[mapserver-commits] r10582 - trunk/docs/en/development/rfc
Thu Oct 7 21:57:56 EDT 2010
Author: warmerdam
Date: 2010-10-08 01:57:56 +0000 (Fri, 08 Oct 2010)
New Revision: 10582
Added:
   trunk/docs/en/development/rfc/ms-rfc-62.txt
   trunk/docs/en/development/rfc/index.txt
preliminary writeup for RFC 62
Modified: trunk/docs/en/development/rfc/index.txt
--- trunk/docs/en/development/rfc/index.txt	2010-10-07 19:42:44 UTC (rev 10581)
+++ trunk/docs/en/development/rfc/index.txt	2010-10-08 01:57:56 UTC (rev 10582)
@@ -71,4 +71,6 @@
    ms-rfc-59
    ms-rfc-60
    ms-rfc-61
+   ms-rfc-62
Added: trunk/docs/en/development/rfc/ms-rfc-62.txt
--- trunk/docs/en/development/rfc/ms-rfc-62.txt	                        (rev 0)
+++ trunk/docs/en/development/rfc/ms-rfc-62.txt	2010-10-08 01:57:56 UTC (rev 10582)
@@ -0,0 +1,205 @@
+.. _rfc62:
+  MS RFC 62: Support Additional WFS GetFeature Output Formats
+:Date: 2010/10/07
+:Author: Frank Warmerdam
+:Contact: warmerdam at pobox.com
+:Last Edited: $Date: 2010-09-28 17:40:49 -0400 (Tue, 28 Sep 2010) $
+:Status: Development
+:Id: $Id$
+Description: This RFC proposes to extend the ability of the WFS GetFeature
+request to support formats other than GML.  Support for template query
+formatting (aka RFC 36) is introduced as well as support for output to
+OGR outputs.  Control of output formats is managed via appropriate
+OUTPUTFORMAT declarations.
+WFS GetFeature Changes
+1) If the WFS OUTPUTFORMAT value is not one of the existing supported values,
+then the set of outputFormatObj's for the map will be searched for one with
+a matching name or mime type and an image mode of MS_IMAGEMODE_FEATURE.
+2) If the wfs_formats metadata exists on the layer, it should be a comma
+delimited list of output formats permitted for this layer.  Any other will not
+be selectable with the OUTPUTFORMAT parameter to GetFeature.
+3) The existing GML2/GML3 generation support will be retained in essentially
+it's current form within mapwfs.c, but it's preamble and postfix generation
+will be moved into separate functions to reduce the "gml clutter" in the
+main msWFSGetFeature() function.
+4) If an outputFormatObj is being used instead of GML output, it will be
+generated by a call to msReturnTemplateQuery() which already supports output
+via the new template engine (RFC 36) as well as call outs for other renderers.
+outputFormatObj
+A new image mode value will be added, MS_IMAGEMODE_FEATURE, intended to
+be approriate for formats that are feature oriented, and cannot be meaningfully
+seen as an image.  RFC 36 style template output format declarations will now
+default to this imagemode.  The WFS GetFeature() directive will only
+support output formats of this image mode.
+As well a new renderer value, MS_RENDER_WITH_OGR, will be added for OGR
+output.
+OGR OUTPUTFORMAT Declarations
+The OGR renderer will support the following FORMATOPTION declarations:
+DSCO:*
+  Anything prefixed by DSCO: is used as a dataset creation option with the
+  OGR driver.
+LCO:*
+  Anything prefixed by LCO: is used as a layer creation option.
+FORM=simple/zip/multipart
+  Indicates whether the result should be a simple single file (single), a
+  mime multipart attachment (multipart) or a zip file (zip).  "zip" is
+  the default.
+STORAGE=memory/filesystem/stream
+  Indicates where the datasource should be stored while being written.
+  "file" is the default.
+  If "memory" then it will be created in /vsimem/ - but this is only suitable
+  for drivers supporting VSI*L which we can't easily determine automatically.
+  If "file" then a temporary directory will be created under the IMAGEPATH
+  were the file(s) will be written and then read back to stream to the
+  client.
