[mapserver-commits] r10017 - trunk/mapserver
Fri Mar 26 01:01:04 EDT 2010
Author: warmerdam
Date: 2010-03-26 01:01:03 -0400 (Fri, 26 Mar 2010)
New Revision: 10017
   trunk/mapserver/mapbits.c
   trunk/mapserver/mapdrawgdal.c
   trunk/mapserver/mapresample.c
   trunk/mapserver/mapserver.h
   trunk/mapserver/maputil.c
preliminary implementation of validity mask for raw valued raster handling (#2181)
Modified: trunk/mapserver/mapbits.c
--- trunk/mapserver/mapbits.c	2010-03-25 18:48:12 UTC (rev 10016)
+++ trunk/mapserver/mapbits.c	2010-03-26 05:01:03 UTC (rev 10017)
@@ -40,7 +40,6 @@
  * Hardcoded size of our bit array.
  * See function msGetNextBit for another hardcoded value.
-#define MS_ARRAY_BIT 32
 /* #define msGetBit(array, index) (*((array) + (index)/MS_ARRAY_BIT) & ( 1 << ((index) % MS_ARRAY_BIT))) */
Modified: trunk/mapserver/mapdrawgdal.c
--- trunk/mapserver/mapdrawgdal.c	2010-03-25 18:48:12 UTC (rev 10016)
+++ trunk/mapserver/mapdrawgdal.c	2010-03-26 05:01:03 UTC (rev 10017)
@@ -2112,6 +2112,10 @@
     int *band_list, band_count;
     int  i, j, k, band;
     CPLErr eErr;
+    float *f_nodatas = NULL;
+    unsigned char *b_nodatas = NULL;
+    GInt16 *i_nodatas = NULL;
+    int got_nodata=FALSE;
     if( image->format->bands > 256 )
@@ -2121,6 +2125,18 @@
+/*      We need at least GDAL 1.2.0 for the DatasetRasterIO             */
+/*      function.                                                       */
+#if !defined(GDAL_VERSION_NUM) || GDAL_VERSION_NUM < 1200
+    msSetError(MS_IMGERR,
+               "RAWMODE raster support requires GDAL 1.2.0 or newer.",
+               "msDrawRasterLayerGDAL_RawMode()" );
+    free( pBuffer );
+    return -1;
+#endif
 /*      What data type do we need?                                      */
     if( image->format->imagemode == MS_IMAGEMODE_INT16 )
@@ -2150,6 +2166,53 @@
+/*      Do we have nodata values?                                       */
+    f_nodatas = (float *) calloc(sizeof(float),band_count);
+    if( band_count <= 3
+        && (layer->offsite.red != -1
+            || layer->offsite.green != -1
+            || layer->offsite.blue != -1) )
+        if( band_count > 0 )
+            f_nodatas[0] = layer->offsite.red;
+        if( band_count > 1 )
+            f_nodatas[1] = layer->offsite.green;
+        if( band_count > 2 )
+            f_nodatas[2] = layer->offsite.blue;
+        got_nodata = TRUE;
+    if( !got_nodata )
+        for( band = 0; band < band_count && got_nodata; band++ )
+            f_nodatas[band] = msGetGDALNoDataValue(
+                layer, GDALGetRasterBand(hDS,band_list[band]), &got_nodata );
+    if( !got_nodata )
+        msFree( f_nodatas );
+        f_nodatas = NULL;
+    else if( eDataType == GDT_Byte )
+        b_nodatas = (unsigned char *) f_nodatas;
+        for( band = 0; band < band_count; band++ )
+            b_nodatas[band] = (unsigned char) f_nodatas[band];
+    else if( eDataType == GDT_Int16 )
+        i_nodatas = (GInt16 *) f_nodatas;
+            i_nodatas[band] = (GInt16) f_nodatas[band];
 /*      Allocate buffer, and read data into it.                         */
     pBuffer = malloc(dst_xsize * dst_ysize * image->format->bands
@@ -2162,7 +2225,6 @@
         return -1;
-#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1199
     eErr = GDALDatasetRasterIO( hDS, GF_Read,
                                 src_xoff, src_yoff, src_xsize, src_ysize,
                                 pBuffer, dst_xsize, dst_ysize, eDataType,
@@ -2176,20 +2238,9 @@
                     CPLGetLastErrorMsg(),
         free( pBuffer );
+        free( f_nodatas );
         return -1;
-#else
-     * The above could actually be implemented for pre-1.2.0 GDALs
-     * reading band by band, but it would be hard to do and test and would
-     * be very rarely useful so we skip it.
