[mapserver-commits] r10014 - trunk/docs/en/optimization
Thu Mar 25 11:22:10 EDT 2010
Author: warmerdam
Date: 2010-03-25 11:22:08 -0400 (Thu, 25 Mar 2010)
New Revision: 10014
   trunk/docs/en/optimization/fastcgi.txt
add note on renaming mapserv to mapserv.cgi (#3213)
Modified: trunk/docs/en/optimization/fastcgi.txt
--- trunk/docs/en/optimization/fastcgi.txt	2010-03-25 15:04:19 UTC (rev 10013)
+++ trunk/docs/en/optimization/fastcgi.txt	2010-03-25 15:22:08 UTC (rev 10014)
@@ -87,7 +87,11 @@
       -appConnTimeout 60 -idle-timeout 60 -init-start-delay 1
       -minProcesses 2 -maxClassProcesses 20 -startDelay 5
-4.  In your mapfile, set a PROCESSING directive to tell FastCGI to cache
+4.  Install a copy of the mapserv executable into the cgi-bin directory
+    with the extension .fcgi (ie. mapserv.fcgi).  Use this executable when
+    you want to utilize fastcgi support.
+5.  In your mapfile, set a PROCESSING directive to tell FastCGI to cache
     the connections and layer information on all layers for which connection
     caching is desired - ie. all slow layers.