+  If "stream" then the datasource will be created with a name "/vsistdout"
+  as an attempt to write directly to stdout.  Only a few OGR drivers will
+  work properly in this mode (ie. CSV, perhaps kml, gml).
+COMPRESSION=none/gzip
+  Should gzip compression be applied as the result is returned?  This is
+  generally not suitable for use with FORM=zip which is already compressing
+  the image.  "none" is the default.
+FILENAME=name
+  Provides a name for the datasource created, default is "result.dat".
+Examples::
+  OUTPUTFORMAT
+    NAME "CSV"
+    DRIVER "OGR/CSV"
+    MIMETYPE "text/csv"
+    FORMATOPTION "LCO:GEOMETRY=AS_WKT"
+    FORMATOPTION "STORAGE=memory"
+    FORMATOPTION "FORM=simple"
+    FORMATOPTION "FILENAME=result.csv"
+  END
+  OUTPUTFORMAT
+    NAME "OGRGML"
+    DRIVER "OGR/GML"
+    FORMATOPTION "STORAGE=filesystem"
+    FORMATOPTION "FORM=multipart"
+    FORMATOPTION "FILENAME=result.gml"
+  END
+  OUTPUTFORMAT
+    NAME "SHAPEZIP"
+    DRIVER "OGR/ESRI Shapefile"
+    FORMATOPTION "FORM=zip"
+    FORMATOPTION "FILENAME=result.zip"
+  END
+OGR Renderer Implementation
+The OGR Renderer will be implemented as the function msOGRWriteFromQuery()
+in the new file mapogroutput.c.  It will create a new OGR datasource based
+on the information in the output format declaration.  It will then
+create an output layer for each map layer with an active, non-empty
+query resultcache.  Those resultcache shapes will be written.
+- The gml_include_items rules will be used to decide what attributes should
+  be written to the output layers.
+- the gml field name aliasing mechanism will be supported for OGR output.
+- Layers will be created with a geometry type based on the type of the layer
+  with POINT as wkbPoint, LINE as wkbLineString, and POLYGON as wkbPolygon.
+- Currently all output fields will be created with a type of OFTString since
+  we do not have a mechanism to know the real types of source fields.
+- Some features, such as zip output, will only be supported with GDAL/OGR 1.8.
+  These features will be made conditional on the GDAL/OGR version.
+Use of CPL Services
+Support for WFS OGR output is dependent on USE_OGR being defined.  But
+when available it implies that GDAL/OGR CPL (Common Portability Library)
+services are also available.  These include the virtual file system
+interface (VSI*L) which provides services like "in memory" files.  The
+/vsimem services will be used to avoid writing intermediate files to disk
+if STORAGE=memory, the default configuration.
+Note that the /vsimem/ service is already being used for WMS layers to
+avoid having to write images from remove WMS servers to disk, in WCS
+to avoid writing GDAL-written images to disk and in WMS when using GDAL
+based outputformats.  So this isn't really new.
+As well, CPL includes support for gzip compression via the /vsigzip
+virtual filesystem handler.
+In the past GDAL has *not* had support for writing zip files; a feature
+that is very desirable as a mechanism for both compressing and grouping
+multi-file sets produced by many OGR drivers.  As part of the development
+undertaken for this RFC it is intended that GDAL will be extended with
+a CPL API for writing zip files, or alternatively a /vsizip/ virtual file
+system mechanism to write files.
+Backwards Compatibilty Issues
+Further Considerations
+- It should be noted that the DescribeFeatureType WFS operation will still only
+  support GML formatted description for feature types.
+- A prototype implementation has been developed (by Frank Warmerdam) and is
+  working though it is not quite feature complete, and will need some refinement
+  before it can be committed.
+Outstanding Issues
+- How do we alter msReturnTemplate() to support the WFS limit on number
+  of features, and offset to the first feature?
+- What are the implications if queries in other circumstances than WFS
+  GetFeature pick an OGR output format?
+- Do we need to support multipoint, multilinestring and multipolygon generation?
+- Are there other mechanisms than gml_include_items we need to consult to
+  decide on fields to write?
+- Do we want to introduce a mechanism to apply stronger typing to fields in
+  the output files?
+Voting history