-    msSetError(MS_IMGERR,
-               "RAWMODE raster support requires GDAL 1.2.0 or newer.",
-               "msDrawRasterLayerGDAL_RawMode()" );
-    free( pBuffer );
-    return -1;
-#endif
 /*      Transfer the data to the imageObj.                              */
@@ -2203,27 +2254,54 @@
                 for( j = dst_xoff; j < dst_xoff + dst_xsize; j++ )
-                    image->img.raw_16bit[j + i * image->width
-                                         + band*image->width*image->height] =
-                        ((GInt16 *) pBuffer)[k++];
+                    int off = j + i * image->width
+                        + band*image->width*image->height;
+                    if( i_nodatas
+                        && ((GInt16 *) pBuffer)[k] == i_nodatas[band] )
+                        k++;
+                        continue;
+                    image->img.raw_16bit[off] = ((GInt16 *) pBuffer)[k++];
+                    MS_SET_BIT(image->img_mask,off);
             else if( image->format->imagemode == MS_IMAGEMODE_FLOAT32 )
-                    image->img.raw_float[j + i * image->width
-                        ((float *) pBuffer)[k++];
+                    if( f_nodatas
+                        && ((float *) pBuffer)[k] == f_nodatas[band] )
+                        k++;
+                        continue;
+                    image->img.raw_float[off] = ((float *) pBuffer)[k++];
             else if( image->format->imagemode == MS_IMAGEMODE_BYTE )
-                    image->img.raw_byte[j + i * image->width
-                        ((unsigned char *) pBuffer)[k++];
+                    if( b_nodatas
+                        && ((unsigned char *) pBuffer)[k] == b_nodatas[band] )
+                        k++;
+                        continue;
+                    image->img.raw_byte[off] = ((unsigned char *) pBuffer)[k++];
Modified: trunk/mapserver/mapresample.c
--- trunk/mapserver/mapresample.c	2010-03-25 18:48:12 UTC (rev 10016)
+++ trunk/mapserver/mapresample.c	2010-03-26 05:01:03 UTC (rev 10017)
@@ -83,7 +83,6 @@
 static int
 msNearestRasterResampler( imageObj *psSrcImage, rasterBufferObj *src_rb,
-                          colorObj offsite,
                           imageObj *psDstImage, rasterBufferObj *dst_rb,
                           int *panCMap,
                           SimpleTransformer pfnTransform, void *pCBData,
@@ -228,64 +227,43 @@
             else if( MS_RENDERER_RAWDATA(psSrcImage->format) )
-                int band;
+                int band, src_off, dst_off;
+                src_off = nSrcX + nSrcY * psSrcImage->width;
+                if( !MS_GET_BIT(psSrcImage->img_mask,src_off) )
+                    continue;
+                nSetPoints++;
+                dst_off = nDstX + nDstY * psDstImage->width;
+                MS_SET_BIT(psDstImage->img_mask,dst_off);
                 for( band = 0; band < psSrcImage->format->bands; band++ )
                     if( psSrcImage->format->imagemode == MS_IMAGEMODE_INT16 )
-                        int	nValue;
-                        nValue = psSrcImage->img.raw_16bit[
-                            nSrcX + nSrcY * psSrcImage->width
-                            + band*psSrcImage->width*psSrcImage->height];
-                        if( nValue == offsite.red )
-                            continue;
-                        nSetPoints++;
-                        psDstImage->img.raw_16bit[
-                            nDstX + nDstY * psDstImage->width
-                            + band*psDstImage->width*psDstImage->height]
-                            = nValue;
+                        psDstImage->img.raw_16bit[dst_off]
+                            = psSrcImage->img.raw_16bit[src_off];
                     else if( psSrcImage->format->imagemode
                              == MS_IMAGEMODE_FLOAT32)
-                        float fValue;
-                        fValue = psSrcImage->img.raw_float[
-                        if( fValue == offsite.red )
-                            continue;
-                        nSetPoints++;
-                        psDstImage->img.raw_float[
-                            = fValue;
+                        psDstImage->img.raw_float[dst_off]
+                            = psSrcImage->img.raw_float[src_off];
                     else if(psSrcImage->format->imagemode == MS_IMAGEMODE_BYTE)
-                        nValue = psSrcImage->img.raw_byte[
-                            continue;
-                        nSetPoints++;
-                        psDstImage->img.raw_byte[
-                            = (unsigned char) nValue;
