[mapserver-commits] r9913 - trunk/mapserver
Wed Mar 3 12:55:28 EST 2010
Author: assefa
Date: 2010-03-03 12:55:28 -0500 (Wed, 03 Mar 2010)
New Revision: 9913
   trunk/mapserver/mapogcsld.c
Fix column type detecting for SLD filters #3052
Modified: trunk/mapserver/mapogcsld.c
--- trunk/mapserver/mapogcsld.c	2010-03-03 17:36:54 UTC (rev 9912)
+++ trunk/mapserver/mapogcsld.c	2010-03-03 17:55:28 UTC (rev 9913)
@@ -723,8 +723,8 @@
     layerObj *psCurrentLayer = NULL;
     const char *pszWmsName=NULL;
     int j=0;
+    const char *key=NULL;
     if (!psRoot || !psLayer)
         return MS_FAILURE;
@@ -817,7 +817,18 @@
                                 if (j < psLayer->map->numlayers)
+                                    /*make sure that the tmp layer has all the metadata that
+                                      the orinal layer has, allowing to do parsing for
+                                      such things as gml_attribute_type #3052*/
+                                    while (1)
+                                        key = msNextKeyFromHashTable(&psCurrentLayer->metadata, key);
+                                        if (!key)
+                                          break;
+                                        else
+                                          msInsertHashTable(&psLayer->metadata, key,
+                                                            msLookupHashTable(&psCurrentLayer->metadata, key));
                                     FLTPreParseFilterForAlias(psNode, psLayer->map, j, "G");
