[mapserver-commits] r10622 - trunk/mapserver
Tue Oct 19 09:49:00 EDT 2010
Author: aboudreault
Date: 2010-10-19 06:49:00 -0700 (Tue, 19 Oct 2010)
New Revision: 10622
   trunk/mapserver/configure
   trunk/mapserver/configure.in
   trunk/mapserver/mapserver.h
   trunk/mapserver/mapstring.c
Added strlcpy function
Modified: trunk/mapserver/configure
--- trunk/mapserver/configure	2010-10-19 04:00:59 UTC (rev 10621)
+++ trunk/mapserver/configure	2010-10-19 13:49:00 UTC (rev 10622)
@@ -4447,6 +4447,102 @@
   STRINGS="-DNEED_STRLCAT $STRINGS"
 fi
+echo "$as_me:$LINENO: checking for strlcpy" >&5
+echo $ECHO_N "checking for strlcpy... $ECHO_C" >&6
+if test "${ac_cv_func_strlcpy+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Define strlcpy to an innocuous variant, in case <limits.h> declares strlcpy.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define strlcpy innocuous_strlcpy
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char strlcpy (); below.
+    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+    <limits.h> exists even on freestanding compilers.  */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef strlcpy
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char strlcpy ();
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_strlcpy) || defined (__stub___strlcpy)
+choke me
+#else
+char (*f) () = strlcpy;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != strlcpy;
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  ac_cv_func_strlcpy=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_func_strlcpy=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_strlcpy" >&5
+echo "${ECHO_T}$ac_cv_func_strlcpy" >&6
+if test $ac_cv_func_strlcpy = yes; then
+else
+  STRINGS="-DNEED_STRLCPY $STRINGS"
+fi
 echo "$as_me:$LINENO: checking for vsnprintf" >&5
 echo $ECHO_N "checking for vsnprintf... $ECHO_C" >&6
 if test "${ac_cv_func_vsnprintf+set}" = set; then
Modified: trunk/mapserver/configure.in
--- trunk/mapserver/configure.in	2010-10-19 04:00:59 UTC (rev 10621)
+++ trunk/mapserver/configure.in	2010-10-19 13:49:00 UTC (rev 10622)
@@ -70,6 +70,7 @@
 AC_CHECK_FUNC(strrstr, ,      STRINGS="-DNEED_STRRSTR $STRINGS")
 AC_CHECK_FUNC(strcasestr, ,      STRINGS="-DNEED_STRCASESTR $STRINGS")
 AC_CHECK_FUNC(strlcat, ,      STRINGS="-DNEED_STRLCAT $STRINGS")
+AC_CHECK_FUNC(strlcpy, ,      STRINGS="-DNEED_STRLCPY $STRINGS")
 AC_CHECK_FUNC(vsnprintf, STRINGS="-DHAVE_VSNPRINTF $STRINGS", )
 AC_SUBST(STRINGS, $STRINGS)
Modified: trunk/mapserver/mapserver.h
--- trunk/mapserver/mapserver.h	2010-10-19 04:00:59 UTC (rev 10621)
+++ trunk/mapserver/mapserver.h	2010-10-19 13:49:00 UTC (rev 10622)
@@ -1864,6 +1864,10 @@
 MS_DLL_EXPORT size_t strlcat(char *dst, const char *src, size_t siz);
 #endif /* NEED_STRLCAT */
+#ifdef NEED_STRLCPY
+MS_DLL_EXPORT size_t strlcpy(char *dst, const char *src, size_t siz);
+#endif /* NEED_STRLCAT */
 /* in mapsymbol.c */
 /* Use this function *only* with mapfile loading phase */
 MS_DLL_EXPORT int loadSymbolSet(symbolSetObj *symbolset, mapObj *map);
Modified: trunk/mapserver/mapstring.c
--- trunk/mapserver/mapstring.c	2010-10-19 04:00:59 UTC (rev 10621)
+++ trunk/mapserver/mapstring.c	2010-10-19 13:49:00 UTC (rev 10622)
@@ -166,6 +166,66 @@
 #endif
+ * Copyright (c) 1998 Todd C. Miller <Todd.Miller at courtesan.com>
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ *    notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ *    notice, this list of conditions and the following disclaimer in the
+ *    documentation and/or other materials provided with the distribution.
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
+ * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
+ * AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL
+ * THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
+ * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Copy src to string dst of size siz.  At most siz-1 characters
+ * will be copied.  Always NUL terminates (unless siz == 0).
+ * Returns strlen(src); if retval >= siz, truncation occurred.
+size_t
+strlcpy(char *dst, const char *src, size_t siz)
+        register char *d = dst;
+        register const char *s = src;
+        register size_t n = siz;
+        /* Copy as many bytes as will fit */
+        if (n != 0 && --n != 0) {
+                do {
+                        if ((*d++ = *s++) == 0)
+                                break;
+                } while (--n != 0);
+        /* Not enough room in dst, add NUL and traverse rest of src */
+        if (n == 0) {
+                if (siz != 0)
+                        *d = '\0';              /* NUL-terminate dst */
+                while (*s++)
+        return(s - src - 1);    /* count does not include NUL */
+#endif
 #ifdef NEED_STRCASESTR
  * Copyright (c) 1990, 1993