+                        psDstImage->img.raw_byte[dst_off]
+                            = psSrcImage->img.raw_byte[src_off];
                     else
                         assert( 0 );
+                    src_off += psSrcImage->width * psSrcImage->height;
+                    dst_off += psDstImage->width * psDstImage->height;
@@ -318,8 +296,7 @@
 static void msSourceSample( imageObj *psSrcImage, rasterBufferObj *rb,
                             int iSrcX, int iSrcY, double *padfPixelSum,
-                            double dfWeight, double *pdfWeightSum,
-                            colorObj *offsite )
+                            double dfWeight, double *pdfWeightSum )
     if( MS_RENDERER_GD(psSrcImage->format) )
@@ -348,21 +325,21 @@
         int band;
+        int src_off;
+        src_off = iSrcX + iSrcY * psSrcImage->width;
+            return;
                 int	nValue;
-                    iSrcX + iSrcY * psSrcImage->width
+                nValue = psSrcImage->img.raw_16bit[src_off];
-                /* if band 1 is nodata, skip the rest */
-                if( band == 0 && nValue == offsite->red )
-                    return;
                 padfPixelSum[band] += dfWeight * nValue;
@@ -370,12 +347,7 @@
                 float fValue;
-                if( band == 0 && fValue == offsite->red )
-                    return;
+                fValue = psSrcImage->img.raw_float[src_off];
                 padfPixelSum[band] += fValue * dfWeight;
@@ -383,13 +355,8 @@
                 int nValue;
+                nValue = psSrcImage->img.raw_byte[src_off];
-                    continue;
                 padfPixelSum[band] += nValue * dfWeight;
             else
@@ -397,6 +364,8 @@
                 assert( 0 );
                 return;
         *pdfWeightSum += dfWeight;
@@ -420,7 +389,6 @@
 static int
 msBilinearRasterResampler( imageObj *psSrcImage, rasterBufferObj *src_rb,
-                           colorObj offsite,
                            int *panCMap,
@@ -500,19 +468,19 @@
             msSourceSample( psSrcImage, src_rb, nSrcX, nSrcY, padfPixelSum,
                             (1.0 - dfRatioX2) * (1.0 - dfRatioY2),
-                            &dfWeightSum, &offsite );
+                            &dfWeightSum );
             msSourceSample( psSrcImage, src_rb, nSrcX2, nSrcY, padfPixelSum,
                             (dfRatioX2) * (1.0 - dfRatioY2),
+                            &dfWeightSum );
             msSourceSample( psSrcImage, src_rb, nSrcX, nSrcY2, padfPixelSum,
                             (1.0 - dfRatioX2) * (dfRatioY2),
+                            &dfWeightSum );
             msSourceSample( psSrcImage, src_rb, nSrcX2, nSrcY2, padfPixelSum,
                             (dfRatioX2) * (dfRatioY2),
+                            &dfWeightSum );
             if( dfWeightSum == 0.0 )
                 continue;
@@ -581,30 +549,29 @@
                 int band;
+                int dst_off = nDstX + nDstY * psDstImage->width;
                             = (short) padfPixelSum[band];
                     else if( psSrcImage->format->imagemode == MS_IMAGEMODE_FLOAT32)
                             = (float) padfPixelSum[band];
                     else if( psSrcImage->format->imagemode == MS_IMAGEMODE_BYTE )
                             = (unsigned char) padfPixelSum[band];
+                    dst_off += psDstImage->width*psDstImage->height;
@@ -639,7 +606,7 @@
 static int
 msAverageSample( imageObj *psSrcImage, rasterBufferObj *src_rb,
                  double dfXMin, double dfYMin, double dfXMax, double dfYMax,
-                 colorObj *offsite, double *padfPixelSum,
+                 double *padfPixelSum,
                  double *pdfAlpha01 )
@@ -671,7 +638,7 @@
             dfWeight = (dfXCellMax-dfXCellMin) * (dfYCellMax-dfYCellMin);
             msSourceSample( psSrcImage, src_rb, iX, iY, padfPixelSum,
-                            dfWeight, &dfWeightSum, offsite );
+                            dfWeight, &dfWeightSum );
             dfMaxWeight += dfWeight;
@@ -693,7 +660,6 @@
 static int
 msAverageRasterResampler( imageObj *psSrcImage, rasterBufferObj *src_rb,
-                          colorObj offsite,
                           int *panCMap,
@@ -766,7 +732,7 @@
             if( !msAverageSample( psSrcImage, src_rb,
                                   dfXMin, dfYMin, dfXMax, dfYMax,
-                                  &offsite, padfPixelSum, &dfAlpha01 ) )
+                                  padfPixelSum, &dfAlpha01 ) )
                 continue;
@@ -830,30 +796,29 @@
                 int band;
@@ -1782,20 +1747,17 @@
     if( EQUAL(resampleMode,"AVERAGE") )
