[mapserver-commits] r10593 - trunk/mapserver
Tue Oct 12 10:42:55 EDT 2010
Author: warmerdam
Date: 2010-10-12 07:42:55 -0700 (Tue, 12 Oct 2010)
New Revision: 10593
   trunk/mapserver/mapshape.c
fix writing z/m shapes, error out in msSHPCreate for Z/M types if not enabled (#3564)
Modified: trunk/mapserver/mapshape.c
--- trunk/mapserver/mapshape.c	2010-10-12 14:42:29 UTC (rev 10592)
+++ trunk/mapserver/mapshape.c	2010-10-12 14:42:55 UTC (rev 10593)
@@ -434,6 +434,23 @@
   ms_int32 i32;
   double dValue;
+#ifndef USE_POINT_Z_M
+  if( nShapeType == SHP_POLYGONZ
+      || nShapeType == SHP_POLYGONM
+      || nShapeType == SHP_ARCZ
+      || nShapeType == SHP_ARCM
+      || nShapeType == SHP_POINTZ
+      || nShapeType == SHP_POINTM
+      || nShapeType == SHP_MULTIPOINTZ
+      || nShapeType == SHP_MULTIPOINTM )
+      msSetError( MS_SHPERR,
+                  "Attempt to create M/Z shapefile but without having enabled Z/M support.",
+                  "msSHPCreate()" );
+      return NULL;
+#endif
   /*      Establish the byte order on this system.                        */
@@ -748,14 +765,15 @@
+    nRecordSize = 44 + 4*t_nParts + 16 * t_nPoints;
 #ifdef USE_POINT_Z_M
-    /*      Polygon. Arc with Z                                             */
+    /*      measured shape : polygon and arc.                               */
-    if (psSHP->nShapeType == SHP_POLYGONZ || psSHP->nShapeType == SHP_ARCZ) {
-      dfMMin = shape->line[0].point[0].z;
-      dfMMax = shape->line[shape->numlines-1].point[shape->line[shape->numlines-1].numpoints-1].z;
+    if(psSHP->nShapeType == SHP_POLYGONM || psSHP->nShapeType == SHP_ARCM) {
+      dfMMin = shape->line[0].point[0].m;
+      dfMMax = shape->line[shape->numlines-1].point[shape->line[shape->numlines-1].numpoints-1].m;
       nRecordSize = 44 + 4*t_nParts + 8 + (t_nPoints* 16);
       ByteCopy( &(dfMMin), pabyRec + nRecordSize, 8 );
@@ -768,21 +786,21 @@
       for( i = 0; i < shape->numlines; i++ ) {
         for( j = 0; j < shape->line[i].numpoints; j++ ) {
-          ByteCopy( &(shape->line[i].point[j].z), pabyRec + nRecordSize, 8 );
+          ByteCopy( &(shape->line[i].point[j].m), pabyRec + nRecordSize, 8 );
           if( bBigEndian ) SwapWord( 8, pabyRec + nRecordSize );
           nRecordSize += 8;
-    } else
-      nRecordSize = 44 + 4*t_nParts + 16 * t_nPoints;
-    /*      measured shape : polygon and arc.                               */
+    /*      Polygon. Arc with Z                                             */
-    if(psSHP->nShapeType == SHP_POLYGONM || psSHP->nShapeType == SHP_ARCM) {
-      dfMMin = shape->line[0].point[0].m;
-      dfMMax = shape->line[shape->numlines-1].point[shape->line[shape->numlines-1].numpoints-1].m;
+    if (psSHP->nShapeType == SHP_POLYGONZ || psSHP->nShapeType == SHP_ARCZ
+        || psSHP->nShapeType == SHP_POLYGONM || psSHP->nShapeType == SHP_ARCM) {
+      dfMMin = shape->line[0].point[0].z;
+      dfMMax = shape->line[shape->numlines-1].point[shape->line[shape->numlines-1].numpoints-1].z;
@@ -795,15 +813,13 @@
-          ByteCopy( &(shape->line[i].point[j].m), pabyRec + nRecordSize, 8 );
+          ByteCopy( &(shape->line[i].point[j].z), pabyRec + nRecordSize, 8 );
           nRecordSize += 8;
-    else
-#endif /* USE_POINT_Z_M */
+#endif /* def USE_POINT_Z_M */
@@ -831,13 +847,13 @@
+    nRecordSize = 40 + 16 * t_nPoints;
-    if (psSHP->nShapeType == SHP_MULTIPOINTZ) {
-      nRecordSize = 48 + 16 * t_nPoints;
+    if (psSHP->nShapeType == SHP_MULTIPOINTM) {
+      dfMMax = shape->line[0].point[shape->line[0].numpoints-1].m;
-      dfMMax = shape->line[0].point[shape->line[0].numpoints-1].z;
       nRecordSize += 8;
@@ -847,19 +863,16 @@
       nRecordSize += 8;
       for( i = 0; i < shape->line[0].numpoints; i++ ) {
-        ByteCopy( &(shape->line[0].point[i].z), pabyRec + nRecordSize, 8 );
+        ByteCopy( &(shape->line[0].point[i].m), pabyRec + nRecordSize, 8 );
         nRecordSize += 8;
-    } else
-      nRecordSize = 40 + 16 * t_nPoints;
-    if (psSHP->nShapeType == SHP_MULTIPOINTM) {
+    if (psSHP->nShapeType == SHP_MULTIPOINTZ) {
+      dfMMax = shape->line[0].point[shape->line[0].numpoints-1].z;
-      dfMMax = shape->line[0].point[shape->line[0].numpoints-1].m;
       nRecordSize += 8;
@@ -869,13 +882,12 @@
       nRecordSize += 8;
-        ByteCopy( &(shape->line[0].point[i].m), pabyRec + nRecordSize, 8 );
+        ByteCopy( &(shape->line[0].point[i].z), pabyRec + nRecordSize, 8 );
         nRecordSize += 8;
-    } else
@@ -891,26 +903,20 @@
       SwapWord( 8, pabyRec + 20 );
+    nRecordSize = 20;
-    if (psSHP->nShapeType == SHP_POINTZ) {
-      nRecordSize = 28;
-      ByteCopy( &(shape->line[0].point[0].z), pabyRec + nRecordSize, 8 );
+    if (psSHP->nShapeType == SHP_POINTM) {
+      ByteCopy( &(shape->line[0].point[0].m), pabyRec + nRecordSize, 8 );
       nRecordSize += 8;
-    } else
-      nRecordSize = 20;
-    if (psSHP->nShapeType == SHP_POINTM) {
-      nRecordSize = 28;
-      ByteCopy( &(shape->line[0].point[0].m), pabyRec + nRecordSize, 8 );
+    if (psSHP->nShapeType == SHP_POINTZ) {
+      ByteCopy( &(shape->line[0].point[0].z), pabyRec + nRecordSize, 8 );
       nRecordSize += 8;
-    } else
-      nRecordSize = 20;
-#else
-    nRecordSize = 20;
