[mapserver-commits] r10022 - in trunk/mapserver/xmlmapfile: . tests
Fri Mar 26 14:50:35 EDT 2010
Author: aboudreault
Date: 2010-03-26 14:50:33 -0400 (Fri, 26 Mar 2010)
New Revision: 10022
   trunk/mapserver/xmlmapfile/mapfile.xsd
   trunk/mapserver/xmlmapfile/tests/symbolset.xml
Fixed symbol transparency possible values in xml schema
Modified: trunk/mapserver/xmlmapfile/mapfile.xsd
--- trunk/mapserver/xmlmapfile/mapfile.xsd	2010-03-26 17:04:41 UTC (rev 10021)
+++ trunk/mapserver/xmlmapfile/mapfile.xsd	2010-03-26 18:50:33 UTC (rev 10022)
@@ -476,7 +476,7 @@
 					</xs:sequence>
 				</xs:complexType>
 			</xs:element>
-			<xs:element name="transparent" type="xs:positiveInteger" minOccurs="0"/>
+			<xs:element name="transparent" type="xs:integer" minOccurs="0"/>
 		</xs:sequence>
 		<xs:attribute name="name" type="xs:string"/>
 		<xs:attribute name="type" use="required">
Modified: trunk/mapserver/xmlmapfile/tests/symbolset.xml
--- trunk/mapserver/xmlmapfile/tests/symbolset.xml	2010-03-26 17:04:41 UTC (rev 10021)
+++ trunk/mapserver/xmlmapfile/tests/symbolset.xml	2010-03-26 18:50:33 UTC (rev 10022)
@@ -14,7 +14,7 @@
 		<Points>
 			<point x="2" y="-3"/>
 		</Points>
-		<transparent>123</transparent>
+		<transparent>0</transparent>
 	</Symbol>
         <Symbol name="mySymbol222" type="CARTOLINE">
           <antialias>FALSE</antialias>