         result =
-            msAverageRasterResampler( srcImage, src_rb, layer->offsite,
-                                      image, rb,
+            msAverageRasterResampler( srcImage, src_rb, image, rb,
                                       anCMap, msApproxTransformer, pACBData,
                                       layer->debug );
     else if( EQUAL(resampleMode,"BILINEAR") )
         result =
-            msBilinearRasterResampler( srcImage, src_rb, layer->offsite,
-                                       image, rb,
+            msBilinearRasterResampler( srcImage, src_rb, image, rb,
                                        layer->debug );
     else
         result =
-            msNearestRasterResampler( srcImage, src_rb, layer->offsite,
-                                      image, rb,
+            msNearestRasterResampler( srcImage, src_rb, image, rb,
                                       layer->debug );
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-03-25 18:48:12 UTC (rev 10016)
+++ trunk/mapserver/mapserver.h	2010-03-26 05:01:03 UTC (rev 10017)
@@ -1521,7 +1521,7 @@
 #ifndef SWIG
   union {
-	void *plugin;
+    void *plugin;
     gdImagePtr gd;
 #ifdef USE_MING_FLASH
     void *swf;
@@ -1537,6 +1537,7 @@
     float *raw_float;
     unsigned char *raw_byte;
   } img;
+  ms_bitarray  img_mask;
 #endif
 } imageObj;
@@ -1931,6 +1932,14 @@
 MS_DLL_EXPORT int msDrawRasterLayer(mapObj *map, layerObj *layer, imageObj *image); /* in mapraster.c */
 MS_DLL_EXPORT imageObj *msDrawReferenceMap(mapObj *map);
+/* mapbits.c - bit array handling functions and macros */
+#define MS_ARRAY_BIT 32
+#define MS_GET_BIT(array,i) (array[i>>5] & (1 <<(i & 0x3f)))
+#define MS_SET_BIT(array,i) {array[i>>5] |= (1 <<(i & 0x3f));}
+#define MS_CLR_BIT(array,i) {array[i>>5] &= (~(1 <<(i & 0x3f)));}
 MS_DLL_EXPORT size_t msGetBitArraySize(int numbits); /* in mapbits.c */
 MS_DLL_EXPORT ms_bitarray msAllocBitArray(int numbits);
 MS_DLL_EXPORT int msGetBit(ms_bitarray array, int index);
@@ -1939,6 +1948,8 @@
 MS_DLL_EXPORT void msFlipBit(ms_bitarray array, int index);
 MS_DLL_EXPORT int msGetNextBit(ms_bitarray array, int index, int size);
+/* maplayer.c - layerObj  api */
 MS_DLL_EXPORT int msLayerInitItemInfo(layerObj *layer);
 MS_DLL_EXPORT void msLayerFreeItemInfo(layerObj *layer);
Modified: trunk/mapserver/maputil.c
--- trunk/mapserver/maputil.c	2010-03-25 18:48:12 UTC (rev 10016)
+++ trunk/mapserver/maputil.c	2010-03-26 05:01:03 UTC (rev 10017)
@@ -870,6 +870,9 @@
         image->imagepath = NULL;
         image->imageurl = NULL;
+        msFree( image->img_mask );
+        image->img_mask= NULL;
         msFree( image );
@@ -1390,23 +1393,23 @@
     else if(MS_RENDERER_PLUGIN(format)) {
     	image = format->vtable->createImage(width,height,format,&map->imagecolor);
     	image->format = format;
-		format->refcount++;
+        format->refcount++;
-		image->width = width;
-		image->height = height;
-		image->imagepath = NULL;
-		image->imageurl = NULL;
-                image->tilecache = NULL;
-                image->ntiles = 0;
-                image->resolution = map->resolution;
-                image->resolutionfactor = map->resolution/map->defresolution;
+        image->width = width;
+        image->height = height;
+        image->imagepath = NULL;
+        image->imageurl = NULL;
+        image->tilecache = NULL;
+        image->ntiles = 0;
+        image->resolution = map->resolution;
+        image->resolutionfactor = map->resolution/map->defresolution;
-		if (imagepath)
-			image->imagepath = strdup(imagepath);
-		if (imageurl)
-			image->imageurl = strdup(imageurl);
+        if (imagepath)
+            image->imagepath = strdup(imagepath);
+        if (imageurl)
+            image->imageurl = strdup(imageurl);
-		return image;
+        return image;
 #ifdef USE_AGG
     else if( MS_RENDERER_AGG(format) )
@@ -1423,7 +1426,7 @@
             && format->imagemode != MS_IMAGEMODE_BYTE )
-                    "Attempt to use illegal imagemode with rawdata renderer.",
+                       "Attempt to use illegal imagemode with rawdata renderer.",
                        "msImageCreate()" );
             return NULL;
@@ -1448,6 +1451,8 @@
             return NULL;
+        image->img_mask = msAllocBitArray( width*height );
         format->refcount++;
@@ -1490,7 +1495,7 @@
     else
         msSetError(MS_MISCERR,
-               "Unsupported renderer requested, unable to initialize image.",
+                   "Unsupported renderer requested, unable to initialize image.",
                    "msImageCreate()");
         return NULL;
