[mapserver-commits] r10606 - trunk/mapserver
Thu Oct 14 14:31:30 EDT 2010
Author: warmerdam
Date: 2010-10-14 11:31:30 -0700 (Thu, 14 Oct 2010)
New Revision: 10606
   trunk/mapserver/mapows.c
   trunk/mapserver/mapows.h
provide some ows defines and functions regardless of services enabled - fixes builds with no ows services
Modified: trunk/mapserver/mapows.c
--- trunk/mapserver/mapows.c	2010-10-14 18:25:41 UTC (rev 10605)
+++ trunk/mapserver/mapows.c	2010-10-14 18:31:30 UTC (rev 10606)
@@ -249,6 +249,66 @@
+/* msOWSParseVersionString()
+** Parse a version string in the format "a.b.c" or "a.b" and return an
+** integer in the format 0x0a0b0c suitable for regular integer comparisons.
+** Returns one of OWS_VERSION_NOTSET or OWS_VERSION_BADFORMAT if version
+** could not be parsed.
+int msOWSParseVersionString(const char *pszVersion)
+    char **digits = NULL;
+    int numDigits = 0;
+    if (pszVersion)
+        int nVersion = 0;
+        digits = msStringSplit(pszVersion, '.', &numDigits);
+        if (digits == NULL || numDigits < 2 || numDigits > 3)
+            msSetError(MS_OWSERR,
+                       "Invalid version (%s). Version must be in the "
+                       "format 'x.y' or 'x.y.z'",
+                       "msOWSParseVersionString()", pszVersion);
+            if (digits)
+                msFreeCharArray(digits, numDigits);
+            return OWS_VERSION_BADFORMAT;
+        nVersion = atoi(digits[0])*0x010000;
+        nVersion += atoi(digits[1])*0x0100;
+        if (numDigits > 2)
+            nVersion += atoi(digits[2]);
+        return nVersion;
+    return OWS_VERSION_NOTSET;
+/* msOWSGetVersionString()
+** Returns a OWS version string in the format a.b.c from the integer
+** version value passed as argument (0x0a0b0c)
+** Fills in the pszBuffer and returns a reference to it. Recommended buffer
+** size is OWS_VERSION_MAXLEN chars.
+const char *msOWSGetVersionString(int nVersion, char *pszBuffer)
+    if (pszBuffer)
+        snprintf(pszBuffer, OWS_VERSION_MAXLEN-1, "%d.%d.%d",
+            (nVersion/0x10000)%0x100, (nVersion/0x100)%0x100, nVersion%0x100);
+    return pszBuffer;
 #if defined(USE_WMS_SVR) || defined (USE_WFS_SVR) || defined (USE_WCS_SVR) || defined(USE_SOS_SVR) || defined(USE_WMS_LYR) || defined(USE_WFS_LYR)
 #if !defined(USE_PROJ)
@@ -521,66 +581,6 @@
     return language;
-/* msOWSParseVersionString()
-** Parse a version string in the format "a.b.c" or "a.b" and return an
-** integer in the format 0x0a0b0c suitable for regular integer comparisons.
-** Returns one of OWS_VERSION_NOTSET or OWS_VERSION_BADFORMAT if version
-** could not be parsed.
-int msOWSParseVersionString(const char *pszVersion)
-    char **digits = NULL;
-    int numDigits = 0;
-    if (pszVersion)
-        int nVersion = 0;
-        digits = msStringSplit(pszVersion, '.', &numDigits);
-        if (digits == NULL || numDigits < 2 || numDigits > 3)
-            msSetError(MS_OWSERR,
-                       "Invalid version (%s). Version must be in the "
-                       "format 'x.y' or 'x.y.z'",
-                       "msOWSParseVersionString()", pszVersion);
-            if (digits)
-                msFreeCharArray(digits, numDigits);
-            return OWS_VERSION_BADFORMAT;
-        nVersion = atoi(digits[0])*0x010000;
-        nVersion += atoi(digits[1])*0x0100;
-        if (numDigits > 2)
-            nVersion += atoi(digits[2]);
-        return nVersion;
-    return OWS_VERSION_NOTSET;
-/* msOWSGetVersionString()
-** Returns a OWS version string in the format a.b.c from the integer
-** version value passed as argument (0x0a0b0c)
-** Fills in the pszBuffer and returns a reference to it. Recommended buffer
-** size is OWS_VERSION_MAXLEN chars.
-const char *msOWSGetVersionString(int nVersion, char *pszBuffer)
-    if (pszBuffer)
-        snprintf(pszBuffer, OWS_VERSION_MAXLEN-1, "%d.%d.%d",
-            (nVersion/0x10000)%0x100, (nVersion/0x100)%0x100, nVersion%0x100);
-    return pszBuffer;
 ** msOWSPrintMetadata()
Modified: trunk/mapserver/mapows.h
--- trunk/mapserver/mapows.h	2010-10-14 18:25:41 UTC (rev 10605)
+++ trunk/mapserver/mapows.h	2010-10-14 18:31:30 UTC (rev 10606)
@@ -184,15 +184,6 @@
                                                 const char *namespaces,
                                                 const char *name);
-#if defined(USE_WMS_SVR) || defined (USE_WFS_SVR) || defined (USE_WCS_SVR) || defined(USE_SOS_SVR) || defined(USE_WMS_LYR) || defined(USE_WFS_LYR)
-MS_DLL_EXPORT int msOWSMakeAllLayersUnique(mapObj *map);
-MS_DLL_EXPORT int msOWSNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions);
-MS_DLL_EXPORT char *msOWSTerminateOnlineResource(const char *src_url);
-MS_DLL_EXPORT char *msOWSGetOnlineResource(mapObj *map, const char *namespaces, const char *metadata_name, cgiRequestObj *req);
-MS_DLL_EXPORT const char *msOWSGetSchemasLocation(mapObj *map);
-MS_DLL_EXPORT const char *msOWSGetLanguage(mapObj *map, const char *context);
 /* Constants for OWS Service version numbers */
 #define OWS_0_1_2   0x000102
 #define OWS_0_1_4   0x000104
@@ -213,7 +204,16 @@
 MS_DLL_EXPORT int msOWSParseVersionString(const char *pszVersion);
 MS_DLL_EXPORT const char *msOWSGetVersionString(int nVersion, char *pszBuffer);
+#if defined(USE_WMS_SVR) || defined (USE_WFS_SVR) || defined (USE_WCS_SVR) || defined(USE_SOS_SVR) || defined(USE_WMS_LYR) || defined(USE_WFS_LYR)
+MS_DLL_EXPORT int msOWSMakeAllLayersUnique(mapObj *map);
+MS_DLL_EXPORT int msOWSNegotiateVersion(int requested_version, int supported_versions[], int num_supported_versions);
+MS_DLL_EXPORT char *msOWSTerminateOnlineResource(const char *src_url);
+MS_DLL_EXPORT char *msOWSGetOnlineResource(mapObj *map, const char *namespaces, const char *metadata_name, cgiRequestObj *req);
+MS_DLL_EXPORT const char *msOWSGetSchemasLocation(mapObj *map);
+MS_DLL_EXPORT const char *msOWSGetLanguage(mapObj *map, const char *context);
 /* OWS_NOERR and OWS_WARN passed as action_if_not_found to printMetadata() */
 #define OWS_NOERR   0
 #define OWS_WARN    1
