    php_outputformat = (php_outputformat_object *) zend_object_store_get_object(php_map->outputformat TSRMLS_CC);
+    if (php_map->outputformat)
+        php_outputformat = (php_outputformat_object *) zend_object_store_get_object(php_map->outputformat TSRMLS_CC);
     if ((status = mapObj_selectOutputFormat(php_map->map,
                                             type)) != MS_SUCCESS)
@@ -2876,7 +2875,7 @@
         mapscript_report_php_error(E_WARNING, "Unable to set output format to '%s'" TSRMLS_CC,
                                    type);
-    else
+    else if (php_map->outputformat)
         php_outputformat->outputformat = php_map->map->outputformat;
@@ -3450,8 +3449,10 @@
     php_rect_object *php_extent;
-    php_extent = (php_rect_object *) zend_object_store_get_object(php_map->extent TSRMLS_CC);
+    if (php_map->projection)
+        php_projection = (php_projection_object *) zend_object_store_get_object(php_map->projection TSRMLS_CC);
+    if (php_map->extent)
+        php_extent = (php_rect_object *) zend_object_store_get_object(php_map->extent TSRMLS_CC);
     in = php_map->map->projection;
     msInitProjection(&out);
@@ -3482,7 +3483,7 @@
         mapscript_report_php_error(E_WARNING, "setProjection failed" TSRMLS_CC);
         return MS_FAILURE;
-    else
+    else if (php_map->projection)
         php_projection->projection = &(php_map->map->projection);
@@ -3504,7 +3505,8 @@
             msCalculateScale(php_map->map->extent, php_map->map->units, php_map->map->width, php_map->map->height,
                              php_map->map->resolution, &(php_map->map->scaledenom));
-            php_extent->rect = &(php_map->map->extent);
+                php_extent->rect = &(php_map->map->extent);
Modified: trunk/mapserver/mapscript/php/php_mapscript.c
--- trunk/mapserver/mapscript/php/php_mapscript.c	2010-06-28 13:56:58 UTC (rev 10259)
+++ trunk/mapserver/mapscript/php/php_mapscript.c	2010-06-28 16:01:30 UTC (rev 10260)
@@ -557,7 +557,7 @@
     php_layer->layer->layerinfo = (graticuleObj *)malloc( sizeof( graticuleObj ) );
     initGrid((graticuleObj *)php_layer->layer->layerinfo);
         php_grid = (php_grid_object *) zend_object_store_get_object(php_layer->grid TSRMLS_CC);
         php_grid->parent.child_ptr = NULL;
