[mapserver-commits] r10620 - trunk/mapserver
Mon Oct 18 23:54:36 EDT 2010
Author: warmerdam
Date: 2010-10-18 20:54:36 -0700 (Mon, 18 Oct 2010)
New Revision: 10620
   trunk/mapserver/mapgdal.c
   trunk/mapserver/mapogroutput.c
   trunk/mapserver/mapproject.h
expose msProjectionObj2OGCWKT(), reproject ogrout shapes, write projection via ogr (#3570)
Modified: trunk/mapserver/mapgdal.c
--- trunk/mapserver/mapgdal.c	2010-10-19 03:47:58 UTC (rev 10619)
+++ trunk/mapserver/mapgdal.c	2010-10-19 03:54:36 UTC (rev 10620)
@@ -40,7 +40,6 @@
 #include "cpl_conv.h"
 #include "cpl_string.h"
-static char *msProjectionObjToWKT( projectionObj *proj );
 static int    bGDALInitialized = 0;
@@ -389,11 +388,11 @@
         GDALSetGeoTransform( hMemDS, map->gt.geotransform );
-        pszWKT = msProjectionObjToWKT( &(map->projection) );
+        pszWKT = msProjectionObj2OGCWKT( &(map->projection) );
         if( pszWKT != NULL )
             GDALSetProjection( hMemDS, pszWKT );
-            CPLFree( pszWKT );
+            msFree( pszWKT );
@@ -574,20 +573,38 @@
     return MS_SUCCESS;
+#else
+void msGDALInitialize( void ) {}
+void msGDALCleanup(void) {}
+#endif /* def USE_GDAL */
-/*                        msProjectionObjToWKT()                        */
+/*                      msProjectionObj2OGCWKT()                        */
 /*      We stick to the C API for OGRSpatialReference object access     */
 /*      to allow MapServer+GDAL to be built without C++                 */
 /*      complications.                                                  */
 /*      Note that this function will return NULL on failure, and the    */
-/*      returned string must be freed with CPLFree(), not msFree().     */
+/*      returned string should be freed with msFree().                  */
-char *msProjectionObjToWKT( projectionObj *projection )
+char *msProjectionObj2OGCWKT( projectionObj *projection )
+#if !defined(USE_GDAL) && !defined(USE_OGR)
+    msSetError(MS_OGRERR,
+               "Not implemented since neither OGR nor GDAL is enabled.",
+               "msProjectionObj2OGCWKT()");
+    return NULL;
+#else /* defined USE_GDAL or USE_OGR */
     OGRSpatialReferenceH hSRS;
     char *pszWKT=NULL, *pszProj4;
     int  nLength = 0, i;
@@ -626,14 +643,17 @@
         eErr = OSRExportToWkt( hSRS, &pszWKT );
     OSRDestroySpatialReference( hSRS );
-    return pszWKT;
-#else
+    if( pszWKT )
+        char *pszWKT2 = strdup(pszWKT);
+        CPLFree( pszWKT );
-void msGDALInitialize( void ) {}
-void msGDALCleanup(void) {}
+        return pszWKT2;
+    else
+        return NULL;
+#endif /* defined USE_GDAL or USE_OGR */
-#endif /* def USE_GDAL */
Modified: trunk/mapserver/mapogroutput.c
--- trunk/mapserver/mapogroutput.c	2010-10-19 03:47:58 UTC (rev 10619)
+++ trunk/mapserver/mapogroutput.c	2010-10-19 03:54:36 UTC (rev 10620)
@@ -35,6 +35,7 @@
 #if defined(USE_OGR)
 #  define __USE_LARGEFILE64 1
 #  include "ogr_api.h"
+#  include "ogr_srs_api.h"
 #  include "cpl_conv.h"
 #  include "cpl_vsi.h"
 #  include "cpl_string.h"
@@ -513,11 +514,22 @@
         OGRSpatialReferenceH srs = NULL;
         gmlItemListObj *item_list = NULL;
         const char *value;
+        char *pszWKT;
+        int  reproject = MS_FALSE;
         if( !layer->resultcache || layer->resultcache->numresults == 0 )
             continue;
+/*      Will we need to reproject?                                      */
+        if(layer->transform == MS_TRUE
+           && layer->project
+           && msProjectionsDiffer(&(layer->projection),
+                                  &(layer->map->projection)) )
+            reproject = MS_TRUE;
 /*      Establish the geometry type to use for the created layer.       */
 /*      First we consult the wfs_geomtype field and fallback to         */
 /*      deriving something from the type of the mapserver layer.        */
@@ -556,6 +568,16 @@
             eGeomType = wkbNone;
         else
             eGeomType = wkbUnknown;
+/*      Create a spatial reference.                                     */
+        if( pszWKT != NULL )
+            srs = OSRNewSpatialReference( pszWKT );
+            msFree( pszWKT );
 /*      Create the corresponding OGR Layer.                             */
@@ -693,12 +715,22 @@
+            if( reproject )
+                status =
+                    msProjectShape(&layer->projection, &layer->map->projection,
+                                   &resultshape);
             ** Write out the feature to OGR.
-            status = msOGRWriteShape( layer, hOGRLayer, &resultshape,
-                                      item_list );
+            if( status == MS_SUCCESS )
+                status = msOGRWriteShape( layer, hOGRLayer, &resultshape,
+                                          item_list );
             if(status != MS_SUCCESS) {
                 msOGRCleanupDS( datasource_name );
                 return status;
Modified: trunk/mapserver/mapproject.h
--- trunk/mapserver/mapproject.h	2010-10-19 03:47:58 UTC (rev 10619)
+++ trunk/mapserver/mapproject.h	2010-10-19 03:54:36 UTC (rev 10620)
@@ -70,6 +70,7 @@
 MS_DLL_EXPORT int msProjectionsDiffer(projectionObj *, projectionObj *);
 MS_DLL_EXPORT int msOGCWKT2ProjectionObj( const char *pszWKT, projectionObj *proj, int
                             debug_flag );
+MS_DLL_EXPORT char *msProjectionObj2OGCWKT( projectionObj *proj );
 MS_DLL_EXPORT void msFreeProjection(projectionObj *p);
 MS_DLL_EXPORT int msInitProjection(projectionObj *p);
