[mapserver-commits] r9923 - trunk/mapserver
Sat Mar 6 14:40:18 EST 2010
Author: tamas
Date: 2010-03-06 14:40:18 -0500 (Sat, 06 Mar 2010)
New Revision: 9923
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapmssql2008.c
Fixed the query handling with the MSSQL2008 driver (#3058)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2010-03-06 19:39:01 UTC (rev 9922)
+++ trunk/mapserver/HISTORY.TXT	2010-03-06 19:40:18 UTC (rev 9923)
@@ -14,6 +14,8 @@
 Current Version (SVN trunk):
+- Fixed the query handling with the MSSQL2008 driver (#3058)
 - Fixed swig zoomRectangle() method: the maxy in the rect object have to be < miny value (#3286)
 - Fix crash with GRID layers with no classes (#3352)
Modified: trunk/mapserver/mapmssql2008.c
--- trunk/mapserver/mapmssql2008.c	2010-03-06 19:39:01 UTC (rev 9922)
+++ trunk/mapserver/mapmssql2008.c	2010-03-06 19:40:18 UTC (rev 9923)
@@ -97,6 +97,30 @@
      layer->layerinfo = (void*) MSSQL2008layerinfo;
+void handleSQLError(layerObj *layer)
+   SQLCHAR       SqlState[6], Msg[SQL_MAX_MESSAGE_LENGTH];
+   SQLINTEGER    NativeError;
+   SQLSMALLINT   i, MsgLen;
+   SQLRETURN  rc;
+   msMSSQL2008LayerInfo *layerinfo = getMSSQL2008LayerInfo(layer);
+   if (layerinfo == NULL)
+       return;
+    // Get the status records.
+   i = 1;
+   while ((rc = SQLGetDiagRec(SQL_HANDLE_STMT, layerinfo->conn->hstmt, i, SqlState, &NativeError,
+            Msg, sizeof(Msg), &MsgLen)) != SQL_NO_DATA)
+      if(layer->debug)
+            msDebug("SQLError: %s\n", Msg);
+      i++;
 /* remove white space */
 /* dont send in empty strings or strings with just " " in them! */
 static char* removeWhite(char *str)
@@ -415,10 +439,8 @@
 		msSetError( MS_QUERYERR, "Could not parse the layer data", "msMSSQL2008LayerOpen()");
         return MS_FAILURE;
-    //setMSSQL2008LayerInfo(layer, layerinfo);
     return MS_SUCCESS;
@@ -492,7 +514,7 @@
 		Plus 10 formatted doubles (15 digits of precision, a decimal point, a space/comma delimiter each = 17 chars each)
 		Plus SRID + comma - if SRID is a long...we'll be safe with 10 chars
-	char        box3d[40 + 10 * 17 + 11];
+	char        box3d[40 + 10 * 22 + 11];
     char        query_string_temp[10000];       /* Should be big enough */
     int         t;
@@ -568,14 +590,23 @@
         columns_wanted = _strdup(buffer);
-	sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", /* %s.STSrid)", */
-		rect.minx, rect.miny,
-		rect.maxx, rect.miny,
-		rect.maxx, rect.maxy,
-		rect.minx, rect.maxy,
-        layerinfo->user_srid
+	if (rect.minx == rect.maxx || rect.miny == rect.maxy)
+        /* create point shape for rectangles with zero area */
+        sprintf(box3d, "Geometry::STGeomFromText('POINT(%.15g %.15g)',%s)", /* %s.STSrid)", */
+		    rect.minx, rect.miny, layerinfo->user_srid);
+    else
+	    sprintf(box3d, "Geometry::STGeomFromText('POLYGON((%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g,%.15g %.15g))',%s)", /* %s.STSrid)", */
+		    rect.maxx, rect.miny,
+		    rect.maxx, rect.maxy,
+		    rect.minx, rect.maxy,
+            layerinfo->user_srid
     /* substitute token '!BOX!' in geom_table with the box3d - do an unlimited # of subs */
     /* to not undo the work here, we need to make sure that data_source is malloc'd here */
@@ -1249,6 +1280,7 @@
         /* Any error assume out of recordset bounds */
         if (rc != SQL_SUCCESS && rc != SQL_SUCCESS_WITH_INFO)
+            handleSQLError(layer);
             return MS_DONE;
@@ -1263,6 +1295,8 @@
 				/* figure out how big the buffer needs to be */
                 rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
+                if (rc == SQL_ERROR)
                 if (needLen > 0)
@@ -1276,6 +1310,8 @@
 				    /* Now grab the data */
                     rc = SQLGetData(layerinfo->conn->hstmt, t + 1, SQL_C_BINARY, valueBuffer, needLen, &retLen);
+                    if (rc == SQL_ERROR || rc == SQL_SUCCESS_WITH_INFO)
 				    /* Terminate the buffer */
                     valueBuffer[retLen] = 0; /* null terminate it */
@@ -1292,6 +1328,8 @@
 				/* Set up to request the size of the buffer needed */
                 rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, dummyBuffer, 0, &needLen);
                 /* allow space for coercion to geometry collection if needed*/
                 wkbTemp = (char*)malloc(needLen+9);
@@ -1307,6 +1345,8 @@
 				/* Grab the WKB */
                 rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 1, SQL_C_BINARY, wkbBuffer, needLen, &retLen);
                 memcpy(&geomType, wkbBuffer + 1, 4);
@@ -1368,6 +1408,9 @@
             /* Next get unique id for row - since the OID shouldn't be larger than a long we'll assume billions as a limit */
             rc = SQLGetData(layerinfo->conn->hstmt, layer->numitems + 2, SQL_C_BINARY, oidBuffer, sizeof(oidBuffer) - 1, &retLen);
 			oidBuffer[retLen] = 0;
             record_oid = strtol(oidBuffer, NULL, 10);
@@ -1442,7 +1485,7 @@
     if(layer->numitems == 0)
-        snprintf(buffer, sizeof(buffer), "%s.STAsBinary()", layerinfo->geom_column);
+        snprintf(buffer, sizeof(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
     else
@@ -1451,7 +1494,7 @@
             snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "convert(varchar(max), %s),", layer->items[t]);
-        snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary()", layerinfo->geom_column);
+        snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer), "%s.STAsBinary(), convert(varchar(20), %s)", layerinfo->geom_column, layerinfo->urid_name);
@@ -1477,6 +1520,9 @@
         return MS_FAILURE;
+    layerinfo->sql = query_str;
+    layerinfo->row_num = 0;
 	return msMSSQL2008LayerGetShapeRandom(layer, shape, &(layerinfo->row_num));
@@ -1864,6 +1910,7 @@
     vtable->LayerWhichShapes = msMSSQL2008LayerWhichShapes;
     vtable->LayerNextShape = msMSSQL2008LayerNextShape;
     vtable->LayerGetShape = msMSSQL2008LayerGetShapeVT;
+    vtable->LayerResultsGetShape = msMSSQL2008LayerGetShapeVT; /* no special version, use ...GetShape() */
     vtable->LayerClose = msMSSQL2008LayerClose;
@@ -1898,6 +1945,7 @@
     layer->vtable->LayerWhichShapes = msMSSQL2008LayerWhichShapes;
     layer->vtable->LayerNextShape = msMSSQL2008LayerNextShape;
     layer->vtable->LayerGetShape = msMSSQL2008LayerGetShapeVT;
+    layer->vtable->LayerResultsGetShape = msMSSQL2008LayerGetShapeVT; /* no special version, use ...GetShape() */
     layer->vtable->LayerClose = msMSSQL2008LayerClose;
