[mapserver-commits] r10566 - branches/branch-5-6/docs/en/input/vector
Fri Oct 1 17:23:23 EDT 2010
Author: tamas
Date: 2010-10-01 21:23:23 +0000 (Fri, 01 Oct 2010)
New Revision: 10566
Added:
   branches/branch-5-6/docs/en/input/vector/mssql.txt
Add document for MSSQL2008 driver
Added: branches/branch-5-6/docs/en/input/vector/mssql.txt
--- branches/branch-5-6/docs/en/input/vector/mssql.txt	                        (rev 0)
+++ branches/branch-5-6/docs/en/input/vector/mssql.txt	2010-10-01 21:23:23 UTC (rev 10566)
@@ -0,0 +1,131 @@
+.. _mssql:
+MSSQL
+:Author: Tamas Szekeres
+:Contact: szekerest at gmail.com
+:Last Updated: 2010-10-01
+.. contents::
+    :depth: 3
+    :backlinks: top
+Introduction
+Microsoft SQL Server 2008+ supports storing spatial data by using the built in geometry/geography data
+types. MapServer supports a driver to access these tables containing spatial columns, which is
+compiled as a plugin (msplugin_mssql2008.dll).
+Creating spatial data tables in MSSQL 2008
+There are several ways to create spatial data tables in MSSQL 2008. Having an existing data you can
+easily upload that to an MSSQL table by using the `ogr2ogr <http://www.gdal.org/ogr2ogr>`__ commandline
+tool and the OGR's `MSSQL Spatial driver <http://www.gdal.org/ogr/drv_mssqlspatial.html>`__
+Connecting to Spatial Data in MSSQL 2008
+In order to connect to the MSSQL 2008 spatial database you should set up a valid connection string to
+the database like the following example:
+  Server=.\MSSQLSERVER2008;Database=Maps;Integrated Security=true
+Create MapServer Layer
+Once the connection can be established to the server the layer can be configured to access MSSQL2008
+as follows:
+  LAYER
+    NAME "rivers_mssql_spatial"
+    TYPE POLYGON
+    STATUS DEFAULT
+    CONNECTIONTYPE PLUGIN
+    PLUGIN "msplugin_mssql2008.dll"
+    CONNECTION "Server=.\MSSQLSERVER2008;Database=Maps;Integrated Security=true"
+    DATA "ogr_geometry from rivers USING UNIQUE ogr_fid USING SRID=4326"
+  END
+The DATA parameter is used to perform the SQL select statement to access your table in MSSQL.
+The geometry column is required in the select statement; in the above example the ogr_geometry
+column is the geometry column in the rivers table. The table should also have an unique column
+(ogr_fid) which is provided for random access to the features in the feature query operations.
+The DATA section should also contain the spatial reference id (SRID) of the features in the data table
+The SRID is used when specifying the search shapes during the intersect operations which should match
+with the SRID of the features otherwise no features are returned in a particular query.
+if you omit specifying the SRID value in the DATA section the diver will use SRID=0 when defining
+the search shapes.
+The expected location on the plugin dll
+On Windows platforms the DLLs needed by the program are searched for in the following order:
+1) The directory from which the application loaded.
+2) The current directory.
+3) The system directory. Use the `GetSystemDirectory <http://msdn.microsoft.com/en-us/library/ms724373.aspx>`__
+   function to get the path of this directory.
+4) The 16-bit system directory.
+5) The Windows directory. Use the `GetWindowsDirectory <http://msdn.microsoft.com/en-us/library/ms724454.aspx>`__
+6) The directories that are listed in the PATH environment variable.
+Using spatial indexes
+In order to speed up the access to the features a spatial index should be created to the
+geometry column which could easily be done with the OGR MSSQL Spatial driver like:
+  ogrinfo -sql "create spatial index on rivers" "MSSQL:server=.\MSSQLSERVER2008;database=Maps;Integrated Security=true"
+In general we can safely rely on the query optimizer to select the most appropriate index in the sql
+query operations. In some cases - however - we should force the optimizer to use the spatial index
+by specifying the index hint in the DATA section like:
+  DATA "ogr_geometry from rivers using index ogr_geometry_sidx USING UNIQUE ogr_fid USING SRID=4326"
+Layer Processing Options
+We can control the behaviour of the MSSQL driver by using the following PROCESSING options:
+    - **CLOSE_CONNECTION=DEFER** - This is where you can enable connection pooling for certain
+      layer types. Connection pooling will allow MapServer to share the handle to an open database
+      or layer connection throughout a single map draw process.
+Obtaining binaries containing the MSSQL plugin dll
+Currently the following binary distributions contain msplugin_mssql2008.dll
+- `MapServer and GDAL binary and SDK packages <http://vbkto.dyndns.org/sdk/>`__
+- `MS4W distributions <http://www.maptools.org/ms4w/>`__
+More Information
+* `OGR MSSQL Spatial driver page <http://www.gdal.org/ogr/drv_mssqlspatial.html>`__ (describes the OGR MSSQL support)
+* `ogr2ogr application <http://www.gdal.org/ogr2ogr>`__ (describes the ogr2ogr commandline application)
+* :ref:`vector` (MapServer Vector Data Access Guide)
